Sky InsuranceEM Tuning
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Lewis583
Thread: thermostat??
    Sep 2012
    69
    thermostat??
    While the weather has been cold iv noticed my car hasnt been getting hot, changed the coolant and such but made no difference so I thought I would change my stat. Iv located what looks like the housing and removed it but no stat inside. The part iv removed is the plastic housing next to the sai on the engine block. Iv picked one up from euro carparts and they have given me a thermostat but my question is, is my stat that plastic unit, and is it map controlled or am i looking in the wroung place?? Car is a 2000 s3 apy cheers
    Oct 2007
    111
    There should be a stat in the bud. Its a plastic housing with a two bolt fixing near the altenator.
    Oct 2007
    111
    *there*
    Lewis583's Avatar
    Mar 2010
    872
    Thermostat is located in a housing that is hidden behind the alternator below the inlet manifold. Housing is held on with 2 10mm head bolts. It is possible to remove the housing and stat with the alternator in situ, but in my opinion, it is far better to remove the alternator for better access.
    Birdy likes this.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Feb 2008
    24
    Its easy enough to get the stat out without removing the alternator HOWEVER buy a new dip stick tube. Because its brittle plastic they snap very easily and its only £1.30 or so for a new tube..
    Sep 2012
    69
    Thanks guys ill tackle that tomorrow. Iv just put a new tube on it lol so hopefully should get away without breaking it. Ill try an do it with the alternator in place as I will have to do it on my back but will see what happens. Thanks again
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,787
    It's easy enough to do it leaving the alternator there. You just need a decent 1/4" ratchet. Wobble extensions may help but I didn't have any at the time. They're 10mm with 5mm hex sockets in the center. Don't forget a new o ring.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  1. Thermostats and Water temperature
    By Wak in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2007, 17:07
  2. Thermostat change problems
    By Broken Byzan in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd January 2006, 07:34
  3. External Temp thermostat
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th December 2005, 20:03
  4. Thermostat?
    By AudiVW in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2005, 16:58
  5. THERMOSTAT
    By LULU in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2004, 05:11
