Sky InsuranceChris Nott
Results 1 to 20 of 20
    Jan 2013
    15
    130tdi fuel gauge reading too high
    So as title says, the fuel level in the cluster is out by about a quarter of a tank, consistently. Then the gauge stops at last quarter until your empty! I know as I just ran out on the M6!! Just bought this car so..
    The fuel warning light came on, just below half a tank, so i think that was about right, just the level seems to be too high by said amount.
    I took out the sender and cleaned up the contacts but that hasn't changed anything. So i'm wondering if the level in the cluster needs recalibrating (if that can be done) or is faulty or the sender unit is at fault!
    Anyone with any experience of this? Thanks in advance.
    Jul 2010
    204
    When you turn the engine off does the needle drop to the bottom or does it only drop to onto the red? That would determine if the clocks have been tampered with to an extent....
    Jan 2013
    15
    Quote Originally Posted by Paul_TDi View Post
    Hi thanks for your reply, the needle drops as you would expect..
    Jun 2011
    Great Melton Norfolk
    1,340
    You can change the level reading with vcds.
    May 2012
    RETFORD, NOTTS
    1,716
    Quote Originally Posted by gen.heinz guderian View Post
    How do you do this and to what extent can i alter the fuel guage readings? mine doesnt move off full untill 150-200 miles, and the last 1/4 tank takes about 50 miles
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Cobra88's Avatar
    Sep 2011
    Live in Ipswich Suffolk (orig from W London)
    275
    if you have had the sender out of the tank
    you need to align the arrow on the sender with the arrow on the tank or it will never go under a quarter of a tank
    Check the arrows are lined up
    thats what the tank is like on my Diesel (would expect petrol to be same tank)
    Regards
    Rick
    2001 Audi A3 (8L) 1.9Tdi SE 110 3d in Mineral Grey.
    18" TD 1.2s & Toyos, S3 Seats with Kufatec looms, JOM Coilovers, .240 Nozzles (HFLO-X),PD150 Turbo (GT1749VB) Malone tuning map,Pipercross Air Filter,PD150 inlet manifold,PD150 TiP,PD150 Maf, Darkside EGR Delete,Darkside Alloy Intercooler & Pipe kit,Darkside Turbo Oil feed pipe,11mm Pump, PD lift pump. Currently 188hp and 320lbft, Southbend SMF st2, milltek full system with golf 4mo tailpipes,S3bumpers,Liquid Gauge,VCDS Lite Registered
    Jan 2013
    15
    Quote Originally Posted by Cobra88 View Post
    Regards
    Rick
    Yea I lined the arrow up on top of the sender it that's what you mean? Cheers
    Jan 2013
    15
    Some developments.. I filled the tank with diesel! Ouch!! Just done 55 miles and the needle hasn't moved, but also noticing now, when turning the engine off the needle doesn't drop all the way, it goes down to bottom of the red for about 15 seconds, then finally drops right down. So I am 99% sure this is a cluster issue. I have heard of companies who will re furb the cluster units, (I don't want to go down a new unit route..)
    anyone know of who might be good for this work? Cheers
    Jul 2010
    204
    Not heard of people refurbing them but you could look out for a 2nd hand unit on ebay or a car being broken and just swap your clocks over. You would just need a vag-com wizard to switch them.
    Jan 2013
    15
    yea dont really want to go down that route. This place say they can do a repair on the gauge and turn it around in three days all for 90 quid plus vat! Sounds very reasonable to me.
    Cobra88's Avatar
    Sep 2011
    275
    Hi Woofdog
    What is the number on your clocks
    are they full or half DIS ?
    I might have a spare set of half Dis clocks laying round.
    8LO 920 950 B depends if yours is a 130 sport or not (these are not sport)
    Jan 2013
    15
    Hi mate, thanks for the offer.
    I'm not sure of the number but it IS a 130 sport so I guess they wouldn't work.
    Cobra88's Avatar
    Sep 2011
    275
    depends if you have a full DIS or a Half DIS
    Jan 2013
    15
    not sure what the difference is.. does the full have trip computer etc? As mine just has service indicator and oil warnings etc.. no trip
    Cobra88's Avatar
    Sep 2011
    275
    you have half DIS then mate
    no MPG or outside temp etc
    Jan 2013
    15
    no none of that jazz mate.
    Let me know how much you want for them if you find them! I would have to get my local VAG specialist to program them in tho right? Does the mileage carry over?
    Cobra88's Avatar
    Sep 2011
    275
    No the mileage can be altered on the clocks once they are coded to your car
    I have the SCK number for the clocks i have.
    I'm offshore currently and will be back Monday AM
    will have a dig then and see what i have.
    Not 100% sure i still have them
    Regards
    Rick
    Yep you will need to get a VAG specialist to code them to your car
    Mar 2013
    49
    Hi guys,
    Sorry for bringing up an old ish thread but i have the same issue.
    Had the car for 3 days, driving on the M4 and ran out of fuel. Its a 1.9TDI 130 SE
    My fuel warning light came on at just under half a tank aswel and my car died at 1/4 left.
    Ive just checked and when i turn my car off the fuel needle doesnt drop all the way. It stops on the last notch. Pic below.
    Mine is a half DIS as you can see in the pic. Im actually wanting to upgrade to full dis and add full trip computer.
    It appears that the fuel gauge is misconfigured but how to i rectify it and why would it be wrong in the first place?
    Hope you guys can help
    Jan 2013
    15
    Hi did, you ever get this issue sorted out of interest?
    May 2012
    RETFORD, NOTTS
    1,716
    Quite common for fuel guage to miss read before full failure of cluster. Could last months or minutes!
    I can fit and correct milage if you get stuck. Woofdog did u fix yours?
  1. high fuel consumption (act maf readings too high)
    By navicx in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd September 2012, 17:40
  2. Heater blowing cold and temperature gauge reading too high
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 15:06
  3. Fuel gauge reading !! Can't be right ..
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2010, 12:13
  4. 2006 A6 Fuel gauge reading empty.... (2.7 tdi)
    By A6Ian in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th May 2010, 10:39
  5. Had a flat battery now fuel gauge reads empty.
    By casiodan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2009, 19:34
