Chris NottBadger5
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Inside tyre wear
    Sep 2010
    498
    Inside tyre wear
    Whilst having a wheel off yesterday I noticed that both front tyres have worn more on the inside than the outside, the fronts are up fro renewal soon anyway. The inside of the tyres, by about an inch i'd say, is almost bare, whereas the rest is about 2mm-ish.
    I gather this is to do with camber. It's a 1.9tdi Quattro Sport. Are the heavy on camber wear? These tyres have lasted me just over 2 years now, so the rate of wear is not an issue I don't think. Just something that is puzzling me.
    Oct 2012
    Telford
    95
    You need to get it 4 wheel laser aligned, I had a tracking issue when I bought my S3 and took it to get 4 wheel laser aligned and it had heavily worn uneven because of camber aswell as tracking. Got two new tyres sat here waiting untill my next visit to be fitted to be laser aligned again as well as some other work.
    Avus Silver 2002 S3 BAM purchased Oct 2012
    Work Done To Do
    • Full Service
    • Sump and Pickup Clean
    • Rocker Cover Gasket
    • CV Joint Replaced
    • Top Mounts
    • New Rubber
    • Front stock ARB rear R32 ARB
    • DS Ball Joint
    • Haldex Service
    • Rear wheel arch bodywork
    • B5 Tip
    • Relentless DP and Sportscat
    • Custom Remap
    • RNS-E Install
    • Refurb Alloys
    S3 Paul's Avatar
    Oct 2006
    2,764
    I would say it can be camber or tracking.
    Is the car low?
    I used to get bad tyre wear on the inners of my S3's fronts
    I had the tracking done but was told the car was soo low the adjustment for the chamber ( bottom ball joint to wishbone bolts) couldnt correct it.
    So i sourced a second set of wishbones and moddified them to allow for enough adjustment to get the Camber angle back within factory spec ( just)
    I would get both tracking and camber checked when you have the new tyres fitted.
    Noggy Blue 2001 S3
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Too much camber and/or too much toe out for your driving style. get an alignment done and ask them to reduce both by .5 Of a degree or so, perhaps 1 Degree. wear like that can also be amplified by worn bushes/topmounts
    Sep 2010
    498
    I had the top mounts replaced along with new dampers and springs about 6 months ago. The MOT last month mentioned front bushes (can't remember which off the top of my head) as an advisory so will look into getting these done. I think i'll have the camber, tracking and toe in checked. I would like them to set it up as parellel toe if possible. I know the tracking needs done as it pulls to the right when the wheel is central.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    If you change bushes or make ANY change at all to the front suspension be it ride height adjustment or whatever you NEED to get alignment checked... any adjustment to height throws the toe out...
    Quote Originally Posted by doublem_1 View Post
    ...I know the tracking needs done as it pulls to the right when the wheel is central.
    If you already know this then this thread is pretty pointless... this is why your tyres have worn dude...
    <tuffty/>
    Birdy likes this.
  1. Inside Tyre Wear?
    By tyrrelll in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th November 2011, 16:04
  2. Hi all i have a MAYOR issue with inside tyre wear...Need help URGENTLY..
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th September 2011, 18:37
  3. 2nd Service, Rear tyre, inside excessive wear
    By giblets46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2008, 10:50
  4. Inside tyre wear on -40mm lowered C5 A6
    By evomaster3000 in forum Handling
    Last Post: 26th March 2007, 16:48
  5. Rear tyres wearing on inside edge
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th February 2007, 19:35
