Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: propshaft centre bearing
    Jul 2012
    59
    hi all
    has anyone had the centre bearing\bush fail or get noisey? it would appear the replacement propshaft i got has either has a knackered centre bearing\bush or joint? is it something that can be reconditioned ? looks like a rubber mount around the outside of the prop or does it have a bearing ??
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Welly had issues with his... all the parts are available from a dealer... I think he changed a rubber doughnut (new from a dealer) and git a second hand prop to replace the rest IIRC...
    Centre joint is just a CV type joint which is available from a dealer too
    <tuffty/>
    Jul 2012
    59
    might even just remove prop and leave it fwd poxy thing.
    Jul 2012
    59
    is there specific way of way of making sure all is correctly alligned?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    I don't think the parts were that expensive from memory... if looking for a 2nd hand prop, the TT ones are shorter from the CV to the rear... dunno about R32 props... they 'should' be the same length as the S3
    <tuffty/>
    Big Bang Yam likes this.
    Jul 2012
    59
    cheers tuffty!going to get up in the air and exam the joint, possibly take the joint apart and make sure its greased etc!
  1. centre support bearing propshaft
    By ms1083 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th August 2011, 10:27
  2. Quattro propshaft centre mount ?
    By Jonion in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th July 2010, 12:17
  3. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
  4. RS4 copies - centre caps
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2003, 19:01
