AH FabricationsSky Insurance
Results 1 to 8 of 8
    Sep 2010
    498
    Engine under tray
    Since I've had my car (2 years) it's been missing it's under tray. With all the recent cold, salty conditions, it made me think about buying one with the new side pieces and attach it. Do you think an under tray is that important?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    No.
    .Ben.'s Avatar
    Nov 2012
    Guildford, Surrey
    114
    I don't think mine's got one and it still looks immaculate under there!
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    389
    What's one of those? :P
    2000 Plate Audi S3 1.8T Santorin Blue - 261.0BHP - 255.1LB/FT on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
    Sep 2010
    498
    Ok, I take it it's not too important then. The side trims (that the under tray attach to) were falling down a while back so i removed those as well.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    The side pieces and undertray serve two main purposes... one is to act as a sound deadener the other to protect the underside of the engine from stuff that will lead to corrosion...
    Power steering pipes tend to suffer (tbf they do with the stuff in place too) but I still have all the underside covers fitted and I reckon it helps keep my bay pretty clean...
    Each to their own at the end of the day but if you haven't got them they are not cheap IIRC to buy form a dealer.... the undertray alone was over 100 quid from memory
    <tuffty/>
    Sep 2010
    498
    Cheers for the heads up tufty, there are some full kits on the bay of e for around the £60 mark. I'm tempted.
    Jun 2010
    Quote Originally Posted by doublem_1 View Post
    mine has just arrive today got it from the seller named Nerobart tryed haggling with him and manged to get mine for 55£ thats all 3 pieces + fitting kit gonna try and get my mechanic to fit it this weekend.
    back ground : when i brought the car the middle bit was missing, it was on my TQS previously aswell. however one of the side bits has been bent and grounds out on most things so was planning to pull it off until we had all the snow, and i saw it in the road on a return jurney so stopped and picked it up! however it was the drivers side which was the good side! so the bent panel is still bent and attached but have twisted it up higher now so it wont be an issue for next couple of days i hope!
    but will reply as soon as i get it fitted and let you know how well/easy my guy finds it! ( no instructions included btw) along with golf aero wiper arms that arrived!
    Ben
  1. Under Tray's from the USA
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th October 2009, 15:31
  2. Engine Under tray needed
    By d4mo in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th May 2009, 21:25
  3. Under tray+ front bumper wanted.
    By SMITH MEISTER in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd July 2008, 19:22
  4. Under tray
    By sfs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2008, 17:07
  5. Under tray (Engine)
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2007, 13:45
