AH FabricationsSky Insurance
Results 1 to 30 of 30
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Traction control problem after a hit and run! *added pics*
    Hi guys, Happy New Year!
    Just before xmas, someone hit our S3 on the back passenger side. Took the rear bumper out and hit the passenger rear wheel / panel.
    they scarpered! left us stranded!
    Ive just replaced the bumper/light today and drove for the first time since the accident. There are a couple of issues.
    Tracking is out... centre of steering wheel has to be at 10 o'clock for the car to drive straight! is this something bent on the rear pass side at back? would this affect the steering direction? impact was no where near the front wheels
    and next.. taking off in 1st gear always sends traction control loopy! abs flashes and all power is cut! this only happens in 1st gear. It does clear after about 10 seconds..
    can anyone help with the cause of these issues? I hope so, we are gutted they hit us and ran! need a bit of help/luck!
    Dave
    2001 AMK Dolphin Grey S3
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,358
    the bent wheel will be causing it mate.
    Often when you change components on the suspension like track rod ends and the like, if you set the tracking too far out, the scrubbing of the wheel alters the wheel speed on a given corner to such an extent that the traction control sees it as wheel slip and interferes.
    If something on the rear end is bent to a similar degree from the impact I have no doubt the ESP would do exactly the same thing.
    I'd imagine if the passengers rear wheel was hit, it'd be toe out to require the steering wheel to have some left lock to go straight, as the whole car will be crabbing.
    Get an alignment check and it'll almost certainly show up as rear left toe being miles out.
    Not sure how toe is controlled on the back of an S3, but I'm sure of our 4wd friends can advise
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Thanks Prawn.. i'll get an alignment booked up asap. If say something was bent.. what would be the most common component?
    hoping its just knocked the tracking way out, but best to be prepared to replace whats needed! Ive hd a look under but cant see anything untoward.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    My bet will be on the flimsy tie arms... there are 2 attached to each hub, take the wheel off and you can see by eye if any have bent, it may be hard to see just looking under..
    Whats the damage on the rear panal? could it have gone into the suspension turret?
    ohh and pics...??
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    Yep, from what I've seen of S3 rear suspension I'd definitely be looking at the tie bars first. As Prawn says, it'll probably be towing out loads because of the impact.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    for the tracking to be out something would of bent, as said above check the visual components for obvious damage. i9 guess the car crabs a little and that's why your steering wheel is out.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Tie bars, stub axle, suspension arm... any of that could be the issue ... ESP and ABS will be playing up due to the steering wheel being off centre... the steering position sensor expects the wheel to be dead straight when driving straight... it knows this because the abs sensors are reporting the same speed... if you turn the wheel the ABS/ESP expects to see a speed difference between the sensors now due to the steering angle... with the wheel out of whack its out of its calibration range and silly things happen as it thinks the wheels are spinning when they are not... this triggers the ESP...
    Get the bent stuff unbent and the wheel back inline then all will be good in the world
    <tuffty/>
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Just been out and taken the wheel off (its COLD!)
    i took a load of pics... and had a good look around.
    I couldnt see anything bent. Perhaps you guys can?
    (I fitted a brand new bumper and tail light hence why damage doesnt look too bad. Wing dented and wheel scuffed where the other car hit me)
    Wing damage
    wheel off .. its a but grubby under there! but all looks straight...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Could be the perspective but the bottom tie bar looks bent up a tad... that will throw camber and toe out a bit... might look like a an old Mini crabbing down the road from behind..
    <tuffty/>
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Is anything adjustable on the rear suspension that could have been 'knocked out'?
    I really thought the front had been affected.. I didn't realise that a knock on the rear wheel would affect the steering position so much!?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Quote Originally Posted by Schlaag View Post
    Not in std form no... if the rear is out of alignment then something is bent... or worn... but normally bent...
    <tuffty/>
    Sep 2005
    Derbyshire
    180
    Is it just me or does the wheel look as cambered as a lowered A3 / S3 without adjustable tie arms?
    http://i256.photobucket.com/albums/h...B48599464B.jpg
    Looking at the coil springs you have fitted, I would guess your car isn't lowered and the camber certaintly makes me suspicious something ain't right.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Quote Originally Posted by Blackcupraa View Post
    Suspension is all standard
    The top of the wheel deffo seems to tuck in more than it does on the other (non impacted) side
    So basically no point in getting an alignment done until I locate what is bent!
    Basically something is definitely bent and nothing can be adjusted because nothing could have been knocked out of its setting, its all unadjustable
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Sorry to hear about the accident mate It does look like your wheel has lots of camber on it very similar to mine after I had my new lower suspension fitted. I took my car to a proper wheel alignment specialist and he managed to adjust the rear camber on my car so its almost right now on my standard tie bars. So there is defo some adjustment that can be done to both the toe and the camber on the rear wheels which of course in the impact may well of been knocked out of place.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Plus they would be able to tell you when doing the alignment if something is bent or not too. The guy I got my alignment done with was really good as I took my subframe off the car about 2 weeks after getting the alignment done and he only charged me £20 to redo the front for me.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Quote Originally Posted by vrbob View Post
    Hi matey. Ah ok, that sounds promising... forget my last post then. Ill get it to a proper laser alignment outfit!
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Cost me £60 for the full alignment and of course got a nice printout telling me the difference between before and after. Defo worth a shot before you start buying bits
    Sep 2005
    Derbyshire
    180
    As per VRbob's post, i'd take it to a monkey garage who charge a tenner for tracking and see what they say, if it's out, spend the big money on a hunter alignment etc.
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Quote Originally Posted by JudderMan View Post
    Yeah there's a **** load of camber on it. The pic with the wheel off from behind the car looking at the suspension if you look at the angle of the damper it's cantered in loads and whatever that's called that it's connected to is bent.
    Tufty...the old Mini rotten subframe crabbing
    (edit, must type faster)
    This pic mate? are you referring to where the lower part of the shock mounts
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Yep, that's the pic. Maybe it's my eyes but it looks bent or twisted even. If you look at the lower end of the shock it's twisted in a little - I don't mean the other thin bar that is cantered inwards to the right of the shock.
    This is what I mean Traction control problem after a hit and run! *added pics* | Awesome Screenshot
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Gotcha! (nice screen shot tool!)
    I'll jack the rear up on the diff and take both rears off... see what doesnt match up to the OK side!
    Nice spot mate
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    I actually deleted the original post as I doubted myself but after putting it in the screenshot (Google Chrome addon) it looks like it. Interested to see what the other side looks like now
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Those are typically at a slight angle anyway... they are not straight on as std...
    <tuffty/>
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    bugger!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    The bottom arm does look look like it has a bit of an arch to it, The trailing arm is slotted too and could have been forced too one end?
    Going by the pics i cannot understand how the steering has gone like it has? is there a chance in the shunt, the front wheel was forced into the curb?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    I think at this point you should be taking it for an alignment check mate tbh...
    <tuffty/>
  28. #27
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    Not really Dave... As I turned in to a lane on my right side... the other guy came steaming round a bend, slammed his brakes on and as i pulled in to my right turning.. his nose smacked in to my pass wheel, bumper end (took bumper off) .. oh then he did one!
    I wasnt spun.. luck he just caught my tail end really rather than a full on shunt in to my side!
    Nothing hit my front. I agree, its strange my steering is so off!
  29. #28
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    291
    riiight... Had a hnter alignment and car no longer crabs.. and drives straight.
    Toe adjustment is maxed on the suspect side and is still out. So looks like stub or whole arm is bent slighty. Without spending untold on replacing parts, we will never track the problem down... I can live with the slightly increased tyre wear that side... Its 99% better
    Still the EBS issue though.. but I can press esp and turn it off if annoying.
    Just need to get it through its MOT now.. reckon it will fail on headlight level...
  30. #29
    May 2012
    RETFORD, NOTTS
    1,753
    Looks to me like the hubs bent where the shock mounts to it. Also the ESP issue could be a damaged ring/sensor from the same shunt. If the aligner has just adjusted out the crabbing, has not a good enough fix imo. They should have found the root of the problem.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  31. #30
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    As above something has been bent and subjected to stress that it wasnt designed for, adjusting things to almost right is potentially risky as the bent or damaged component could fail with catastrophic results, if it was my car I'd want to be finding the root of the problem and replacing any bent or damaged components with either new or good second had parts. Some things are just not worth compromising on with IMHO.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
  1. esp/traction control problem
    By lobs84 in forum TT/TT-S/TT-RS Forum
    Last Post: 19th March 2009, 11:48
  2. Traction Control Problems
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th October 2008, 19:39
  3. Our B6 bashed, hit and run
    By mikeswagon in forum Rants & Raves
    Last Post: 6th October 2008, 19:06
  4. Traction Control Problems
    Last Post: 5th September 2008, 11:44
  5. Oil Sensor + Cruis Control Problems (after new ECU)
    By griffin1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2006, 09:35
