Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Sep 2005
    Derbyshire
    180
    Haldex fault code 00526
    Hi guys,
    Just scanned the AWD on VCDS lite and came up with 00526 - Brake Light Switch (F): Implausible Signal. Looking at the possible symptoms it doesn't sound like it should and yes, I have Brake lights when pedal depressed.
    Would this prevent the Haldex from working on my 1999 Audi S3?
    I've driven the car and when I tried to come up the driveway on a small patch of ice (the rear wheels were on snow) and it sounded as though the front passenger side diff was grinding (maybe transfer box). The car refused to go up the drive unless I rolled back and then got traction on the fronts to get me over it.. SHould the rear wheels have "activated to help me up?
    Note the driveway is not steep by any stretch of the imagination, it's as steep as a stepped curb, roughly 5 degrees I would imagine for about 2-3 feet then level.
    Essflee's Avatar
    Mar 2008
    2,007
    My car keeps throwing this fault too, from reading up on various posts people are saying that a faulty break light switch will knock the haldex off, the break lights still work but the car thinks its breaking so only runs fwd.
    Mine is intermittent which hasn't caused to much off a problem, if your struggling to get up your drive which isn't steep then I'd change the switch over.
    You should pull up pretty much any hill with snow if the 4wd is working correctly. With all this snow I've actually been looking for hills and roads with lots of snow, lol
    revo'd
    Sep 2005
    Derbyshire
    180
    Where's the switch located?
    Edit: Always Google before posting, engage brain before typing!!!!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    There is an updated brake light switch that stops the intermittent fault...
    Sep 2005
    Derbyshire
    180
    Just read upteen posts on VWVortex, SCN, ASN etc and seems to be conflicting information.
    In order to fit this, does the Brake pedal have to be fully depressed or not?
    Gizmo20VT's Avatar
    Jun 2012
    289
    I need to find this info, But AFAIK you have to press the brake pedal before logging in to the Haldex on VCDS.
    Edit: From Ross tech is says Auto gearbox's however if I do press the pedal before logging in I do not receive the error
    00526 - Ross-Tech Wiki
    Sep 2005
    Derbyshire
    180
    Quote Originally Posted by Blackcupraa View Post
    Anybody got any ideas?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Implausible signal is a code normally meaning the controller doesn't understand the 'data' its receiving from it...
    As for your code....
    00526 - Brake Light Switch (F): Circuit Malfunction
    Possible Symptoms
    MIL (Malfunction Indicator Light)
    No Brake Lights
    Possible Causes
    Wiring and/or connections faulty between Brake Switch, Brake Lights and/or ABS Controle Module
    Brake Light Switch (F) damaged
    Brake Light faulty
    Fuse(s) faulty
    Possible Solutions
    Check wiring and connections
    Replace Brake Light Switch (F)
    Check / Replace fuses(s)
    Check / Replace Brake Lights
    Check Brake Light Switch (F) in ABS Measuring Block
    Special Notes
    FAQ 2.7. Many Automatic Transmission Control Modules will show a DTC 00526 or 17087 that indicates a faulty brake light switch. This can be ignored and will not appear if you press the brakes once before checking for Fault Codes.
    Possible Causes
    Wiring/Connectors from/to Brake Light Switch (F) faulty
    Possible Solutions
    Check/Repair Wiring/Connectors from/to Brake Light Switch (F)
    Check/Replace Brake Light Switch (F)
    Check Measuring Value Blocks (MVB)
    Special Notes
    ...have changed loads of brake switches as they seem to fail fairly regularly... might be worth changing it or at the least check the Haldex plug by the diff as these are known to corrode
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    The new type switch has no ratchet feature and just turns and locks in place.. 5 mins and done..
    Sep 2005
    Derbyshire
    180
    Thanks guys, switch is here just need to fit it.
    I haven't checked the plug but had no issues when it was serviced recently. I'll jack it up and check over the weekend, snow dependant of course.
  1. Haldex ECU - Fault Code J492
    By Jonay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2011, 16:26
  2. Replies: 3
    Last Post: 18th October 2011, 13:06
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
