EM TuningAH Fabrications
Results 1 to 13 of 13
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    intercooler outlet size
    Hi guys i no there is a lot of information in the intercooler sticky which i have read from start to finish, but i have chance of an intercooler measuring roughly 760x240x76 but it only has 57mm inlets and outlets!
    Main question is would this be adequate for a ko4 hybrid (which is my plan in the near future) or not?
    Matt
    BRING ON THE WET WEATHER ​QUATTRO FTW
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    Do you know what the cooler is rated to.....? I would say 63 or bigger would be better... But I'm no expert.... I'm sure someone else will come along to verify...
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    I have been told 600hp but you no how some of these people just make figures up! I was thinking 63mm but its at a good price and outlet are under headlights :-D
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    It's wether u'd get the pipes to fit with the extra length of the Intercooler, and if theres room behind the bumper as the common upgrade is 600mm long iirc..
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    @ s3 clarke, Yes i have already said it would depend on fitment i just didnt want to buy it if the 57mm outlets was no good for a hybrid etc. :-(
    Jul 2010
    Teesside
    933
    I have just bought the Ahfabs V2 because it was not an option to loose my fogs.... I know people have used Wellycooler and done it also.... I think Bill is doing one now with the Wellycooler.... Mounting it upside down.... The S3 Gringo.... Don't know prices though...
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    Well this is very similar where as the inlet and outlet run under the headlights above the crash bar.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    Anything smaller than the standard cars boost pipes is a dumb idea. You should be looking for 60mm+. I personally run 63mm piping, as many do, some use 76mm.
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    Yes well i suppose that puts it into prespective a little bit more superkarl.
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    823
    Re: intercooler outlet size
    Is that so you can keep the fogs or will they still fit with 76mm?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Wellycooler is 600x300x76 for reference... I would say 700 wide is going to be a bit too wide, 57mm is a bit too small... the Forge and AH V1 use 51mm inlets but that was back when there wasn't much choice about...
    AH V2 is 63mm inlets, larger surface area and more rows than the V1 and not much more to buy so if looking for something like that then the V2 is a no brainer but Bill has been using the toyo/welly cooler in a fair few applications now and can mod them to fit pretty much anything... recent applications being a TT, Leon Cupra and S3... the 'Gringo' is £250 IIRC but worth dropping him an email or phone call to confirm..
    <tuffty/>
    AVLO's Avatar
    Mar 2012
    Doncaster
    255
    Cheers for the advice tuffty i was always going to stand by my word and get the ah fabs v2 but my mate who is breaking his 440hp golf asked if i would like his ic so i just wanted to see what you guys thought about it.
    Looks like it will be the v2 :-D
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Quote Originally Posted by ShaunS3 View Post
    youl never keep fogs with 76. With 60-63mm you deffo can.
    OP, id put money on the 760mm measurement of the cooler being overall width, not core width, its prob a 600mm core. Its not a bad size, 60mm shorter than a wellycooler. Inlets and outlets can always be modified too.
  1. k04 hybrid intercooler piping size and cooler
    By peterg60 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2012, 22:34
  2. pd 130 intercooler hose size
    By andrew-247 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2012, 19:57
  3. Sizes for the standard side mount intercoolers?
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2009, 09:53
  4. Intercooler sizes...
    Last Post: 6th October 2008, 19:32
  5. intercooler sizes
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2004, 19:22
