Volks AutosMonster Motorsport
Results 1 to 16 of 16
    Apr 2012
    Wiltshire
    164
    Air/Fuel ratio gauge
    Been looking on the internet at a few and came across this one on ebay. Has anyone got one of these? And if so any good?
    http://www.ebay.co.uk/itm/3006346529...84.m1423.l2649
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    Not heard of them but looks pretty cool...
    <tuffty/>
    Apr 2012
    Wiltshire
    164
    <tuffty/>
    I know you can get loads of add ons for it
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    Quote Originally Posted by Dan s3 audi View Post
    PLX Devices | Wideband O2 Air Fuel Ratio - PLX Devices
    So I can see.... EGT etc for it too... interesting if nice 'reassuringly' expensive ;P
    <tuffty/>
    Apr 2012
    Wiltshire
    164
    <tuffty/>
    Well as my ecu would not show any faults if it starts running lean etc i think i might invest in one of these. Where is the best place for the 02 sensor to go on the exhuast? could i get away with fitting it under the car rather than in the tight space of the engine bay. I have no cat on the car.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    Ideally need to be close to where the current one is... issues with moving it further away are it will suffer more from moisture in the exhaust (this is why Bill warms the car up under load to get the exhaust hot enough that moisture is not going to damage the probe in the tail pipe for the dyno), potential air leaks from the 2 bolt flange join that will dilute the readings (will look leaner than they are) and you also need to fit the probe at a certain angle... incorrect angle and moisture will kill off the probe...
    Oxygen Sensor Installation Issues (Tech Edge)
    Sorry to say but the best place to fit it will mean yo need to remove the DP for the boss to be welded
    <tuffty/>
    Apr 2012
    Wiltshire
    164
    <tuffty/>
    What a load of work lol how about the liquid gauge you have on your car. Does that not just plug into your ecu and can it read the air/fuel ration off that?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    Yes but... as you don't have a wideband lambda anyway it will still not read on WOT... to know what AFR is on yours then sadly wideband gauge or a wideband ECU conversion... conversion will need a complete new map though... they are very different between the ECU's
    <tuffty/>
    Apr 2012
    Wiltshire
    164
    <tuffty/>
    Guage it is then
    lovemelongtime's Avatar
    Jun 2012
    Horsham
    335
    Question
    Hi Dan,
    I used to run a NGK AFX AFR Kit on my standalone setup, very very accurate (air-fuel ratio (AFR) from 9.00 to 16.00), this was integrated into the map.
    http://www.ngksparkplugs.com/products/performance/afx.asp
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,355
    I run an AEM Uego wideband gauge in mine. Like it very much
    Apr 2012
    Wiltshire
    164
    Quote Originally Posted by lovemelongtime View Post
    Hi Dan,
    Looks like a good kit that, just need to sorce out where i can get a gasket for my down pipe from where it joins the middle section as its a diffrent exhuast to the original (as i will need to remove the down pipe to get a boss welded on). How would i go about finding out what gasket i need?
    Jun 2012
    Horsham
    335
    Hey Dan,
    I would suggest taking a picture and seeing if any of the lads on the forum can help out? To be honest fella, the gasket may be ok?
    Apr 2012
    Wiltshire
    164
    I have re-used the gasket a few times now adding a bit of heat proof silicon but it always has a slight blow to it.
    Jun 2012
    Horsham
    335
    Picture me thinks?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    This the 2 bolt flange of a relentless DP? don't use a gasket... the supplied ones are crap... use high temperature sealant
    <tuffty/>
  1. Air fuel ratio
    By and32 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2009, 19:08
  2. Fuel Consumption Gauge?
    By bachamp in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2007, 09:41
  3. Air fuel ratio meter
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd September 2007, 20:29
  4. AIR-FUEL
    By vw754 in forum Diesel forum
    Last Post: 31st March 2007, 09:06
  5. AIR-FUEL
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2007, 08:47
