I presume you own an S3 right? If just a lowly A3, then I'm out!
You just had the tracking done and not 4 wheel alignment? I'd check tyre pressures first to see if they all match up, then look and see if all tyres are matching brands on the same axle, as in matching tyres on the front and matching tyres on the rear of car. It could be a camber problem, which tracking does not measure or adjust.
Checked the front suspension arm bushes? front bush is voided, rear bush should be solid but have been known to be voided... if these have excessive wear then this will pull the car all over the place regardless of tracking...
hummm... as prawn says... subframe could have been dropped for a clutch change or something and not realigned once done... caster will be affected as this is technically a fixed value so if the subframe is off square then this will throw it all out.. need to undo the subframe bolts to get that back in...
Rear camber could be a broken spring... rear toe seems excessive too...
