Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    729
    Cable or Electronic Throttle Valve on my AUM
    Car details in my sig. As above, is mine a cable or electronic throttle valve? Or how do I check?
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    My previous AUM engined A3 1.8T was fly by wire, no cable, I think it's the earlier engines that had cables.
    Imteyaz.
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    729
    Thanks buddy, so would that mean it's runs on a ME7.5 1mb?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by JudderMan View Post
    Yes... AUM are ME7.5
    <tuffty/>
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    821
    Add Vex182 on Facebook
    Easiest way was to just look at the throttle body and if there is a steel cable on a pulley coming from it then that would have solved it You will just have a plug on the side and no cable.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Jun 2012
    Aberfeldy,Scotland or Antrim, NI
    144
    Or turn the ignition on so the dash lights display. If theres one next to the tacho that says EPC then its fly by wire.
    2002 Nogaro Blue 8L Facelift S3
    WTB. Concert CD player unscratched (8L0035186G)
    Heater control unit unscratched (8L0820043H)
    Headlight switch. (
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    729
    Quote Originally Posted by Arnie013 View Post
    Cheers everyone I'm fairly sure it does have an EPC light and as Tufty says all AUMs
  1. 17705 prersure drop between turbo and throttle valve p1297
    By melon454 in forum General Technical / How To
    Last Post: 23rd February 2012, 00:05
  2. 17953/P1545/005445 - Throttle Valve Controller: Malfunction
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2011, 17:36
  3. throttle valve faulty
    By BENEVA in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2010, 08:58
  4. 1.4TFSi Electronic Recirculation Valve
    By vanaaken in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th May 2008, 21:25
  5. faulty throttle valve
    By JR6 in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th March 2008, 19:20
