Volks AutosChris Nott
Page 1 of 3 123 LastLast
Results 1 to 40 of 112
Like Tree3Likes
Thread: I stripped my Forge DV down as i wasnt sure if it was leaking... Advice needed please
    S3 Paul's Avatar
    Oct 2006
    2,759
    Well after reading Jardo's thread about the Forge DV and that its prone to leaking boost i thought as mine had been on a while i would try the bubble test...
    Basicaly i used a bike pump to preasurise the DV as instructed by Jardo... after just one pump there was bubbles leaking out of the bottom. Bad news...
    So i stripped it down to check the insides.
    This is what i was faced with...
    Sorry for the quality... iphone
    The ring at the bottom of the piston is clearly worn but could it be lapped out with grinding paste method,
    There is next to no wear on the inside of the DV body,
    the marks on the side of the piston... is this damage or how they come?
    the spring looks a little battered? or is this fine and not something to worry about ?
    Thanks for any help.
    Paul
    Noggy Blue 2001 S3
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    Lap it in with paste, and as tuffty has been recommending, use a green spring with a shim.
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,905
    Visit 16Klappe's Instagram Channel
    Hmm, so with pressure in the top nipple and the side port it leaked quite readily. Sounds bad.
    As SK and myself have instructed a valve grinding dowel and some valve grinding paste to re-face the piston in the body will be the best idea.
    Did you use grease on the o rings rather than light oil as I said? Sometimes they can cause the valve to stick slightly.
    A green spring and a shim (to lower the cylinder volume) should be enough.
    Dare I say it...Try an OE valve.
    I quite often say I'm going to do things.
    Then never do them.
    S3 Paul's Avatar
    Oct 2006
    2,759
    Quote Originally Posted by 16Klappe View Post
    so... Slowly lap the piston in against the body ?
    bottom face obviously , then before refitting I need to buy a green spring and a shim?
    with any luck I will be picking up a standard DV tomorrow if its not faulty I will fit that,
    Noggy Blue 2001 S3
    S3 Paul's Avatar
    Oct 2006
    2,759
    Am I right in thinking its the " valve tuning kit"
    I need from forge?
    Noggy Blue 2001 S3
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,070
    you need a forge service kit, which consists of 2 o-rings and some grease, then some generic lapping paste and a stick with a suction cap on the end.
    The bit you need to lap in is the conical end of the piston. You can see the mark on yours where it has been making contact with the seat.
    On a fully lapped piston, that band will be a full 4mm wide to show it's making complete contact with the piston seat and sealing fully. A narrow band suggests it's not well fitted and highly likely to leak.
    Try lapping it in well, and also if it's got the hexagonal top try sealing up the side port where it scews in as well, they often leak from there.
    S3 Paul's Avatar
    Oct 2006
    2,759
    Thanks,
    the O rings look fine, I've checked them for any damage.
    Is the side port just screwed in?
    i didn't want to try and force it , seal it with? Silicone on the threads? Ptfe?
    i will lap the piston to the seat in the morning .
    deffo a shim and new spring?
    Noggy Blue 2001 S3
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,070
    if the top it hexagonal, then yea, the side port is screwed in.
    Tough to say what to seal it with, I've not done mine yet, and I'm certain it'll be leaking!
    Lap the piston until you've got a clear and clean 4mm seat the whole way around.
    I run a yellow spring and shim with my hybrid, seems perfect. Just try adding a shim to yours with the yellow spring.
    When you fit the shim, I used a little sealant on the bottom of the shim on mine, to totally seal it off from the cavity that remains below the piston, just to ensure the chamber volume is reduced.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    999
    I'm i bit confused about all this lapping the piston stuff....lol
    Wouldn't lapping the piston make it harder should he need to renew the piston at a later date ?
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,905
    No.
    Eventually he would need a new piston...But that would take decades.
    Then never do them.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    999
    No.
    But wouldn't the paste also grind away at the body of the valve or am i looking at this completely the wrong way ?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    The bottom of the piston is what youre lapping with paste, it needs a good seal, lapping it with grinding paste ensures a uniform seal all the way around.
    Compare it to the lapping of valves in a gead, and the seal between valve and valve seat, needs to be bang on all the way around.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    999
    I'm currently using a baily dv30 but I've got a 007 on its way.
    It will probably be clear when i take it apart....lol
    Sep 2006
    Sunny Suffolk
    550
    So grind out the line shown on the second photo to 4mm wide?
    Does anything need to be done to the band caused by O-rings shown in the first photo?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,070
    Quote Originally Posted by vanilla_ice View Post
    BANG ON Somebody gets it
    That line as seen on Pauls, is where the sealing is occuring against boost pressure.
    On Pauls it's a very thin line. On mine after lapping, it's a full 4mm thick seat
    A3-Lee likes this.
    S3 Paul's Avatar
    Oct 2006
    2,759
    I've just had a quick go at lapping the piston.
    out of interest are we looking for a fully dull 4mm? Like you would a valve in a cylinder head?
    ive tried to remove the side pipe but to say its tight is a massive understatement ,
    Noggy Blue 2001 S3
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,070
    yes a nice dull band paul.
    Is your valve a hex top or round top? Only hex top ones are removable I think.
    S3 Paul's Avatar
    Oct 2006
    2,759
    It's hex topped . I can see its threaded but without damaging it by clamping the pipe in some soft jaws I don't think it's going to budge too easy,
    i will give it another go when I venture outside ,
    i used a little rough paste to make a start on the seat I've just cleaned it down before I swap to fine ppaste the band is now 4mm but has a few lines from the rough paste...
    Noggy Blue 2001 S3
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,070
    Sounds good mate. it's a huge difference compared to your first pic isn't it? The two faces are very very closely machined, but obviously not perfectly.
    Bigger the seat the better the seal
    S3 Paul's Avatar
    Oct 2006
    2,759
    Well...
    just tried it with bubble test...
    bubbles galore , out of both the end and the thread on the side,
    great news... Not
    i just hope that the standard valve is available today and that its not split,
    big asks I know for a Sunday but I need the car for the morning
    Noggy Blue 2001 S3
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    Hmm, so with pressure in the top nipple AND the side port it leaked quite readily. Sounds bad.
    Is this how you tested it Paul?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    <tuffty/>
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    Well after reading the same post as the op, I can confirm I have taken my round headed 007 off my s3, checked the piston for leaks with the pen trick, finger over the nipple job, and the piston just drops back down. Great news! I've just put the oem dv back on, which I think I'll be leaving on as that was spot on no leaks etc. Also... My forge dv has a blue spring.. I brought it second hand and never checked it, just put it on, until recently with all these dv posts I've realised they have a few different springs and need servicing every so often. What do u suggest? My car is basically standard and if I play with it, will only be going to the 270-280bhp mark. So for hijacking, just didn't want to raise a new post for the same issues. Cheers.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    S3 Paul's Avatar
    Oct 2006
    2,759
    I beleave so... i used this...
    to put equal air preasure to both the SIDE and to the TOP small fitting.
    The valve leaked straight away with only 1 pump of my cycle pump,
    Is this correct or wrong?
    I cant see a second pipe going to the top of the DV on the video tuffty posted???
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    In fairness the ECU is pretty intelligent... as its a load based ECU it can cope with minor leaks by increasing boost as compensation... load based ECU's don't have 'boost' tables... they alter boost to achieve the requested torque from the driver... this is why you see higher boost levels during the summer than during the winter as the ECU requests more boost to compensate for the less dense air to meet the torque request...
    What this means in real life is that the small leak that some of these valves have won't have an adverse affect on performance... no leaks are better but for the most part (unlike some of the chinese copy valves I have seen) its not going to change your life...
    <tuffty/>
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    Gave it a quick clean, used cutting paste on all the worn marks, regreased it and put it back together, this time the valve drops a little then holds. Think I will stick either a green or a yellow spring in which ever is recommended on a standard 225, with new o rings and either try it again or if I am happy with the oem valve I will sell the forge.
    willowsdad likes this.
  28. #27
    S3 Paul's Avatar
    Oct 2006
    2,759
    Well... I fitted an oem valve ( that passes the pen test) and now the car will spike round to 22 psi but drops to 15 psi every prolonged pull?
    duff valve?
    car fecked?
    im sick of this car, it's always something
    Noggy Blue 2001 S3
  29. #28
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    999
    <tuffty/>
    I don't suppose you have a how to lap the forge valve video do ya ....lol
  30. #29
    S3 Paul's Avatar
    Oct 2006
    2,759
    When lapping in the piston seat did people use the o rings to centralise the piston? Or just allow it to self centre ?
    Can somebody confirm how I tested the valve was right?
    i asked a few times and tried to read all the threads...
    Noggy Blue 2001 S3
  31. #30
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Connect the alloy bit of your tester to side inlet of the DV (one that sees boost when fitted the correct way round) and then the blue tube coming from the side of your tester to the vac inlet on the top of the DV... pressurise through your valve as normal...
    The side port should undo on the newer 007p's... I used thread lock initially on mine but still leaked... so then I used 100deg c silicon... all good now
    <tuffty/>
  32. #31
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,905
    Push the piston of the OEM valve up and place your thumb over the top nipple. Look through the side port and see if the seal drops.
    If it drops it is ****ed, if it stays firm it should be fine.
    Then never do them.
  33. #32
    S3 Paul's Avatar
    Oct 2006
    2,759
    ah,
    well it holds vacuum,
    It doesn't hold fully open but it doesn't drop all the way. When I remove my finger it snaps shut,
    is the forge DV repairable ? Or is it beyond messing about? It leaks with the "pen test" and drops to about 4 mm from the bottom until I move my finger.
    Noggy Blue 2001 S3
  34. #33
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    its always going to drop a little.. Normal..
    Air is compressable.... and flip side of the coin is its als "Stretchy" so the drop is the DV's internal volume being stretched until its pulling a vacuum to hold it... hence the movement.
    you will notice a stock DV hardly moves down on its pen test as its internal volume above the diaphragm is smaller than on a forge.
    forge do a service kit.
    o rings and grease.
    bill@badger5.co.uk
  35. #34
    Whoever does not try, does not learn.
    Feb 2004
    Surrey
    191
    The Forge 007 DV (blue spring) is great, had mine for around 10 years. I service it every year, using engine oil (I find using the red grease dries up to quick) and never had any problems. There’s instructions up on the Forge website that shows how to maintain and leak the DV.
    Audi S3 (52) 265bhp Revo Stage 1
  36. #35
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    blue spring? does it open at all?
    bill@badger5.co.uk
  37. #36
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,905
    My valve used to operate "well" with a blue spring.
    Then never do them.
  38. #37
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    I dunno... you don't need a stiff spring in the DV... end
    <tuffty/>
  39. #38
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    lols.........
    oh no not again
    "well".......... the well know exacting description...
    hehe
    bill@badger5.co.uk
  40. #39
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,905
    Pmsl.
    Then never do them.
  41. #40
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    999
    Here's a video guide showing you how to service the forge valve (i don't think you should use vaseline to grease it):
    It would be good if someone on here would do a guide on how to lap the piston
  1. S4 avant Parts available after stripping down for rs4 widebody
    By LeeT in forum For Sale/Wanted - Audi Parts
    Last Post: 12th November 2011, 23:21
  2. S4 avant Parts available after stripping down for rs4 widebody
    By LeeT in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd November 2011, 22:16
  3. Forge 007P DV Down To 79
    By DPM in forum DPM Performance
    Last Post: 10th July 2010, 11:22
  4. Forge Split R (Splitter) DV Fitting Help Needed Please!
    By AudiS3Quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2009, 07:00
  5. TT 8N 1.8T 225 Forge FMIC Down To 565
    By DPM in forum TT/TT-S/TT-RS Forum
    Last Post: 12th March 2009, 10:23
