Page 3 of 3 FirstFirst 123
Results 81 to 112 of 112
Like Tree3Likes
Thread: I stripped my Forge DV down as i wasnt sure if it was leaking... Advice needed please
  1. #81
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by vrbob View Post
    So are we now saying that a green spring with a shim is better than the yellow spring in a 007p for stage 2 cars?
    Also is the redesigned piston that forge have released makes the DV operate better?
    The redesigned piston is to fix the leak issue.. seems they have reduced the internal volume a bit too
    There is no need for a stiffer spring as the spring is only used as a return spring not a mechanism for holding it shut... the shim is to reduce the pistons internal volume making it faster to react and the green spring should be all thats needed for the valve to operate normally... this is relevant for the older design but arguably not so much on the new design...
    <tuffty/>
    Last edited by <tuffty/>; 24th January 2013 at 11:18. Reason: Edited... getting my facts straight... thanks Dave :)
  3. #82
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    The redesigned piston is to fix the leak issue.. its internal volume hasn't changed that much..
    <tuffty/>
    Did you see the pics? it has greatly reduced the Volume.... there is no need to shim it trust me...
  4. #83
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    I didn't notice but I can see what you mean... use of a shim still stands if using a previous version of the piston though...
    <tuffty/>
  5. #84
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Cool well will see if forge send me the redesigned piston and then I will give it a service put the new piston and swap back to the green spring
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  6. #85
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    <tuffty/>
    Yeah its almost flush with the spring seat now..
  7. #86
    Sep 2006
    Sunny Suffolk
    552
    I can see Forge getting a lot of emails about this. vrbob, are you expecting to pay for a new piston?
  8. #87
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Before everyone has a panic.... this...
    In fairness the ECU is pretty intelligent... as its a load based ECU it can cope with minor leaks by increasing boost as compensation... load based ECU's don't have 'boost' tables... they alter boost to achieve the requested torque from the driver... this is why you see higher boost levels during the summer than during the winter as the ECU requests more boost to compensate for the less dense air to meet the torque request...
    What this means in real life is that the small leak that some of these valves have won't have an adverse affect on performance... no leaks are better but for the most part (unlike some of the chinese copy valves I have seen) its not going to change your life...
    <tuffty/>
    <tuffty/>
  9. #88
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Quote Originally Posted by vanilla_ice View Post
    If I can then yes that is what would be ideal, There is a link to the service kit which can be found here Forge Motorsport | Alloy Fabrication its £15
    But I am going to see if I can get just the piston FOC as this is the re designed bit and probably the only bit I really need as such
  10. #89
    S3 Paul's Avatar
    Oct 2006
    2,764
    Dave, from the picture it looks like the seal is trapped / secured in place by the end of the piston that looks to be screwed on from the screw head i can see inside?
    Noggy Blue 2001 S3
  11. #90
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Had a reply back from forge saying I could buy the service kit from them
    They also say that the new piston design is only for the super size DV, is that right as the pic that S3 Dave posted earlier comparing the new vs old that looks identical to my current piston. so have sent them the pic as an attachment to see if that is correct or not.
    Vex182 likes this.
  12. #91
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Ok... the problem here is that while not ideal the design is not an actual failure... I cannot see Forge replacing every single piston they have ever made because it could potentially leak a little... at least Forge have recognised that the design needs improving and have taken steps to do so...
    Forge valves have been around for donkeys years and while I have no doubt there has been a degree of leakage from some of them over the years its never presented itself as a real world problem... I personally think the whole running too stiff a spring thing is a bigger issue myself... I for one was under the impression the springs rate needed to be higher to hold it shut but I realise now this is not the case and have seen it for myself how much using a lighter spring and reducing piston volume can improve the valves overall performance....
    Lets not forget these parts still wear out over time... a lot of the cases where leaking is an issue are probably just down to wear... this is a soft alloy after all... the wear visible on the side of the OP's piston was from rubber o-rings!... it does happen...
    As I have already mentioned a couple of times the ECU will compensate for small leaks and I very much doubt there is any real world performance hit under normal circumstances (this is too subjective to be definitive of course)...
    The service kits are relatively inexpensive and something that needs to be done once in a while... if you have obvious wear and the grease has mostly gone then all you can really expect from Forge is to make sure the service kit contains the latest revision of the piston...
    <tuffty/>
  13. #92
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by S3 Paul View Post
    Possibly Paul, i didnt bother poking around, im sure it will be fine..
  14. #93
    S3 Paul's Avatar
    Oct 2006
    2,764
    Good news !
    Royal mail managed to finaly find my Package from Forge
    So... i tested the Forge DV as it was... ( sorry no gauge as i had to give the correct pump back ) so i rigged up my cycle pump...
    Just to be clear i did locate the clamps correctly before the test was done. i just pushed them on to show what set up i used.
    one pump... Bubbles. as expected, i had lapped the old piston in but either i stopped too soon or ... the Orings had seen better days.
    I stripped the valve down cleaned it completely, Sealed the side port thread ( as this was leaking too on the bubble test ) i used "hondabond" high temp silicone based gasket sealent, when that had cured i rebuilt the valve with the new O rings and piston using the suplied grease as i went...
    Back to the sink to test for bubbles... NONE. as i said i have no gauge to hand today but where the old piston leaked as i finished the first full pump this new set up was holding at three pumps. until the hose i had on the side port blew off.
    In my eyes thats a massive improvement . i retested and left it at two pumps and left it under water... no leaks.
    Everything moves as it should so i know its not stuck but it seals ! thats for sure...
    This is the old piston after i lapped it in... but it leaked far too easy
    This is what came in the kit.
    Many thanks to Forge
    Noggy Blue 2001 S3
  15. #94
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Well done mate
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
  16. #95
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Brucie Bonus
    Got an email form Forge this morning to say they are gonna send me out one of the new pistons.
    So once it arrives I will give the 007p a nice service and upgrade the piston. I will also swap my current yellow spring setup to a green spring and a shim and see how this performs
  17. #96
    S3 Paul's Avatar
    Oct 2006
    2,764
    Brucie Bonus
    I think there is no need for the shim in the new piston. Tuffty mentioned it further up the thread.
    Im running a yellow spring and the car is fine. Now holds bang on whatever boost im at ( say if i put the throttle down and hold it at 10 psi it stays bang on there until i move my foot up or down) it used to drop 3 or 4 psi .
    The "dumping" sound is a crisp "tish" rather than the chatter i was getting.
    Noggy Blue 2001 S3
  18. #97
    RIP S3dave
    May 2004
    nr Glos
    7,176
    sounds like decent progress
    well done all
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  19. #98
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Cheers for the info mate, I have the full spring kit as I bought it off ebay last year. So will stick with the yellow spring and just give it a good service instead when fitting the new piston.
  20. #99
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,372
    Excellent news Paul, Very glad to hear it.
    Now, I must get myself the new piston!
  21. #100
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    New piston arrived this morning, Cheers Forge
    So as I had an hour spare this afternoon I grabbed my service kit (received last year) and stripped down the 007p.
    Took all the o rings out and gave it a good clean all round removing the old (now black) grease.
    once clean I used the nice pink grease on all the clean o rings and re seated them all.
    Gave the new design piston a light greasing and then re-seated that. Don't over grease it it only needs a very light coating.
    All back together with the yellow spring still in place and did the finger test (push up piston, cover to nipple with finger, release piston, it should drop about 5mm and then hold in that position until you release your finger on the top nipple and it should then snap closed).
    Not done any real world testing but will see how it feels during my commute to work tomorrow.
  22. #101
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Swapped my bailey DV30 for the forge 007p and fitted the new style piston today.
    All seems good so far
  23. #102
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    Fitted my oem dv the other day, and went for a proper drive yesterday, what a transformation, boost is so much stronger, my forge must have been leaking bad for a long time. oh well I sold it on eBay the other day and I wont miss it lol
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
  24. #103
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    New piston seems to work well, didn't get much "testing" done on my way to work (damn those other cars on the road)
    But boost seems good so will maybe do some logging later on.
    So if you have a 007p rather than flog it and buy another get yourself a service kit and ask for the new piston as this may well solve any issues you had and maybe forge will help out FOC if not its only £15 to get it back up and running again. Plus servicing the DV is I good idea too to keep optimum operation.
  25. #104
    S3 Paul's Avatar
    Oct 2006
    2,764
    Well thats prety much why i contacted Forge...
    I thought spend on a stock DV to cure the issue ( by removing it ) or see if they could help and to be fair... Yes the DV was pricey when i bought it... but to send me the internals free. Top service and problem solved.
    Noggy Blue 2001 S3
  26. #105
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Exactly, I spent near enough £100 on my 007p and spring kit etc so why not get it running correct rather than sell for a loss and buy another DV.
  27. #106
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    I've got to say this forge valve isn't as loud as my old bailey dv30.
    Not sure if its the new piston or just how these forge valves are?
  28. #107
    Feb 2012
    bedfordshire
    751
    Quote Originally Posted by A3 T View Post
    i find my standard Bosch valve is louder then my old 007 the answer I am looking for is how much can the Bosch take ? as I have a brand new 008 DV that I have not fitted, will I need it for when I get my car mapped ? I have sold my 007 by the way and I am using my Bosch at the mo with no problems I find it better the my 007 to tell the truth
  29. #108
    May 2010
    Bedford
    2,877
    30psi has been tested and held fine.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  30. #109
    Feb 2012
    bedfordshire
    751
    So do I really need the 008 for when I get the car tuned ? are the diaphragms in the Bosch strong enough to trust on a tuned s3 ?
  31. #110
    Feb 2012
    bedfordshire
    751
    Double post stupid iPhone
  32. #111
    May 2010
    Bedford
    2,877
    You dont NEED it no but it`ll outlast the OEM plastic item.
  33. #112
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Just thought I'd say, I recieved my forge piston today FOC! They have been great with service! Thumbs up to them!
  1. S4 avant Parts available after stripping down for rs4 widebody
    By LeeT in forum For Sale/Wanted - Audi Parts
    Last Post: 12th November 2011, 23:21
  2. S4 avant Parts available after stripping down for rs4 widebody
    By LeeT in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd November 2011, 22:16
  3. Forge 007P DV Down To 79
    By DPM in forum DPM Performance
    Last Post: 10th July 2010, 11:22
  4. Forge Split R (Splitter) DV Fitting Help Needed Please!
    By AudiS3Quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2009, 07:00
  5. TT 8N 1.8T 225 Forge FMIC Down To 565
    By DPM in forum TT/TT-S/TT-RS Forum
    Last Post: 12th March 2009, 10:23
