Monster MotorsportChris Nott
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 112
Like Tree3Likes
Thread: I stripped my Forge DV down as i wasnt sure if it was leaking... Advice needed please
  1. #41
    S3 Paul's Avatar
    Oct 2006
    2,764
    Would vasoline work?
    I mean it is a good lube ;-)
    I'm going to lap my piston again tomorrow at work. In the same way I would do a valve to seat on a cylinder head. Would starting with a cordless drill slowly to rough the seat be too harsh? Then finish it by hand,
    I know forge do a service kit but once I've lapped the piston in would a new piston never fit? Or just not needed?
    Does anybody have a spare shim?
    Or do I need to swap to yellow spring too?
    Is the spring you need linked in any way to how/ who mapped the car?
    Noggy Blue 2001 S3
  3. #42
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Paul ive got a shim you can have.
  4. #43
    S3 Paul's Avatar
    Oct 2006
    2,764
    Top banana .
    are they all the same thickness?
    When could I get it?
    Noggy Blue 2001 S3
  5. #44
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Bear in mind that the grease generally used is a silicon based one... this won't damage rubber seals... if you plan to change regularly then maybe it will be ok but petroleum based greases affect normal rubber o-rings which I believe the Forge ones are.. The kits are cheap enough to buy tbh...
    Use a green spring and a shim... the shim goes in first... reduces the volume of the piston (as Bill has mentioned before, air is stretchy as well as compressible) this will help the piston react faster... use a little grease or silicon to seal the shim where it sits in teh piston... use a green spring for the DV... mapping has nowt to do with DV's...
    <tuffty/>
  6. #45
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Yup, think ive got 4 so wont miss them. If you can come through this weekend mate, then. Id say during week but im in manchester for the next 2 weeks mon to fri.
  7. #46
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    forge do a service kit.
    o rings and grease.
    +1
    Also if you contact forge and ask nicely then they sometimes give you a complete kit with choice of spring for free
    If not then you can buy it from forge here:
    http://www.forgemotorsport.co.uk/content.asp?inc=product&catalog=0007
    Of on ebay here:
    http://www.ebay.co.uk/itm/FORGE-MOTORSPORT-DUMP-VALVE-SERVICE-KIT-007P-ETC-/260857498410?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item3cbc518b2a
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
  8. #47
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    It is pretty stiff to push the piston up with the blue spring, but then I've got nothing bar a standard one to compare it too. I put the standard one back on and took it down the road earlier, I recon it boosts better tbh. I got the valve 2nd hand and at the time didn't know you could service them and change springs etc. I'm gonna sell the forge I think.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
  9. #48
    Oct 2012
    140
    This?
    CHEMICO ENGINE VALVE GRINDING PASTE + LAP STICK LAPPING TOOL KIT COARSE & SMOOTH | eBay
    I'm going to take my 008 apart tomorrow and swop the yellow for the advised green and shim.
    I hope the above kit won't be needed, as forge have improved the piston seal on the 008 from the 007. I hope
  10. #49
    S3 Paul's Avatar
    Oct 2006
    2,764
    Well, as advised i dropped forge an email last night at about 10pm,
    this morning i received a reply saying... sorry to hear im having problems and that they will send me a service kit including a redesigned piston ( with a seal on) free of charge, They also said that if i run over 15psi of boost to stick with the yellow spring and see how that fairs.
    I am very impressed with the speed of the reply it was before 9 am! and the offer of free help .
    fingers crossed the forge DV may make it back on to the car in the near future.
    Noggy Blue 2001 S3
  11. #50
    S3 Paul's Avatar
    Oct 2006
    2,764
    Quote Originally Posted by paultownsend View Post
    This?
    That is exactly the same paste and stick i have so yeh, thats fine
    Noggy Blue 2001 S3
  12. #51
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Personally I still think a yellow spring could be a tad stiff... but can't fault Forge on their service... I would still try the green and a shim as a back to back and see how you get on... if they done what I think they have with an o-ring seal on the piston then it shouldn't really need a yellow spring to hold it shut... remember the pressure will be the same both sides of the piston under boost so it should force it open (when fitted the correct way round rather than having boost acting on the bottom of the piston itself)
    Good work...
    <tuffty/>
  13. #52
    Sep 2006
    Sunny Suffolk
    554
    Quote Originally Posted by S3 Paul View Post
    Pics when it arrives please.
  14. #53
    Whoever does not try, does not learn.
    Feb 2004
    Surrey
    193
    Yes it does – based on the sound that I hear when I lift off the accelerator, I get a whooshing sound type noise, when the air is being recirculated. At the time when I bought the DV, I thought it was a direct replacement, didn’t really know about the different spring rates and shims until afterwards. I’ve never had any issues, must be lucky!
    Over the last few years, of not using the correct size allen key, I round the bolts. Asked for replacements bolt parts from Forge, and they sent a replacement kit for free – brilliant service
    Audi S3 (52) 265bhp Revo Stage 1
  15. #54
    S3 Paul's Avatar
    Oct 2006
    2,764
    well i received anothe email about 10 mins after sending my postal address saying the parts would be posted first class today. Realy good service!
    I will post pictures before i build it up. The only thing i need to sort now is something to seal the side port thread. ive removed it and cleaned off what looks like old locktite ,now the question is ... what can i use that i can get localy to reseal it.
    Halfords do a few high temp silicones but which to use as its not listed in the directions
    Noggy Blue 2001 S3
  16. #55
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Use a sump sealent or something.
  17. #56
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
  18. #57
    Oct 2012
    140
    Just purchased a new 710N valve from TPS. Forge 008 in the for sale section soon......
  19. #58
    S3 Paul's Avatar
    Oct 2006
    2,764
    thanks Paul,
    that was top of my little list ,
    a mate has said he uses two silicone based sealers to build Honda engines... Gets it from the dealers,
    He says I can use that , I think after a chat with him and looking the product up it sound spot on,
    i finished lapping the current piston in before I got the email from forge, so I will post pictures of that and the new one the are sending before I rebuild the DV
    Noggy Blue 2001 S3
  20. #59
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    You still want a shim dude?
  21. #60
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Told ya
  22. #61
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    New forge piston...
    Its got a lower seal on the seat, and the surface area inside is greatly reduced...
  23. #62
    RIP S3dave
    May 2004
    nr Glos
    7,183
    seems they're listening
    fair play...
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  24. #63
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Itll be interesting to see what piston design my forge supersize valve is, ill be stripping it down to fit a shim so ill post pics up to see if it is the old piston design of the improved version.
  25. #64
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    New forge piston...
    Looks good but i cant help thinking....
    what if that o-ring comes off ?
  26. #65
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    Quote Originally Posted by A3 T View Post
    Then you're ****ed.
    I quite often say I'm going to do things.
    Then never do them.
  27. #66
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Dani could post a pic of forges supersized dv piston when you get it?
    They've already replaced mine to an updated one already (FOC) but curious if they will be putting some kind of seal on there now?
    The original is the one on the right with the radius and the newer one was with the flat bottom
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  28. #67
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Thabks for that stacey, i now know what spec the piston will be and yeah course i will. How does the top come off? Screw top or allen screw? Also what spring you running?
  29. #68
    Oct 2012
    140
    Fitted a new 710n from TPS today. A lot better than my 008.
    My lump has only a k03 but has a rock steady -22hg vacume. A green spring in the 008 would blow open up to 5 psi then the car would spin its wheels. With the yellow it held better at low boost, dump at light throttle, but would still chirp at certain loads. Shims mad it worse either way.
    710n holds perfect boost from vacume to its now 17psi boost. The new forge absolutely leaked. Great for £120 and purchased as a 'stage 1' must!
    Thanks for the advice bill et all
  30. #69
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Also the new design looks alot better.
  31. #70
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Mines a screw top and running a yellow spring with a shim to reduce volume as I stupidly sold the 007 with the green spring as buyer requested it and I thought I'd never use it
    Anyone got a spare green spring (shameless plug) lol
  32. #71
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Haha what you like. I may be able to help you out with that mate. Ill have to check when im back home friday but ill let you know m
  33. #72
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Quote Originally Posted by 16Klappe View Post
    Then you're ****ed.
    Keep it short and say it how it is
    Maybe we should stick with the old one.
  34. #73
    S3 Paul's Avatar
    Oct 2006
    2,764
    Im prety sure the likely hood of the seal "falling off" has been looked into and tested?
    I wouldnt expect the would offer to send these pistons out to cure a problem if they had tested any and they had fallen off?
    Noggy Blue 2001 S3
  35. #74
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Hopefully they've done more testing than they did on the originals.
    Then never do them.
  36. #75
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    well I contacted forge Monday evening and I haven't had a reply... ooh well the standard valve is back on and I think I prefer it.
  37. #76
    S3 Paul's Avatar
    Oct 2006
    2,764
    Never ever happy FACT
    Noggy Blue 2001 S3
  38. #77
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    So are we now saying that a green spring with a shim is better than the yellow spring in a 007p for stage 2 cars?
    Also is the redesigned piston that forge have released makes the DV operate better?
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  39. #78
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Well mine is back on the car and it feels/sounds a lot sharper...
  40. #79
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Cool will fire off an email to Forge and see if I can get a re designed piston for my 007p then.
    In regards to springs should I stick with the yellow?
  41. #80
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yes deffo as the volume as decreased
  1. S4 avant Parts available after stripping down for rs4 widebody
    By LeeT in forum For Sale/Wanted - Audi Parts
    Last Post: 12th November 2011, 23:21
  2. S4 avant Parts available after stripping down for rs4 widebody
    By LeeT in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd November 2011, 22:16
  3. Forge 007P DV Down To 79
    By DPM in forum DPM Performance
    Last Post: 10th July 2010, 11:22
  4. Forge Split R (Splitter) DV Fitting Help Needed Please!
    By AudiS3Quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2009, 07:00
  5. TT 8N 1.8T 225 Forge FMIC Down To 565
    By DPM in forum TT/TT-S/TT-RS Forum
    Last Post: 12th March 2009, 10:23
