Sky InsuranceEM Tuning
Results 1 to 17 of 17
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Front subframe removal
    Hi guys,
    I can't really seem to find the answer to my question as to how easy/ straight forward is it to remove the front subframe?
    Mine is bent on one side and seeing as my car is off the road at the moment I was thinking of getting a subframe as well as other parts that I need.
    I was also thinking of getting a different anti roll bar as I have seen a 23mm one from a bora that looks like it goes under the driveshafts would this be correct?
    Thanks simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Scullies's Avatar
    Feb 2012
    Dubai
    1,241
    AFAIK its 4 bolts plus the bolts for the steering rack. There might be some other minor bits to loosen though.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,468
    Four 'man' bolts hold the subframe on... you have to undo the steering rack and support it before removing the subframe... its advisable to get the front alignment checked after replacing the subframe as it can move on the bolts...
    Here is a link to when I did mine... its not a how-to but will give you and idea of whats there..
    Subframe off for the lads....
    <tuffty/>
    Jun 2012
    Redhill Surrey
    635
    Cheers tuffty, is changing the subframe something that can be done on the driveway on your own?
    I also want to get a arb that loops up under the drive shafts.
    Simon
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,468
    Anything can be done on the driveway at home if you put your mind to it ;P
    Yeah... big breaker bar required for the bolts... don't remember the torque settings off hand and the Haynes is in the boot of the car... if I remember I dig it out later... I believe its recommended to replace the bolts...
    <tuffty/>
    Jun 2012
    Redhill Surrey
    635
    Cool, ill have to buy a subframe then and collar a mate to give me a hand to fit new one and few other bits, then get it to a garage for a new clutch
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    Grale1 - have you found out why your tracking is out or is this the reason pal. How comes the motor is off the road ??
    Jun 2012
    Redhill Surrey
    635
    No mate I haven't got to bottom of it yet but think it may be related tho as it slightly bent and fitted with crapy wishbones etc, so was thinking of replacing the lot, it needs a new release bearing so getting a new smf clutch set up
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,321
    replace the lot mate, it's actually a really easy job.
    Complete subframe swap shouldn't take any more than 2 hours on a driveway with axle stands and simple tools.
    Unbolt the dog bone mount, and 4 steering rack bolts, then the ball joints on each side, then just undo the 4 subframe bolts and it'll drop right off.
    Drop it off with the wishbones and ARB still attached, and transfer what you're going to use onto the new subframe, then sit the centre of the subframe on a trolley jack and slide it in, then lift it up slowly into position until it's pressed against the body again with a very light force.
    this should allow you enough play to wiggle it about with a screwdriver to get the rear bolts to line up, then once they're located the fronts will just slide right in.
    Jun 2012
    Redhill Surrey
    635
    Cheers prawn, hopefully get round to buying the bits in the next week or so to start, do you know if a arb from the bora goes under the driveshaft?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,321
    Spec for spec, the bora is exactly the same as the A3 mate, so no. it won't.
    Jun 2012
    Redhill Surrey
    635
    Ok, can you recommend one that goes under, as ill be putting one coilovers so don't want it rubbing the arb, and a mate of mine put an s3 one on hers but it looks like it needs Quattro coilovers for the drop links to connect properly.
    Whoever does not try, does not learn.
    Feb 2004
    Surrey
    192
    Did mine last year on the drive way, as I had to replace the clutch. Don’t, like I did, remove the three bolts on the front suspension arms, as this will bugger up your camber. Use ball joint puller, see Running gear, Front-wheel drive and four-wheel drive - ElsaWeb, and you don’t have to remove the suspension arms, like I did, the whole unit can come down, as Prawn had mentioned.
    Have a look at some of the technical documents at ElsaWeb - VAG Audi Škoda Seat Volkswagen Online Repair Manuals to get a rough idea on what to do, and torque settings
    Audi S3 (52) 265bhp Revo Stage 1
    Jun 2012
    Redhill Surrey
    635
    Guys, I still haven't got round to buying a subframe, but I took the car to an independent Audi specialist the other week and he reckoned that the castor is out?? Not to sure what this is, any how as this left hand pull is really starting to get to me and wanting to push on with other things. So I got the tape measure out and from the measurements I took it 4-5mm further forward on the right hand side ( drivers side ) to the passenger would this really have much of an influence? On the pull to the left? So would I be able to adjust the subframe or is a case of getting a new one if its got a slight bend in in?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,468
    There is caster adjustment by moving the subframe but this will also affect camber and toe if not done right and with alignment gear... the amount of movement is limited but is there to allow a little fine tuning... if its out regardless it suggests something is bent...
    Caster angle - Wikipedia, the free encyclopedia
    <tuffty/>
    Jun 2012
    Redhill Surrey
    635
    Cheers tuffty, the subframe, steering rack and driveshafts are the only bits I haven't changed, but there is a difference in the measurements between the two sides, so maybe the subframe might be bent, I haven't a breaker bar at the moment to be able to undo the bolts and try and adjust it. But be best to get this guy to do it and get it aligned from him and see what it's like after
    robloake's Avatar
    Mar 2013
    Hastings
    62
    Quote Originally Posted by Grale1 View Post
    Hi mate, dropped my A3 on coilies recently and the best front ARB to go for is the Whiteline, around £150 from Balance Motorsport, goes under the driveshafts you can then drop as low as you like with no driveshaft rubbing at all.
  1. A3 Front Bumper Removal
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2011, 08:00
  2. Replies: 4
    Last Post: 9th August 2010, 08:25
  3. standard black front spoiler removal?
    By griffj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd January 2006, 22:26
  4. Front shock removal
    By clarko in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 22:48
  5. S3 Front Grill Removal for Lidatek LE-30 Install
    By wizard in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2004, 09:55
