EM TuningJMB Retrofits
    stevegti2's Avatar
    May 2011
    223
    s3 8L koni shock absorber question
    hi i have a A3 fwd and am using a awd front anti roll bar to set on the front quastion i have is
    beetween the s3 A3 quattro 97-99 and A3 quattro 2000-2003 was there any differences in chassis or front strut??
    koni list different shocks for each car wich i dont understand ?
    thanks
    BURN RUBBER NOT YOUR SOUL !
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    I would say pre facelift and facelift...
    phil miller's Avatar
    Sep 2012
    Devon
    843
    A3 Quattro and S3 front shocks ARE NOT the same as Fwd shocks, on front drive the ARB links bolt to the lower arm on quattro and S3 it bolts the the roll bar to the lower spring cup on the shock, if your using s3 or quattro shocks and roll bar set up then you will need quattro or s3 stuff
  1. Koni FSD Shock Absorbers
    By s-line stu in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th January 2008, 22:40
  2. Koni FSD Shock Absorbers
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2007, 06:38
  3. price on Eibach Pro Damper Performance Shock Absorbers
    By nick-barnes07 in forum Awesome GTI
    Last Post: 22nd July 2007, 01:47
  4. Fitting new shock absorbers
    By Ray Marks in forum General Technical / How To
    Last Post: 4th February 2007, 15:32
  5. A4 B5 Rear Shock Absorbers
    By imported_Donald_MacIver in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th April 2006, 22:30
