Chris NottMonster Motorsport
Results 1 to 8 of 8
    Jul 2011
    peterborough
    32
    3" maf senso/housing
    I have got an Agu engine 1.8T a3 (1998) but at the min i running the standard maf sensor but i need to go upto the vr6 one but i not sure what part code is and dont have anymore info on it so was wondering if anyone would be able to give me a part number or info about what be the best place to try get one from?
    thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Need? this because you are fitting a larger turbo?
    Prawn should be able o give that to you if its not listed in his build thread somewhere
    <tuffty/>
    Jul 2011
    peterborough
    32
    yes i need one as already fitted a bigger turbo before realising i would need one
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,079
    VR6 housing part number is 0 280 217 512
    What you need is just the sensor from an OBD2 mk3 VR6, engine code AAA I believe.
    Obviously when changing the MAF you'll need to have the map altered to suit.
    What bigger turbo have you fitted too? as the VR6 sensor maxes out at around 320bhp
    Jul 2011
    peterborough
    32
    cheers i have got a ko3s with k04 internals (a beachbuggy hybrid) but at the min its running 230.6 @ 5669 rpm and 296 ft-lbs @ 3690 at the flywheel but need to change maf, and get a 3" downpipe then get remap tweeked again to see what difference that makes to figures
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,079
    Ah right. Was this the jabba mapped one? Ko4-001 spec?
    at 230bhp you'll probably find your maf total maxed at 187gs. Vr6 maf will suit perfectly
    Jul 2011
    peterborough
    32
    Yes mate it is the same one. Had quick search thru ebay and have found FORD VW GALAXY SHARAN GOLF Mk3 VENTO MAF Mass Air Flow Meter Sensor 2.8L-2.9L | eBay which looks like got spec i want and fairly cheap for new part.
    Now just got track down a decent 3" downpipe and work out if go sport cat or stick with original cat then once that fitted change maf over and tweek remap
    Jul 2011
    peterborough
    32
    Before I go and order the wrong part can someone please check and see if this is the right part I am after thanks.
    VW Golf ACP Air Mass Sensor (MAF) Genuine Low Cost Direct Replacement New | eBay
  1. FYI - MAF sensor housing
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2012, 17:17
  2. MAF Housing Size
    By johnie72 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2007, 18:48
  3. MAF housing sizes??
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th March 2007, 11:00
  4. 2.4 MAF housing diameter
    By mckay9uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2007, 18:15
  5. Larger MAF housing
    By mtsakmakis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2005, 13:38
