Sky InsuranceEM Tuning
Results 1 to 9 of 9
    burns3's Avatar
    Jun 2011
    223
    Bumble stop flashing will ya!
    Right long story shortish,
    Bumbles been sitting outside my parents since i injuried my hand at work just before xmas and havent been able to drive due to surgery and that. Anyway the battery has went flat so my keyfob is not working so you have to go in through the boot as you cant get into the drivers door due to the lock not matching the key for some reason.
    Sooo the car is now open and runs and drives fine but the hazard lights flash for about 4min from when the door opens oh and the fact you have to lock via the boot! Its as if the alarm is going off but with no sound but i have never heard the alarm go off before and welly doesnt think he has too so cant confirm that works anyway so this may be infact what is happening lol.
    As i live over 20mile away from my parents my dad has had a look at it today with this auto locksmith and he thinks the fob is working fine battery and signal wise but was going to have a look into it more and get back to us. Was wondering in the mean time if anyone had any ideas on here as your normally a knowledgeable lot
    Any ideas appreciated people.
    Car is a 2000 s3 if you dont know it.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,325
    does it lock and unlock from the keyfob now?
    definitely sounds like the alarm going off without the siren sounding.
    burns3's Avatar
    Jun 2011
    223
    No mate keyfob doing nothing at all, apart from annoying me.
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    441
    I had the same problem a simply key re sync procedure and its been fine since
    Here ya go
    1. Take the spare key, put it into the ignition and turn the key to the "on" position, just prior to starting the car.
    2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
    3. Exit the car and close the door.
    4. With a second key, physically lock the doors (don't use a remote).
    5. Take the first remote to be programmed, press one of the buttons and the lights will flash once. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed
    burns3's Avatar
    Jun 2011
    223
    Quote Originally Posted by A3-Lee View Post
    Here ya go
    I read stuff like that when i used the search but unfortuantely i dont have a spare key with this car which has me stumped at what i could do without one.
    I may just need to get one sorted from somewhere cos i prefer having a spare anyway.
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    Im in the same position mate, my key fob has stopped working after disconnecting the dash cluster to try and fix my display screen.
    Changed the battery's in the fob but nothing and don't have a spare.
    how to re sync with out a spare key anyone?
    AMD stage 2 map, BBS LM 19s, 20mm Momo Spacers, Black Diamond Discs, Ferrodo ds2500 pads, Milltek Exhaust, Pipewerx downpipe and Decat, Custom FMIC, 4 bar Fuel Pressure Regulator, Forge 007p, Forge short shift, Forge DV relocation ,Forge TIP, S2000 Filter, Sachs Race Clutch, Sachs Light weight Single mass flywheel, ForgeOil catch tank, De baffled Charge pipe & Polished, Polished Inlet Manifold, N249 Delete, PCV Delete, Red Engine Mounts, Forge Boost hoses, Angel Eye Headlights, LCR Splitter,
    burns3's Avatar
    Jun 2011
    223
    Quote Originally Posted by Danny Cawsey View Post
    Atleast you dont have to enter through the boot though!
    Anyone, were desperate lol
    Lewis583's Avatar
    Mar 2010
    870
    Taken straight from Autodata. Vehicle entered was 2000 S3, not sure if it makes a difference though.
    Edit: Just realised, this is no use if your key won't manually unlock the drivers door.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    Quote Originally Posted by burns3 View Post
    haha this is very true, i feel for you mate.
    So by the sounds of it i need to get an other key with out the fob to re program mine?
  1. Is this the part I will need to finally stop my car running rough
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2011, 00:14
  2. will the problems ever stop????????????????????
    By bansheeboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2010, 15:19
  3. Indicator Lights stopped flashing
    By boson in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2009, 12:59
  4. Booked in, yet again! When will this bug stop!
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2009, 10:27
  5. Oh god, will the problems ever stop!? Timing quetion
    By James333 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2008, 21:08
