Badger5AH Fabrications
Thread: Air con problem
    Jun 2012
    138
    Air con problem
    Just went to use my air con in my s3 and it doesn't seem to be working,if you push the air con button the symbol comes up on the display but then goes straight off again,the last time I used the air con was a couple months ago and it was working,is the problem more likely to be to do with the control box with the display or could it be the pressure switch under the bonnet
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    My guess is it needs to be checked for leaks.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It wont work if the ambient temps are very low like at present..
    Jun 2003
    World of my own
    9,813
    Yes far more likely that its just too cold. If the outside temp is below 5 degrees the snowflake button will not work
    Alex Turner
  1. Air Con Problems
    By WAL4D in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 21:39
  2. Air Con Problem: Slothlike coldness
    By hyperaudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2006, 08:44
  3. Air Con Problem
    By Quattro_Lew in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2006, 21:54
  4. Air Con Problems A3 1.8 T Sport
    By jester104 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2006, 14:15
  5. Air Con-Problem
    By Jason in forum General Technical / How To
    Last Post: 22nd May 2006, 13:41
