Volks AutosSky Insurance
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By s3clarke
Thread: Help needed ASAP please. Possible coil pack failure?
    S3 Paul's Avatar
    Oct 2006
    2,759
    This morning my car lost power and sounds like its on 3 cylinders.
    Im hoping coil pack , Vag com says mulitiple misfire?
    Is the safest way to check which if any coil pack has gone to have the car running and unplug the injectors one at a time? hopefully one will make no diffrence to the engine note ??
    Is this the easyest way?
    Please help as car is stuck at work.
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    if its misfiring on idle pull the injector wiring plug off one injector at a time... if the engine note doesn't change then thats the bad cylinder
    <tuffty/>
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    Could also be a spark plug
    Once you found which cylinder is not firing, swap coil packs around and check again
    S3 Paul's Avatar
    Oct 2006
    2,759
    Thanks people,
    It was a coil pack,
    Number 2,
    Ive asked Audi if they still honour the recall. Im waiting for a reply.
    The coils were all genuine but ive had to just stick a BERU one in to fix the outstanding problem.
    Noggy Blue 2001 S3
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    The RS6/TT hitachi "e" bolt downs are said to be the most reliable, if Audi don't replace yours. Mine have been sound for 18 months.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,063
    the bolts downs seem to last people fairly well on S3's.
    Amazingly, the 3 wire bolt down BERU oem coilpacks were still going strong on the track car at 216k miles, having never blown one from new, I know of several 200k+ AGU's all running their original coils.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Yeah a VW specialist mate of mine says he's never changed an AGU coil pack. He also said I should keep the bolt downs and not bother with TFSI ones. I think it's like these s2000 filters. Going from old tired parts to new ones is always going to be better.
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    Any news on the recall? Since Audi won't do my corrosion under warranty they can replace my coil packs instead!
    phil miller likes this.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
  1. HELP AND ADVICE NEEDED ASAP PLEASE
    By SOHAIL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th June 2012, 13:34
  2. Help needed asap please.
    By HOTTIGGER in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2012, 12:34
  3. turbo help needed asap please
    By S3featesV9 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2012, 15:19
  4. Adapter help needed ASAP PLEASE
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2010, 00:40
  5. A4 2.8Q Oil pump location needed ASAP Please help
    By markcass in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd October 2007, 10:42
