JMB RetrofitsBadger5
    Mar 2012
    Nottz
    104
    ESP light & steering problem on return from M.O.T
    Hey all,
    I have an Audi S3 2002 AMK almost stage 2 atm. The problem I have is after receiving my car back from having M.O.T being done last week, I'd noticed my ESP light was on. I attempted to switch it off from main traction unit, nothing happened. I also noticed my steering wheel was slightly out when the wheels are centred.
    I had taken my car back to garage, to the mechanic, who had taken my car to the M.O.T Centre around the corner. He will have a look at it later on today hopefully.
    I've read up on the possible problems it could be with ESP traction light..coil pack or spark plugs might need to be change. I hav'nt got round to do this yet since modding car last year & I have a custom remap stage2 booked in at R-Tech this Wedesday. Would It be best for me to sort this before hand & any ideas about my steering wheel??
    May 2012
    RETFORD, NOTTS
    1,753
    Has he pranged it while out on the road in it without you knowing?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    If the wheels are straight and steering is not then someone has changed something, unless it was like that before and you didnt notice.
    Ask if they removed the steering wheel for any reason. If they did you will need to reset the steering angle sensor.
    When I bought my car, the sensor was 180deg out and I coudnt turn the ESP light off.
    You will need Vagcom to reset it
    Remove the steering wheel, adjust the sensor to 0deg ( check vagcom measuring block for the read out ) becarefull not to turn it the wrong way as I have heard that if you turn the sensor too many times, something will break on the inside!
    Mar 2012
    Nottz
    104
    Re: ESP LIGHT & STEERING PROBLEM ON RETURN FROM M.O.T
    Quote Originally Posted by @udi A3 View Post
    I wondered to... or whether it woz one of the guy's from m.o.t place but I know if I asked & someone had, I doubt there admit it.
    Mar 2012
    Nottz
    104
    Quote Originally Posted by Scullies View Post
    Yeh 100% it wasn't like that when I had my car before hand, I will ask them later if they did need to alter steering at all. I'm hoping it can be sorted 2day before my remap 2moz.
    Nice1
    27,126
    The slip ring, if turned to many times can be pulled out of its connecions, but this only happens when 2 situations are current, 1st the steering column lower bolt is not connected to the rack, so it doesnt have a stop point or someone has moved the slip ring by hand & not centered it, so its already fully locked 1 way or other when wheels are actually straight, so turning it further pulls wires out, so doubt its this, unless they've removed the wheel & messed about or the column was undone at bottom.
  1. ESP light, Airbag light and yellow steering light
    By craigs3tdi in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th July 2012, 10:27
  2. Steering Angle Sensor - ESP light (FIXED)
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2012, 07:18
  3. Problem with esp light on dash...
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2011, 15:34
  4. Battery died and now have power steering light and esp light on ?
    By bradus in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2010, 14:46
  5. power steering & esp light came on after i washed car???
    By trailboss in forum General Technical / How To
    Last Post: 20th June 2010, 21:05
