JMB RetrofitsVolks Autos
Results 1 to 20 of 20
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    540
    Fuel smell in cabin
    Hi guys,
    Had a search, but couldn't find an answer to this question for this vehicle. S3 8L APY.
    Recently I'm sure I can smell fuel in the cabin. Only seems to happen after maybe 15 minutes of driving, and usually when I've been driving and then stop at a set of lights etc. the smell is strongest; then when I drive off it kinda dissipates, but I'm sure I can smell it and I'm not going crazy
    Just wanted to know, should there be anywhere I should be looking at first to see where fuel could be leaking and I could be getting the smell? Any particular hoses? The injectors? Fuel filter?...dunno. I haven't seen any wet patches under the car and I usually have the air-con on (reading around I see this can affect where the air is sucked in from, so affects whether I would get a smell or not) but given the cold weather sometimes the air-con doesn't work.
    I admit I've currently got the car for sale, but I'm getting this fixed before I accept any offers as i'm not selling it when I think there could be an issue!!
    Thanks guys,
    Aran
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Check the evap canister pipes under the cover, if these hoses split there is a strong petrol smell...
    Jun 2011
    Great Melton Norfolk
    1,356
    Could try changing the Pollen filter, they tend to get neglected and block up.
    Feb 2012
    Surrey
    540
    Thanks guys. Where under the cover is the EVAP canister? Also, would a crummy pollen filter smell of fuel?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Its by the coolant bottle under the cover..
    Feb 2012
    Surrey
    540
    awesome, thanks buddy, i'll check tomorrow after the drive to work and see if anything like the EVAP lines are rotten / smell of fuel
    May 2012
    RETFORD, NOTTS
    1,753
    Pollen filter makes weird smells, change it anyway for a few quid :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Feb 2012
    Surrey
    540
    yeah, may as well
    Feb 2012
    Surrey
    540
    Hi guys,
    Popped the bonnet this morning and couldn't see any fuel leaks anywhere or even smell any to be honest :S I'll drive her until I can smell it, then i'll try to pull over and check again then
    Oct 2011
    760
    same problem, injector seat seal top one, 5 quid audi.
    Feb 2012
    Surrey
    540
    alright, i'll check the injectors, thanks
    May 2012
    Manchester
    229
    post back how you get on mate, ive got exactly the same problem but everytime i have a sniff round the injectors, rail and charcoal canister i cant smell anything. The only times i do is when i pull up at a junction. weird
    Feb 2012
    Surrey
    540
    very weird...least it's not only me!!
    Feb 2012
    Surrey
    540
    Hi guys,
    An update. Don't think it's coming from the injectors, had a good face in the engine bay sniff However, i think it's coming from around the washer bottle, as I can smell it from there! So, that means EVAP chamber?...
    Thing is I can't see any physical fuel or wetness (which I guess I should be grateful for). So any ideas which pipes / connectors to check / replace?
    Thanks guys!!
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    I had a very similar problem on my pre-facelift S3. The smell would only come in when I was stopped in traffic. I noticed of I turned the climate control totally off then the smell was much less pronounced.
    In the end it was traced to a faulty (split) fuel breather pipe. I can't get you the part number out the service history for you to check because I sold it 4yrs ago. I do remember putting a post on tyres mike about it so I'll see if I can find it.
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    I found the post but I didn't put the part number in it, just the cost which was back in Nov 2006. Maybe it might help you but the part cost £8.16 and when under pressure fuel was leaking from a broken fuel breather pipe. This pipe was bought at an Audi garage and they fixed it free of charge because they diagnosed the fault initially as the charcoal canister, which when replaced didn't fix the problem.
    May 2012
    Manchester
    229
    Quote Originally Posted by s3mad_dude View Post
    which pipe is it? might go check mine now. Hopefully explain my 22.5mpg
    Jan 2013
    I had the same problem .... Only bought the car last week, strong smell of fuel from engine bay .... Split breather hose that runs off the rocker cover .... £18 later no smell and a happy owner!
    chris99's Avatar
    s3 driver
    Dec 2010
    54
    Same problem here, can smell it around the charcoal canister but would have to remove it and check under, if better weather next week.
    Audi S3 8L
    OZ Superleggera | Bilstein B14 | BMC CDA | K04 | FMIC | SACHS Race Engineering | Brembo Sport GT | EBC Redstuff
    Live to drive, drive to live
    Mar 2011
    24
    I have had the same prob with my 1.6 a3 sport 1997 AEH now changed to AKL,
    I am servicing the car this weekend and ill check the above points,
    Exact same symptoms - only when pulling up at junctions strong smell of fuel,
    STRANGEEEE
  1. HELP!!!! Fuel smell in cabin
    By Jine in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th June 2012, 23:18
  2. Fuel smell
    By S3 Nattie in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2010, 08:35
  3. Fuel-Type Smell in Cabin
    By biyitch in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2010, 14:38
  4. Fuel smell
    By 666markyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2009, 13:46
  5. Fuel Smell
    By satanmademedoit in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2008, 12:47
