Badger5EM Tuning
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Pabl0
Thread: New Feature: Anti-hi jack
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    We are pleased to announce another new feature for all ME7.x ECU's
    The new Anti-Hijack feature works as follows:
    if the car is started as normal, it will drive normally for 30s after which the throttle will become unresponsive. The engien will not stall or cut out, but there is no power available. If engine is turned off and back on, the 30s timer does not reset, the pedal will remain unresponsive.
    In order for the system not to activate, the driver has to perform a procedure to disarm before the car is started involving pressing of the pedals. The combination is unique. Disarmament is signalled on the dash.
    Additionally, for cars with a rear 02 sensor which is no longer used, this can be connected to the door switch. The idea is that when a door is opened, the system rearms. This ensures the system is active if you are forced out of your car with by a hi jacker. They will get a safe distance down the road, and be forced to abaodon the car when the throttle no longer responds.
    The feature is available as an option to our custom maps.
    Thanks, Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    Would you be able to add this to mine when i come back with the bigger injectors please?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    May 2010
    139
    Sounds great, only problem = the Mrs.
    It might aswell be quantum physics.
    turnstyle likes this.
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Interesting adding more features to the ECU, but I don't see much point in this particular feature.
    Is it not potentially dangerous for the car to just run out of power after 30 seconds? Like, someone borrows the car, pulls out onto a roundabouts and the car stops? Obviously you'd have to explain to people the code etc. but if they don't bother with the code and think the car works then it stops it could be an issue...
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Scullies's Avatar
    Feb 2012
    Dubai
    1,255
    Quote Originally Posted by Andrew@A.L.D View Post
    And new cams
    There some 3652 cats on vortex up for grabs ATM
    Jun 2009
    Leeds
    3,470
    Quote Originally Posted by Scullies View Post
    And new cams
    I think Piper are going to replace them
    FOR SALE
    Jan 2012
    Stockport, Cheshire
    748
    Quote Originally Posted by Aaron TDIQ View Post
    With anti hijack you are limited to what you can do and not have your car disappear. It's not a feature for everyone, but something we've done before for people so there is demand. You can disable it permanantly if you are lending your car out. I have had countless cars cut out when mapping due to blown hoses etc so I'm not sure it's that dangerous in practice. Probably safer than the theif driving flat out to get away as quickly as possible.
    Rick
  1. S3 8L brand new front anti roll bar
    By stevewushu in forum For Sale/Wanted - Audi Parts
    Last Post: 10th November 2011, 16:10
  2. Brand New front Anti Roll Bar S3 8L £60
    Last Post: 8th November 2011, 17:54
  3. Anti-Car jacking device on the new S3
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd October 2006, 23:21
  4. Activating anti hi-jacking door locks
    By Bongo163 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2006, 11:56
