Chris NottJMB Retrofits
    Gizmo20VT's Avatar
    Jun 2012
    289
    LCD Display not working, Possible to View on Vagcom?
    Hi Guys
    I just wanted to know if there is a way to see what your LCD on your cluster is displaying on Vagcom, Mine needs replacing but I would like to see what its showing error wise when I turn the ignition on.
    Thank you.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,430
    You can't view it on VCDS, you can test the DIS screen output I think, but if you scan the car, it will show any faults anyways.
    Gizmo20VT's Avatar
    Jun 2012
    289
    Im not getting any fault codes, its just annoying when I put the ignition on, get the beep and cant see what the warning is.
    Will try some small checks on headlights next, perhaps a faulty bulb.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,430
    Quote Originally Posted by Gizmo20VT View Post
    At this time of year, it's probably the frost on ground warning. Is it just blinking yellow, and you can't make out what it is?
    Gizmo20VT's Avatar
    Jun 2012
    289
    Its the lower half of the LCD that warns about bulbs and so on, I doubt it would be the frost warning thou :D its about 35 degrees here currently in south africa, could it be anything related to self leveling on the headlights?
  1. Replies: 0
    Last Post: 14th January 2012, 12:28
  2. display on dash not working?!?
    By supanova in forum General Automotive Chat
    Last Post: 4th February 2011, 22:08
  3. mileage and trip display not working
    By Rutter in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2009, 22:28
  4. LCD Display In Dash Has Stopped Working?? Can Anyone help??
    By A3EDDIE in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2008, 13:26
  5. Replies: 0
    Last Post: 25th January 2007, 19:50
