Chris NottSky Insurance
    Sep 2012
    West midlands
    368
    Fuse 28 melted?????fuel pump!!!!
    Can anyone shed some light, I have an Audi s3 8l 2003 model I had my turbo off today when I put it back on I decided too pull fuse 28 for fuel pump too prime turbo but the fuse was not blown but melted I changed it and car started ok fuse didn't get hot or melt as yet,what could cause this any ideas?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    It will most likely be because its drawing too much current... this is typically due to it being put under a heavier load than normal... I'd replace your fuel filter if you haven't already... it could also be a sign the pumps on its way out...
    Also check your fuel trims... if they are quite a high additive value on LTFT's then check the FPR vac pipe is in good nick...
    <tuffty/>
  1. PLEASE HELP. Fuel pump fuse keeps blowing! A3 1.8t 1998
    By gniknotle in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2012, 12:57
  2. S3 Fuel Pump Fuse: Car Broke down!!!
    By cagiti in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2011, 19:35
  3. fuel pump fuse keeps blowing?
    By Karlos the Avant in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2009, 13:55
  4. best place to buy a late coupe fuel pump
    By lazzaman in forum Classic Audi Forum
    Last Post: 25th November 2006, 21:48
  5. Fuel Pump Noise
    By europabluea6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th September 2003, 18:15
