Sky InsuranceVolks Autos
Results 1 to 7 of 7
    Stutibs's Avatar
    Oct 2012
    Fleet, Hampshire
    50
    Should dis auto reset?
    Hi all, I'm still trying to sort out my radio-dis problem but don't know where to start, it the dis info (average mpg, time elapsed, average mph) supposed to automatically reset when you start the car? If not can it be turned on to do that?
    Also I have had the radio out and checked canbus wires does anyone know what power I should have?
    Also I have a canbus code on vagcom for radio and cluster so I am inclined to think wiring fault? Has anybody ever fixed this, I have done a search across the web but as soon as someone posts this problem up it gets avoided like the plague.
    Many thanks to any help given
    May 2012
    RETFORD, NOTTS
    1,753
    My DIS only resets when holding the reset button on the bottom of the stalk on each statistic you wish to reset.
    What was the readings and codes from vagcom?
    What year is your car? Mine is 02 and has no canbus.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Stutibs's Avatar
    Oct 2012
    Fleet, Hampshire
    50
    For instrument the code is:
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 P
    Component: KOMBI+WEGFAHRS. VDO D07
    Coding: 00444
    Shop #: WSC 10001
    VCID: 40897C0E40A2AD1861C
    WAUZZZ8L321001069 AUZ7Z0A1883224
    2 Faults Found:
    01304 - Radio
    49-00 - No Communications
    01311 - Information Data Bus
    37-10 - Faulty - Intermittent
    For radio:
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8L0 035 195 H
    Component: symphony II NP2 0005
    Coding: 00201
    Shop #: WSC 01236
    VCID: 336323C201140680ECE
    1 Fault Found:
    01336 - Data Bus for Comfort System
    37-00 - Faulty
    Stutibs's Avatar
    Oct 2012
    Fleet, Hampshire
    50
    Here you go, thanks
    Stutibs's Avatar
    Oct 2012
    Fleet, Hampshire
    50
    The weirdest thing just happened. I went out to my car, to find the radio backlit (never since i've owned it has it ever lit up) even though the car was off and locked. Turned it on and backlight went off and not come back on. What on earth is going on with my car?!
    Stutibs's Avatar
    Oct 2012
    Fleet, Hampshire
    50
    Avoided like the plague again. I assume either no one knows or no one wants to help.
    Oct 2012
    Telford
    95
    Unless its a problem people have had before it is very hard to diagnose the problem and solve especially over a forum.
    I would would take a punt and say find someone with vagcom to do some tests to see if that sheds some light failing that something funny is going on with the electrics so speak to some garages (maybe even Audi)
    My DIS is the same as above and only resets by holding the reset button on the info you want to reset.
    Avus Silver 2002 S3 BAM purchased Oct 2012
    Work Done To Do
    • Full Service
    • Sump and Pickup Clean
    • Rocker Cover Gasket
    • CV Joint Replaced
    • Top Mounts
    • New Rubber
    • Front stock ARB rear R32 ARB
    • DS Ball Joint
    • Haldex Service
    • Rear wheel arch bodywork
    • B5 Tip
    • Relentless DP and Sportscat
    • Custom Remap
    • RNS-E Install
    • Refurb Alloys
  1. Revo Stage 2 Overboosting and random auto-resets on highway
    By Golfer1991 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2012, 19:44
  2. What should I expect from the 1.9tdi (130) CVT Auto?
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd February 2009, 12:15
  3. Resetting DIS
    By Macduff in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2007, 18:44
  4. Auto check symbol on DIS - what does it mean?
    By jcs356 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2005, 23:21
  5. MOVED: DIS, Clock, etc reset itself again A3 (8P)
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2004, 22:44
