Page 1 of 2 12 LastLast
Results 1 to 40 of 49
Like Tree1Likes
Thread: project ASBO audi a3
    Mar 2012
    96
    Welcome to my Project
    audi a3 1.8t 20v
    only mods it has so far are a set of kw coilovers
    and a s3 rear bumper ( but i dont like it as it dont fit to well)
    so this is how i got the car
    i then fitted fmic and relocated the dump valve
    Mar 2012
    96
    next job i fitted a piper exhaust system
    Mar 2012
    96
    next i fitted a techedge wideband
    and then come along was my emerald k6 aftermarket ecu with 3 maps with plug and play plug
    Mar 2012
    96
    as it sits now its running 190 bhp and 240 lbft , on a worn out k03 turbo
    next week should see my gt28 71r arrive
    Mar 2012
    96
    how it sits now
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I like this build,look forward to seeing it progress
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Nice. Why have you swap the oem management over though?
    Mar 2012
    96
    reason 1 , i dont need a maf , so i just use tps vs map
    reason 2 , i can do alot more with after market ecu such as
    Adaptive Lambda control: Self learning fuelling capabilit
    Adjustable speed and load sites
    Closed Loop EGT control
    Tailor boost curves
    Map switching
    Diffrent boost in diffrent gears
    i can change every single setting in the ecu , i dont have to pay some one to plug vag com in to see for any problems , or change settings
    it really dont cost that much to do , and its easy to use and understand and best of all its plug and play
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,063
    Visit 16Klappe's Instagram Channel
    ALL of that can be done on ME7.
    I quite often say I'm going to do things.
    Then never do them.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    Yes, well done Jardo. This car doesn't have me7, and it'd cost just as much to convert to me7 as it would emerald, I know which I'd choose.
    Looks cool mate, nice to see a different approach. Had you got any more details about this plug and play emerald setup? Does it retain the stock ecu to run the clocks and things? Is it genuine standalone? Or more of a piggyback affair?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    This is interesting stuff. I used to run an emerald ECU on my old Lotus Elise so I'm interested to see how this turns out on an 8L.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,380
    I've seen an emerald ecu on a blue lotus x reg think it was that was more of a piggy back ecu for the 1.8 turbo engine fitted. Retaining standard clocks ect.
    Looks interesting build , something different.
    Sean
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by s33nyboy12 View Post
    Sean
    The lotus ecus were dreadful and a piggy back still didn't give many tuning advances. They needed an emerald and some decent cam pulleys to fine tune them.
    S3 Build Thread
    Mar 2012
    96
    Mar 2012
    96
    its fully standalone , you remove the bosh ecu and have an adaptor that plugs to your std loom and plugs into the emerald , every thing works except the mpg thing on the dash and one little thing controlling the dbw for idle , there finishing off the software for that so , i just fitted an idle screw
    also atm they only have a plug and play loom for an agu with 3-pin coils ndbw
    Mar 2012
    96
    Sean
    there 100 % standalone , emerald ecu works with can bus system so all the clocks work in a lotus
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Quote Originally Posted by jonno123 View Post
    That sounds very cool indeed mate! I have an AGU with 3 pin coils so that's not an issue.
    Is emerald able to do anything like launch control or similar? I take it it controls boost via the standard N75? Does it have knock control as well like the stock ECU? What sort of cost are you talking for the ECU and plug+play loom all in?
    Sorry for all the questions! It's nice to see someone doing something a bit different for a change!
    Mar 2012
    96
    yes use is the stock n75 , you can have launch control , if you use the map switch and push button so you use one map with a low soft cut and hard hard cut rev limit , and then you only have too maps , thats one way to do it , knock control should be ready soon just waiting for the new software to be realesed , lots more feautures coming too , and should be free , like tc , dbw , turbo timer
    money wise
    ecu cost 595 + vat
    plug and play plug cost 120 +vat
    and map sensor cost 60 + vat
    so it something like 780 plus the vat and you get discount if you say your on here i think like 5% off
    stevegti2's Avatar
    May 2011
    223
    ive got a emerald k6 for my suzuki swift the new ones have a feature for traction control aswell and a few other odds and sods there a great ecu plus being british advice is always there and dave walker is a legend i see why you changed it
    BURN RUBBER NOT YOUR SOUL !
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    I was going to ask if it was still Dave Walker behind it all! He's a bit of a legend in the Mini circles
    Mar 2012
    96
    yes dave still ownes emerald , but he dont map on the rolling road any more , i do , dave runs the engine dyno
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    Aaaaaaaaaaaaaaaaah, and suddenly it all makes sense :P
    Good for you man. Nice to see something other than the usual 'what air filter should I use' thread!
    VAG-Slag likes this.
    RIP S3dave
    May 2004
    nr Glos
    7,167
    Quote Originally Posted by 16Klappe View Post
    but not me3.x
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,167
    mk2 golf here now, on GT35 was on MBE, we have now wired in Emerald.... Not the latest version however.
    the TT I race against runs Emerald.. Works fine. Nice features.. I still like my DTA's however.. The new K6 has better features over its predecessors so I need to review their specs.. They keep developing them.
    www.badger5.biz
    bill@badger5.co.uk
    Nov 2011
    W. London
    63
    Quote Originally Posted by stevegti2 View Post
    Hey Steve did u have a older swift gti (was it wide body turbo?) and were u on the old ukswift forum?
    Mar 2012
    96
    small updates spent some pennies ill let pics do the talking
    after a good clean
  28. #27
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    this has to be one of the Nices 8L's on the forum!.
    What size rubber you running? they look chunky!
  29. #28
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    it's not fair. I WANT A RED ONE!!!!!
  30. #29
    Mar 2012
    96
    Quote Originally Posted by Paradox1 View Post
    thanks its not bad for its age and original paint so win
    205 55 16
  31. #30
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Cool B)
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
  32. #31
    stevegti2's Avatar
    May 2011
    223
    @solja of sensi yes thats me mate the gti in my name refers to swifts not silly golfs and as for dave walker last i heard his health took a turn for the worse but a mate went up there for a ecu and said he was on the up wich is good
  33. #32
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Nice car and mods. Keep it up!! Looks pretty awesome in red.
    Seen this beast in PPC...
    Audi S3 1.9 GT30....
    ....that is all
  34. #33
    Mar 2012
    96
    yes dave health did go down but he is alot better now
    he running the engine dyno will i run the rolling road
  35. #34
    Mar 2012
    96
    so i have been getting lots of bits together so i could fit my gt28 71r here is a few pics
    new exhaust mani
  36. #35
    Mar 2012
    96
    a random one of my dog looking cool
  37. #36
    Mar 2012
    96
  38. #37
    stevegti2's Avatar
    May 2011
    223
    crazy laughing...lol
  39. #38
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    389
    nice bangs
    2000 Plate Audi S3 1.8T Santorin Blue - 261.0BHP - 255.1LB/FT on Custom Parsons Performance remap, Forge 007p DV, Red DogBush, Milltek non-res, Lowered 35mm Apex springs, Badger5 TIP/cone filter/heat shield, Powerflex'd, Large FMIC, Relentless Downpipe, Parsons Decat and lots of love.
    On gearbox number 4.
    Further modification to come..
  40. #39
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    isnt this Wendy's old car???
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
  41. #40
    Mar 2012
    96
    yes it is
    also just give richard his corrado back after doing some work to it
    hope to see you at some of your events Aaron
  1. Audi A3 Project 2009
    By a3-ams in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2009, 00:11
  2. Audi project so far
    By Jayyuk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th July 2008, 22:57
  3. Audi Metroquattro project
    By MarcQuinlivan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2008, 15:09
  4. Audi Metro Project (A1 Concept)
    By abdus in forum You Tube Links
    Last Post: 24th October 2007, 19:41
  5. Audi 80 as donor car for build project
    By larsdahlberg in forum Classic Audi Forum
    Last Post: 23rd July 2006, 19:04
