JMB RetrofitsVolks Autos
Results 1 to 8 of 8
    Feb 2012
    15
    Air motor in the center console - climate control (Look PICTURE)
    Hello everybody,
    My car is a3 8L 1.9/110 2000 year. Im replacing the center console with the facelift one. Ive got an air con unit from the facelift but when i took out my old one i saw that there is something like a motor with a rubber pipe for taking air or something. So i saw that it might be integrated in the new one climate control but im not sure if i should use it or not. There isn't a special place to place it in the new one like the old one. Can anybody tell me if i need that or the new one has it integrated and i should cut the wires and throw it out?
    Thanks in advance
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    I haven't ever seen the pre-facelift climate control unit, but it sounds like it could be to draw air in to measure the temperature for the climate control unit.
    The facelift unit has a small grill at the front with a very small gap to measure the ambient temperature. I would guess it is that but couldn't be 100% sure.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    x2 ^^
    Feb 2012
    15
    Should i cut it out? And use only what is integrated in the facelift climate control unit?
    27,114
    The facelift climate unit has wiring etc changes, its not PNP btw.
    Feb 2012
    15
    I know that. But im asking only about that motor* for the air measuring?
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    The facelift version has an ambient air sensor inbuilt so unless you're fitting the pre-facelift electronics into the new centre console, no you don't need to cut it.
    8L IS DE BEST
    27,114
    Quote Originally Posted by yankov View Post
    Fine then good luck.
  1. the center consoles on!!!! (at last!)
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2010, 22:30
  2. Replies: 3
    Last Post: 13th July 2007, 10:53
  3. Air Con/Climate Control Problem
    By shippy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th May 2006, 17:50
  4. how do remove the climate control unit
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2006, 22:53
  5. Electric motor noise behind center console
    By Kasper in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th February 2004, 13:18
