AH FabricationsChris Nott
Results 1 to 18 of 18
Thread: Running Lean
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    Running Lean
    Hi Guys i put my S3 on the dyno today to see what power it is making and found out it was very low on power and running extremely lean, Any ideas as to what could be the problem? Fuel pump knackered?
    Here are the Graphs.
    AMD stage 2 map, BBS LM 19s, 20mm Momo Spacers, Black Diamond Discs, Ferrodo ds2500 pads, Milltek Exhaust, Pipewerx downpipe and Decat, Custom FMIC, 4 bar Fuel Pressure Regulator, Forge 007p, Forge short shift, Forge DV relocation ,Forge TIP, S2000 Filter, Sachs Race Clutch, Sachs Light weight Single mass flywheel, ForgeOil catch tank, De baffled Charge pipe & Polished, Polished Inlet Manifold, N249 Delete, PCV Delete, Red Engine Mounts, Forge Boost hoses, Angel Eye Headlights, LCR Splitter,
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    checked the pressure hose to your FPR?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    Quote Originally Posted by Alex C View Post
    Yep checked that, seems to be fine.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,056
    Checked the FPR for gunk ?
    It may be a tired pump, i put an inline one in to help out...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    If its a tired pump then an inline pump is not a fix... do you have logs to support the AFR on the dyno graph? need to check requested vs actual... could be the maps actually asking for that AFR...
    Its most likely the pump in which case a new one is required but would need to see the AFR logs from VCDS to confirm...
    <tuffty/>
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    <tuffty/>
    Cheers Tuffty, i dont have logs as i dont have access to VCDS, unless anyone in Bristol has VCDS and wants to log it for me tomorrow?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Might be worth taking a trip up to Bill's then as you are just down the road... J13 M5...
    <tuffty/>
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    <tuffty/>
    I was just thinking that, i also have an oil leak so its prob not a bad idea. Ive got a free day tomorrow if bills likely to have space.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Not sure what his schedule is like but I suspect there would be easily time for a road log if nothing else as it will be evident fairly quickly whats going on
    May see you tomorrow then...
    <tuffty/>
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    <tuffty/>
    Ok then mate ill pop up tomorrow, whats a good time?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by Danny Cawsey View Post
    Best bet is to give Bill a ring just after 9am mate...
    http://www.facebook.com/Badger5Ltd
    <tuffty/>
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    So i went to Bills today and did a couple of runs on the dyno to find out it is the fuel pump that was knackered,
    Cheers Tuffty and Bill for checking my car and nice to meet you both.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,937
    you're welcome
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Gizmo20VT's Avatar
    Jun 2012
    289
    Running Lean
    I have the same problem, saving for oem intank pump... Pretty costly!
    www.badger5.co.uk
    May 2004
    nr Glos
    6,937
    VDO listing at £200 on ECP website currently
    VDO Fuel Pump Part No.: 441441110
    bill@badger5.co.uk
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    Don't you just love this forum ..... great work guys
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    They appear to be doing 20% off too...
    <tuffty/>
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    Cheers guys.
  1. Running Lean and bad Idle problems after remap
    By Ryanmt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th October 2010, 11:26
  2. Running lean?
    By A4-Newboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2010, 11:22
  3. Running lean!!!
    By S4twiggy in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2009, 18:12
  4. A4 Cab 1.8T running lean and over revving
    By blackpool1974 in forum VCDS (formerly VAG-COM) forum
    Last Post: 5th October 2009, 22:35
  5. running lean i think
    By slight_problem in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 12:01
