Badger5AH Fabrications
Results 1 to 7 of 7
    Oct 2012
    17
    ABS pump faulty???
    hi all. I've had my abs light on since I've owned the car, I had it plugged in today and its saying I need to replace my abs module??? But my abs Is working fine?? Any suggestions what it could be or does it generally need replacing?? As my mot is due at the end of the month...cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    What was the actual fault code?
    <tuffty/>
    Oct 2012
    17
    Hi mate, I have no idea I was just talking too him whilst the bloke was doing it and he said that.. Ile have to back and ask for the code
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Hi Sean,
    If you have had your ABS light on since you bought the car then I would be very surprised if your ABS is working at all to be honest. Even says so in your S3 handbook IIRC. I had a lot of problems with the ABS module a couple of years ago....and the garage I used at the time ended up sending it away to get rebuild. Unfortunately mine was beyond repair though and had to get a new unit installed. Also I'm almost certain that if your ABS light is on whilst it is MOT'd then it would fail.
    Oct 2012
    17
    Yeah i know that! It seem to work, when emergency stopping there's no skidding, just pulls up nicely! Theres no funny feelings or hidden noises going on! might be missing summit? How much did it cost you in the end? As need to get it tickled of my never ending to do list..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Fault code?
    <tuffty/>
    Oct 2012
    17
    I'm going back up there Tuesday morning. I will pm you and post the code on here
  1. ABS pump faulty?????????
    By floyd 1.8 turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2010, 08:44
  2. a4 central locking pump faulty
    By Mike B in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th April 2010, 17:07
  3. abs pump wanted
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th March 2009, 19:58
  4. ABS Pump Control Unit
    By jitvv in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2007, 10:46
  5. 8L A3 ABS Pump Fault & Repair!
    By Tallpaul in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th June 2006, 15:37
