EM TuningChris Nott
Results 1 to 9 of 9
    imported_Sem
    Eibach coilovers - any good?
    Does anyone on here have Eibach Coilovers fitted?
    They can go as low as 60mm but I was just wondering what the ride quality was like?
    They seem reasonably priced too.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Eibach coilovers - any good?
    You'll find that they will go lower than 60mm. The quoted values are usually that TUV approved heights.
    My coilovers are approved to about the same, but they go way lower. Not that you'd want to go that low.
    Depending on your car,you may need to get the longer ARB droplinks to prevent driveshaft contact and maybe a set of front spacers to keep the tyre away from the adjustment perches.
    I can't comment on the ride quality as I have FK items on my car.
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    [ QUOTE ]
    [/ QUOTE ]
    Any pics with the coilovers on?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Not got any pics at the mo as I've only dropped it 20mm all round for now. I've not got the new droplinks yet, so I didn't want any drive shaft rubbing issues.
    Handles nice tho at that height.
    I can take some pics if you like?
    The only pics I do have are of before and after painting them to hopefully stop them rusting as I couldn't quite justify the extra cost of the stainless items.
    Before Painting
    After Painting
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    [ QUOTE ]
    [/ QUOTE ]
    Yeah if you could just want to have a quick look at how she looks.
    Looks like you have done a good job painting them though [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    Aug 2003
    Spain
    66
    what about FK coilovers ride quality? i've seen on their website they're selling two kinds Highsport and Koenigsport(200 more expensive). Firsts ones are only height adjustable, but the others have also reboudn adjustability,
    Really i wanted to install KW V2 or V3 but they're too expensive, but the bilstein+h&R(or eibach) combination i don't know if will satisfy me refering to the height, while with FK ones you can adjust them whenever you want and have and reasonable price.
    What do you recommend?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Markb, I'll take some piccies this week when I get a spare moment.
    CaTFISH, I'm perhaps not the best guy to comment on all types of coilovers as this is the first set I've ever bought. I've always had non-coilover kits until now.
    But I will explain what I think of my setup and why I chose what I did.
    I too considered a set on KW V2's or the Konigsports, but I had to stick to some sort of buget (flamin' mortgages!). I first looked at how the different brands stood up to corrosion. There was a very good example at the KW stand at GTI International this year which showed how well many brands did to six months exposure to the elements.
    I worked out that I could go for the more expensive stainless items, but I could also achieve the same protection with a lick of tough paint and and smothering of copper grease on the adjusters.
    Also, on the last few cars I've owed I've bought suspension setups with adjustable damping. On each car, I've fitted the kit, set it up and then never adjusted it again. I don't do track days, so I don't need to constantly adjust them. With that in mind a realised that I was paying extra for a feature I didn't really use.
    As for height, I've done a bit of research into kits for the A3, with the discovery that most, if not all fixed spring kits seem to give a "nose down" stance. While this is fine, it wasn't the look I was after. I need adjustable height as I'm planning different wheels sometime in the future and I've already messed with the height a few time already.
    After reading many threads on the www.uk-mkivs.net forum, it was evident that a large number of people were opting for the FK Highsport coilover. Due to its price and apparent good reliability it seemed to be the perfect choice for me, so I bought a set.
    The fitting was very easy indeed, much easier than other cars I've worked on. I won't go into the details, but if anyone needs info on specifics, just let me know.
    As for the performance, is night and day over the Audi stuff. The factory setup was tired on 120000 mile anyway, but the car is transformed. Yes it is a little bumpy, but nothing like my old MK1 or MK2 golfs and can be easily driven on long distances. I do approx 70 miles a day to work and back and don't find it a pain at all. The damping is set just about right I think. Also body roll is greatly reduced, and I feel so much more confident driving my car round corners now compared to the dissapointing experience before the upgrade.
    So would I recommend the FKs, well yes, but if you are planning to play with the ride height from time to time, then make sure you grease the adjustment threads or at least use the spray that comes with them.
    Hope that helps and I'll stop waffling now :-)
    Aug 2003
    Spain
    66
    hmmm thank you, i've it now more clear, but still don't know how hard it'll be....
    BTW... did you bought it on their website or in some local dealer? Where i live there's a new shop that only sells KW suspensions but they ask 1350 for KW V2... [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I know, its very difficult to explain how hard (or soft) the ride is. Its a very personal subjective area.
    I got my suspension from Awesome-GTI. uk-mkiv members get them for 400 delivered.
