Chris NottEM Tuning
Results 1 to 8 of 8
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,307
    Wiring help please - instrument cluster
    I have a 2001 S3 and need to know which wires going into the instrument cluster are the can high and the can low.
    Are there any wiring gurus out there who can tell me which ones they are?
    Thanks.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    26,720
    I'm about to jump on a plane tbh mate, when I land I'll check for you as I cant remember of top of head lol.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,307
    Thank you Nigel.
    2001 S3 (AMK)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,307
    Did you have any luck finding which wires I need? Or does anyone else know which ones are needed to be spliced into?
    Hoping to have a look today while I'm working on the car
    Thanks.
    2001 S3 (AMK)
    26,720
    Yes sorry been so busy since back, you need to tap into Pin 5 low & Pin 6 high of the grey 32 pin connector.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,307
    Thank you mate. Do you know If the connector block is numbered?
    2001 S3 (AMK)
    26,720
    Numbers are embossed into the connectors.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,307
    Thought they would be. Means even I cannot mess it up. Lol.
    2001 S3 (AMK)
  1. Help with instrument cluster A3
    By Gareth a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2012, 16:38
  2. Avant rear wiper wiring help please.
    By mike-a in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st April 2011, 19:12
  3. right click wire help please
    By mikeya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2009, 08:32
  4. Dension wiring help please
    By jimmymidnight in forum In-Car Entertainment
    Last Post: 15th April 2009, 15:20
  5. Headunit wiring help please !
    By Sam-K in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2007, 10:21
