Sky InsuranceJMB Retrofits
    Jan 2013
    Some doubts on 2001 A3
    Hi,
    Im new over here and I would like to start posting around since I just got a 2001 A3, and I love it, unfortunately the information LCD is bad (hope to have it replaced soon...) and some info shows when turning ignition on, seems to say Warning in the red space and there´s something else in the yellow part but I cant figure it out... once the car is turned on there´s no info and everything runs smoothly with no warnings whatsoever... any ideas? perhaps a standard message?.
    Second question is about the speed warning beeping, well, I get the light on when reaching the speed but there´s no beep, is it deactivated? can it be activated/deactivated?
    Cheers and thanks in advance.
    Sep 2012
    61
    When you switch your car on the yellow will probably be 'Ok' and the first red screen will probably be "service" regarding the light coming on when reaching a set speed hold down the button next to the clock and you should get a display on the screen indicating it has switched off.
    Jan 2013
    Quote Originally Posted by stewd View Post
    Exc ! actually it is service not warining , so it is probably it, and regarding the speed limit warning what I am actually looking forward is to get the beep when the light comes up...., if it´s too anoying I can then shut it down again.. but I wanna make sure it does work, at this point there´s no beeping only the light...
  1. Some pics of my recent Thermostat and Water Pump change 2001 Allroad 2.5tdi AKE
    By skyegtb in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th April 2012, 18:37
  2. Just bought 2001 s3, looking for some help please!
    By S3lvo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2012, 16:13
  3. Just bought an 2001 S4, have some questions...
    By samuel_adam in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st May 2004, 20:30
  4. Just bought some Alu mirrors for 250!!
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2003, 21:51
  5. Some nasty person
    By audi_girl in forum Other Brands & Models
    Last Post: 24th January 2003, 19:19
