EM TuningSky Insurance
Results 1 to 37 of 37
Like Tree1Likes
  • 1 Post By Andrew@A.L.D
Thread: R32 throttle body advice on my 1.8t please
    Sep 2010
    68
    Hi there ive just got my self a R32 throttle body for my S3 but ive bought a mk5 R32 throttle body not mk4 has any one fitted these? the difference i have seen though is theres no vacume port on the throttle body like there is on my 1.8t one but i was going to put a port in the adaptor so thats not an issue. basicly just want to know if any one knows if its the same size/layout as the mk4 R32 throttle body and where can i get an adapter from?
    Thanks for your help in advance Nick
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,176
    Think their the same mate, just unplug your standard s3 tb and try the plug on the r32, if it matches up your fine.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    829
    Add Vex182 on Facebook
    I'm sure the map will have to be adjusted and also there is not a ridge on the lip of it so it will pop off under pressure. Best bet is to look into Tuffy's thread as he fitted one some time ago and then removed it.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Bill @ Badger 5 sells adaptor plates for R32 to 1.8t manifolds...
    Have a read from here...
    My minor modding thread
    <tuffty/>
    Sep 2010
    68
    Tuffty that's perfect just what I wanted and I was also thinking of get a spare small port manifold and doing what you've done as I'm running a big port head thanks for everyone's feed back I will get in contact with bill see how much an adaptor is thanks again
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    Quote Originally Posted by Vex182 View Post
    I'm sure the map will have to be adjusted and also there is not a ridge on the lip of it so it will pop off under pressure. Best bet is to look into Tuffya thread as he fitted one some time ago and then removed it.
    Yes map adjustments is recommended
    Mine doesn't have a lip and have run 30 psi, I use a 83mm hose and i think Tuffty used a 85mm. I just used the old hair spray trick and its been fine.
    What spec it the engine? Not really worth it on the standard S3 inlet manifold.
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,176
    Im running a v6 tb on my unmapped s3 and its fine, i had the plenum port matched to the same size as the v6 tb and had a adaptor plate mare to fix it, i also gasket matched the runners at the same time, although ill be ditching the inlet manifold for a largeport one soon.
    Sep 2010
    68
    My engine is fully forged and rebored I'm running a gt2871r turbo with a tial tubular manifold I've got a big port head as well I'm going to get another inlet manifold and basically copy what tuffty has done
    Jun 2009
    Leeds
    3,353
    You mean copy what i've have done lol Tuffty copied me
    FOR SALE
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,648
    Perhaps he means make it look OEM Anyhow you weren't the first were you? I saw it on VWVortex a while ago.
    VWVortex.com - Cast SEM-like Large Plenum / Velocity Stacks & AEB Runners for "homebrew" intake manifold. Opinions?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by Andrew@A.L.D View Post
    Hummm.... I copy no one... I do get inspiration from others though
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,468
    You guys that have done it, do you reeaaallly think it makes a difference?
    I mean, how big is your boost pipe work? Tuffty is yours 63mm?ish.
    I guess im thinking if the tb is the same size as the boost pipes then its cool, and the gains are in a larger plenum, rather than tb? Because the tb can be thought of as a continuation in the boost piping.
    Am i making sense? Its late.
    I guess if the tb is making a difference, thats also like saying increasing the boost pipe size will do the same. Right?
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,648
    Remember the throttle plate and spindle will reduce the diameter to a degree.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Difficult to tell if it made a difference on mine... going to a larger inlet made more of a difference on my setup and thats still on a std 60mm TB... yes, I have 63mm pipework now (63mm OD) and arguably the throttle body is a 'restriction' now... which brings me onto....
    Quote Originally Posted by Sam_ View Post
    ...exactly Sam... the 60mm ID is all well and good but actual surface area is reduced by the plate and spindle...
    I am sure that a larger TB will be beneficial for top end power on my car but at the end of the day its still a 'daily' road car and the smaller TB will help drivability...
    Increasing the size of anything in the charge air system will reduce overall airspeed and effect low end drivability... this can be improved on in mapping (I run a lot of timing advance low down) but its always a balancing act... bigger isn't always better
    <tuffty/>
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,398
    Ok guys, i have edited this thread. If you have a problem with that, feel free to pm me.
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Reesy's Avatar
    King of the Mods. Apparently.
    East Sussex
    3,600
    Visit Reesy's Instagram Channel
    I have a larger TB on my large port inlet mani.
    A lip was welded on to mine to stop the worry of it popping off.
    I have posted something very similar to this already.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by Reesy View Post
    Ah yeah... I had forgotten about that... after having my hose pop off twice I did the same lol...
    <tuffty/>
    S3Zek's Avatar
    Sep 2011
    407
    That TB looks familiar
    Jun 2009
    Leeds
    3,353
    TBH i would say that the T/B alone on a standard inlet doesn't give much if any gains.
    Add the T/B to a large port head and custom large port inlet then yes there are gains.
    We could do with a back to back dyno run to prove this..... Tuffty its time to do a bit of testing done
    FOR SALE
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    ....We could do with a back to back dyno run to prove this..... Tuffty its time to do a bit of testing done
    It is on the cards... now that the car appears to be behaving itself I will be back on it again very soon
    <tuffty/>
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,083
    have you still got the R32 TB waiting to go back on then PT?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Sadly not mate... need to source another....
    <tuffty/>
    Jun 2009
    Leeds
    3,353
    Westy likes this.
    FOR SALE
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    nothing ever came of promise tests 2 & 3 did they?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    S3Zek's Avatar
    Sep 2011
    407
    <tuffty/>
    Do you want your old one back tuffty for testing? I'm not going to use it now till I get a custom large port mani anyway, Let me know and I will ship it back to you.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by S3Zek View Post
    I'll let you know mate... thanks for the offer
    <tuffty/>
  28. #27
    S3Zek's Avatar
    Sep 2011
    407
    <tuffty/>
    No probs
  29. #28
    INA
    http://www.inaengineering.com
    Oct 2008
    65
    Quote Originally Posted by S3_nick View Post
    MKIV & MKV R32 are the same throttle body. Only difference is some have the coolant ports as they throttle bodies sit over a hot exhaust manifold.
    An adapter plate to mate a MKV R32 throttle body w/75 x 75mm bolt pattern & 75mm throttle opening onto an OEM 1.8T intake manifold does not exist. The 75mm diameter cuts into the counterbored mounting holes on the adapter plate. Best bet is having a plate machined that tappers down to a 70mm , welding said plate onto your OEM manifold and then opening up the manifold to 70mm.
    HTH
    Issam
  30. #29
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    and yet it has been done as a test on std ported inlet and R32 throttle.. Go figure
    pointless mod btw on std plenum imho...
    bill@badger5.co.uk
  31. #30
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    What gains could be seen on a large plenum bill?
  32. #31
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,468
    1000hp
  33. #32
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    1000hp
    you have been looking at my plenum havent you...
  34. #33
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,468
    yes. i want!
  35. #34
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    depends on the power level..... higher power more gains. we saw >5000rpm 17bhp gains on tufftys at 300bhp level on his...
    bill@badger5.co.uk
  36. #35
    Jun 2009
    Leeds
    3,353
    I saw 19 bhp at 400 bhp with the inlet
    FOR SALE
  37. #36
    Nov 2011
    Finland
    131
    Will the cruise control work if some other TB is mounted? Just saw some saying (few years ago) at Wortex that it wont, but is really so?
  38. #37
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by BuuBBa View Post
    Mine worked fine
    <tuffty/>
  1. R32 Throttle body
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2011, 19:36
  2. Replies: 1
    Last Post: 27th April 2011, 11:06
  3. r32 throttle body outside size
    By tony696 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2010, 18:02
  4. r32 throttle body
    By jim s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2008, 16:05
