Chris NottEM Tuning
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By s33nyboy12
Thread: I love it when a plan comes together......
    Sep 2012
    Colchester
    90
    Today I had my first proper drive in an S3........ and ive owned the car months.
    I bought the car off another member.... who since hasnt been back on here funny enough..... and all seemed fine.
    No running issues, no abnormal smoke, impressive service record etc.
    Then, 3 weeks into ownership all hell broke loose. Car felt sluggish. Was using coolant at the rate i was refilling it weekly.
    Sniff test said head gasket was fine but a leak was discovered on one of the turbo coolant pipes. Replaced pipe.
    Then the PCV system had a fit. So i just gave in and binned it for a catch-can.... which highlighted other vacuum leaks which i sorted.
    Then i developed misfires. Coils were swapped about and the misfire stayed on cylinder 1. so i changed the spark plugs. made no difference.
    Checked the wires - fecked. So i soldered in a new loom.
    Car ran reasonably ok but still had misfires in high boost.
    Compression test showed a leak. Coolant started goingt down, white smoke from exhaust - didnt take much brain power to figure head gasket had called it a day.
    So left it a few weeks (dangerous but had no choice) and changed head gasket and every other gasket on the head and thermostat.
    Also had to clean off thick rings of k-seal.... which means it had gone before and had a quick fix.
    Put it all together - ran like a bag of spanners!!!
    checked timing - all good. Drove it for an hour and it started running really well and smoothed out..... except i now had a screaching dying cat sound when boost kicked in.
    So left it there for a week and just spent an hour tighening exhaust/turbo manifold bolts, all jubilee clips, double checked vacuum lines and went for a drive.......
    F*ck me it flys!!!!! It feels lightening quick and responsive (loaded revo stg 1 back on) and im chuffed.
    Feels much quicker than when i first bought it - can actually feel it pushing me into my seat now!
    Time to start putting money aside for some mods now!
    To anyone else having issues with their car and are getting disheartened - stick at it. It will all work out haha!
    Sorry for massive post - just wanted to put across the pain ive had with this car
    Audi S3 [AMK 1.8T]
    Mods:
    N249 Bypass
    Revo STG 1
    Rota Grid Drift 9.5J alloys
    AP coilovers
    PCV oil catch can (to atmosphere)
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,069
    Glad to hear you're sorted mate, sounds like a right pain in the arse!
    Who was the member on here that it came from?
    hOAx2000's Avatar
    Jun 2012
    Ipswich
    25
    Wow - Thats sounds seriously unlucky but its good that you didnt give up and came out on top with it!! Someone didnt look after the car very well at one point.
    Buzzer's Avatar
    Apr 2011
    Dublin
    410
    I had similar problems myself when I bought mine, it had a HUGE service record with no expense spared.
    Recon the problem was ME. I kept pushing it on every time I drive it and it highlighted anything that wasn't 100%.
    Sep 2012
    Colchester
    90
    AJD S3 - he has been on since but that didnt show on my phone so i retract the above statement.
    Thing is Alex seemed like a decent guy so i'm inclined to believe he may not even have known it was full of k-seal.
    But thats the chance you take with buying second hand..... and private
    Either way its a good job i didnt have to pay a garage to do all the above - id be broke
    And ive now got a good solid base to do what i originally wanted to do when i bought the car (FMIC and intake).
    Audi S3 [AMK 1.8T]
    Mods:
    N249 Bypass
    Revo STG 1
    AP coilovers
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,285
    That my friend is so similar to my story but mine involved new brakes all round too, sump ,oil pick up , oil sump sensor,and an abundance of vacuum / boost leaks. Mine cost me a fortune at garages but at the end it was just about worth it. Sold it then 4 weeks later the new owner phoned me and said he has blown a 4 inch hole in the side of the engine!!! .????? I was so annoyed I offered to buy it back off him, I was certain this was almost impossible. He declined my offer!
    I'm glad you sorted it all mate and you stuck at it til was all good.
    Enjoy!
    Sean
    turnstyle likes this.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,528
    Good work buddy! You've just reminded me that I need to do my head gasket. Gonna do it at 200k!
    Sep 2005
    Derbyshire
    180
    Mine was the same when I bought it, some £3-4k in repairs alone and it's starting to get to what I think it should be. It did have FSH and a clued in owner prior, maybe it just hates me?
    Sep 2012
    Colchester
    90
    Mental really - if your not careful cars like this can turn into a money pit.
    But just goes to show, a good service record can still hide lots of issues. Mine actually came with a ring binder full of receipts/invoices.
    At first i thought that was good.... all the owners keeping a record of the work they have had done over last 11 years etc.
    Maybe I should have seen it as a warning that this car will break haha!
    Im lucky though, its cost me about £500 to set this car right. (I did forget to mention that I had to buy a battery 3 days after getting home. It died while i was washing the car listening to music )
    Id hate to see the garage bills if i had gone to and from a garage.
    Audi S3 [AMK 1.8T]
    Mods:
    N249 Bypass
    Revo STG 1
    AP coilovers
  1. Low (when the time comes)
    By Dogtown22 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd December 2012, 14:22
  2. Rev D DV Valve When did this come out?
    By jaydav2306 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2012, 11:39
  3. Love it when....
    By Ash B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2008, 17:47
  4. Don`t you just love it when people grow out of thier max power phase!
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2005, 17:32
  5. Whens the new RS3 coming out ?
    By Wish in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2003, 19:33
