AH FabricationsChris Nott
Page 7 of 9 FirstFirst 123456789 LastLast
Results 241 to 280 of 344
Like Tree136Likes
Thread: Audi S3 - Stroker Big Turbo build.
  1. #241
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Hahahah, let's just say he needs a cold shower
  3. #242
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Let's play a game of........
    GUESS THAT PART.....
    I will go first
  4. #243
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    oooo i know this one.
    Bloody damn stupid squiters i believe is the technical term
  5. #244
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,098
    Ohh dear that's not good
    Feel for you mate
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
  6. #245
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOO
    Not another build?
  7. #246
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Quote Originally Posted by Byzan BAHons View Post
    And.... We have a winner
    Quote Originally Posted by StaceyS3 View Post
    Feel for you mate
    Been a long day, replaced the alternator then went out in the morning to do some logging while its was still "cool"
    Hit the rpm limit in 2nd gear and the usual POP, but then I noticed the oil pressure was lower than usual. Stop the car and idled for a bit, no low oil pressure alarm, so went back home. Still had 40psi oil pressure at 3k rpm so took it easy.
    Let the car cool down for an hour then took the sump off. Found the square piece in the sump and was confused at first as I had to think what it could be. The other pieces drained out with the oil, only found them after I realised it was the oil squirter from cylinder 2.
    No idea why its been sheared off as the pistons don't touch the squirters when the engine is turned over by hand.
    Luckily I am a parts hoarder and have a few sets of oil squirters.
    HO LEE CHIT - Changing an oil squirter while the crank is still in the engine is a job for various "multi" tools. Put and extra modified brass washer as a spacer just to give the squirters a bit more clearance.
    But its done and it was a blessing in disguise as I had a look at the NEW OEM oil pump, which hasn't done more than 3000km, and its almost seized. It's impossible to turn by hand and just possible to turn with a torx key. So I fitted the used one from my 1.8t engine, which still turns easily with one finger.
    Sump sealant is drying and I will put the oil in, in the morning, prime the oil system and take things from there.
    Oh the bumpy road to big turbos
  8. #247
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,274
    Good job you spotted that then and also good you could change without a strip down.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  9. #248
    RIP S3dave
    May 2004
    nr Glos
    7,175
    is there any witness on any of the pistons?
    was it tighted v.tight on install? they are v.tight to get off as you know..
    just one piston? weird
    rod straight?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  10. #249
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Other pistons look ok at the moment. The piston did touch the squirter but not by much, there is a slight imprint on the piston skirt. I can see it but can't feel anything when I ran my finger over it. Doesn't seem near enough to break the squirter bolt. Maybe the bolt was the issue and just gave up. Come to think of it, maybe they are a one time use only item.
    Oil squirters were all torqued to 27nm (20ftlb) at engine build.
    I could only eye ball the rod but it looks good.
    The beast is running again, but need more isopropyl alcohol as I have run out and IAT went from max 35c with the 2 stage injection setup to 65c without any injection. So that put a stop to the logging this morning.
  11. #250
    Apr 2013
    JHB, South Africa
    168
    Glad to hear it wasn't as serious requiring a rebuild
  12. #251
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    More bumps in the road to big turbo.
    I had random misfire issue in the past and it was always cyl3. Tried all kinds of ideas to sort it out. Then it went away.
    and then....
    After I repaired the oil squirter and replaced the nearly seized oil pump. The misfires came back and with vengeance.
    I have been trying to find the issue by swapping coilpacks, spark plugs, checking wire harnesses, coolant temp sensors. But nothing seemed to change the misfire.
    It would blow out on boost and start misfiring on 2 cylinders, then one would recover and run on 3 cylinders, then finally the last cylinder would recover and it would idle fine again. I had to pull over to the side of the road and let it recover.
    It would also start to misfire if I engine braked but only on 1 cylinder.
    Cruising on the highway below 3500rpm and not engine braking, it would run perfect!
    So I decided to fit the stock manifold with stock injectors and TB as well as stock maf housing and stock map, my thinking was to eliminate the bigger injectors, new manifold and hemi TB.
    Drove the car off boost with the stock setup and it still started to misfire. Now I know that its not any of the stock parts at fault because they have worked on the stock engine.
    So next was to check the engine. Did compression test and all cylinders were just above 170psi. I little bit low as I was hoping it would be closer to 200psi.
    Then I decided to remove the cams to see if there was an issue with the valves.
    I was shocked to find 3 hydraulic lifters had come apart, 1 per cylinder. My theory is the lifter would pop apart, cause the misfire and then slowly get pushed back together as the engine recovered.
    These lifters were brand new, so I was pretty concerned about the other coming apart. So I replaced them with my used lifters from the stock 1.8t engine. Fitted everything back together and all is well with the bumble beast.
    Did some logging and found that the engine is pulling a lot less timing than it was before I changed the oil pump and squirter.
    so hopefully we can get back on track with the mapping process.
  13. #252
    Apr 2004
    12,520
    Thank heck you sussed it. This modification stuff is a long bumpy road.
  14. #253
    RIP S3dave
    May 2004
    nr Glos
    7,175
    i was'nt expecting to read this
    good find fella
    www.badger5.biz
    bill@badger5.co.uk
  15. #254
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Quote Originally Posted by Scullies View Post
    ****e that's got me worried. Just sealed up the sump and kinda wished I replaced my pressure relief valve bolts for the oil squirters.
    Any body else replaced theirs?
  16. #255
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Yeah, I have never seen lifters come apart while they are still in the engine. But strange things happen.
    THIS CAR WILL GO FAST !!!! dammit
  17. #256
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Is it only because yours is a stroker that the oil squirter got snapped off from the piston?
  18. #257
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Quote Originally Posted by hoffmanvp3 View Post
    I don't really know why it broke, I thought there was enough clearance when I built the engine. Only one squirter bolt snapped, the piston has a slight impression on the skirt but its so slight that I can barely feel it with my finger. So there was definitely not enough impact from the piston to sheer the squiter bolt in half.
    I will put that in the mysterious box along with, spun rod bearing, cracked fsi crank, cracked block across main bearings and exploding hydraulic lifters.
    Not much else can go wrong now
  19. #258
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    I've been reading on vwvortex that some stroker engines had the clearance then when they changed their running in oil out came a squirter. Must be hitting ever so slightly at full load as the rods will shrink and stretch and will prob just tap the squirter block and over time this will prob create stress cracks and eventually fail. But this is just a guess
  20. #259
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Mine were spaced out with aluminium washers at engine build, so there was "extra" clearance. Maybe the bolt was tired and gave up from the slight piston tapping. Then when it broke off it must of gotten beaten by the crank and rod on its way down into the sump.
    Things could have been a lot worse but luck was on my side for a change.
    I still feel the piston would really need to hit the squirter hard to snap the bolt and then the piston would have a fair bit of damage to it.
    I could undersand the theory if all the squirer bolts snapped or were knocked loose, but they were all still tight when I tried to re-torque them.
  21. #260
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    That is an epic collection of mishaps. Things can only go up right!
  22. #261
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Maybe a weak rod that compressed and stretched more than the others or a slightly out of true big journal on the crank that was specific to that piston?
    Did u use a DTI to measure true TDC on each piston? That'll tell if the crank or rods are true
  23. #262
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Oh there are a lot more to add to that list, but they are all user error.
    Last night was a good example, I was testing the engine for any more misfires and forgot I was on a redonkulously high boost map, started hammering it down the road and blew the boost pipe off the TB, with that there was an almighty BANG and a backfire that blew out the TB and lit the whole of the front of the car up. It was like NLS but out the front of the car.
    Obviously the engine died, so I popped the bonnet and found that carpet thing that's clipped to the underside of the bonnet was completely destroyed and half hanging over the engine. I was meaning to remove it anyways
  24. #263
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    No i havent, if I buy one more tool or part for my car I will get served with divorce papers......
    I will add it to the "one day" list, which is quite a long list atm
  25. #264
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Oh and I forgot about today's experience, while waiting at the alignment shop for my mates TT to get done, I left the car idling and after a few minutes the larger radiator fan burnt out. Noticed that awesome PC board smell and opened the bonnet to find smoke!! Mad rush to turn the car off and grab the fire extinguisher!
    No fire thankfully, so I cut the wires going to the fan as I couldn't be arsed with getting under the car to find the plug and unplug it.
    Drove the car home while keeping an on coolant temp in VCDS, I have a massive radiator that sits behind an FMIC and large oil cooler and the coolant was sitting at 88c while cruising home in 35c weather.
    So we went down the the scrap yards in my mates TT, bought a used mk4 golf shroud and fans, fitted them this evening and all is well with bumble beast again
    Good thing my wife doesnt read this, what she doesnt know wont make her ANGRY
  26. #265
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    AND.......lets add a dead MAF to the list
    Weird thing is I went to borrow my mates MAF sensor from his TT, pulled it out and noticed the sensor number is F 00C 2G2 076
    his car runs fine with that sensor, so tried it in mine and it works. How weird. After a lot of translated google pages, it turns out that sensor is for an Audi A2 1.4tdi.
    We have no idea how the previous owner found that sensor here in this country as there are NO diesel cars around.
  27. #266
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    This happened to my friends TT, I recently found out that when he dismantled the head he put all the tappets in a magnetic tool tray
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  28. #267
    RIP S3dave
    May 2004
    nr Glos
    7,175
    sensor element should end 049 to be correct
    www.badger5.biz
    bill@badger5.co.uk
  29. #268
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Quote Originally Posted by Andrew@A.L.D View Post
    That must be a pretty strong magnetic tool try
    Yip, 049 is what I had. Typical 13 month expiry date. New 049 will be purchased ASAP
  30. #269
    RIP S3dave
    May 2004
    nr Glos
    7,175
    bosch sensors suk... not what you would expect from Zee Germans is it... so called quality make, not in reality more often these days.
    Sad but true
    www.badger5.biz
    bill@badger5.co.uk
  31. #270
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Lets go maf less yanky style
  32. #271
    RIP S3dave
    May 2004
    nr Glos
    7,175
    after you
    www.badger5.biz
    bill@badger5.co.uk
  33. #272
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    after you
    hahaha, come on
    You the magic man, I'm just the minion loading files. What do I know
  34. #273
    RIP S3dave
    May 2004
    nr Glos
    7,175
    RS4 MAF for me
    www.badger5.biz
    bill@badger5.co.uk
  35. #274
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Ok, so this misfire on cold start has won. I have no idea why its only misfiring when the engine is cold.
    Its not remap related, as I have fitted stock k04 injectors, stock maf and flashed stock ecu file. Still misfire when cold.
    Misfires are multiple random misfires across all 4 cylinders.
    So the decision has been made to pull the head and fit the AMK head with K04 setup so I can drive this bumble biatch!
    Have also received a precision Vband in/out turbine housing, so its a good time to make a new exhaust manifold.
    My mate is going BT on his TT, so he can use the existing T3 manifold.
  36. #275
    RIP S3dave
    May 2004
    nr Glos
    7,175
    I did'nt think it ever was map.... given similar spec hardware drives around fine for 2 years now..
    misfires we have seen have been plug related.. new plugs supplied by customer turned out to be faulty.. chased our tail on that one.
    www.badger5.biz
    bill@badger5.co.uk
  37. #276
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Thats why you the boss
    I will try another new set of plugs, it will be the 3rd set but its still easier than pulling the head
  38. #277
    Dec 2013
    6
    Wish I had the money to do this
  39. #278
    Jun 2009
    Leeds
    3,469
    What pugs are you using as i bought a new set fitted them and it misfired when cold then found out they crap so i fitted a set of Bosch platinum plugs F5DPOR and i can't fault them but your best changing them every 6 months or less depending on how many miles you do.
    FOR SALE
  40. #279
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    I have tired NGK PFR6Q and NGK BRK7E, both new and resulting in misfires.
    I will have a look if those plugs you use are available here in Dubai.
    My service plan is new oil, plugs, filter every 5k km.
  41. #280
    RIP S3dave
    May 2004
    nr Glos
    7,175
    for testing, std PFR6Q
    Scullies likes this.
    www.badger5.biz
    bill@badger5.co.uk
  1. Did someone say BIG TURBO build ????
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2012, 21:22
  2. S3 PE1820 big turbo build
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2011, 13:03
  3. 2002 S3 big turbo build
    By suba..who?? in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2011, 21:26
  4. Big Red Building and Little Red Audi
    By technics100 in forum Photography & The Digital Darkroom
    Last Post: 3rd July 2008, 00:23
