Monster MotorsportEM Tuning
Page 3 of 8 FirstFirst 12345678 LastLast
Results 81 to 120 of 305
Like Tree96Likes
Thread: Audi S3 - Stroker Big Turbo build.
  1. #81
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Thanks Karl
    Here is a time lapse of seating the inlet valves - I only used the fine grit paste as the valves were seated properly on the first build.
    Once I have finished the exhaust valves, the head with get a good clean an all the supertech valves, valve springs and titanium retainers will get fitted back into the head.
  3. #82
    Apr 2013
    JHB, South Africa
    162
    Amazing build bud! Gona be watching this closely
  4. #83
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Thanks bud, I won't be going so in depth like some of the other builds. It's all basically the same.
    time lapse is easier for me. I can leave the camera recording, than having to stop and take pictures.
  5. #84
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    insane build man, and i thought you owned normal yellow s3 lol!-)
    1999 apy s3, black & blue interior,dare bbs lm's, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, stock dump valve, badger 5 v3 tip, bam rocker cover and push in coilpacks, toyosports fmic, amd stage 2+ remap 280.3bhp 263.9 lb/ft.
  6. #85
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    It is normal yellow
  7. #86
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Today I put the head back together after giving it a wash to get all the grinding paste and dust off of it.
    Here's all the supertech valves ready to be put back into their respective area.
    and the "special" valve tool
    and then a time lapse of assembling the AEB head with supertech valve train. Head is waiting for VVT and cams to be fitted.
  8. #87
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Nothing too exciting today. Cleaned the carbon off the pistons and fitted them to the IE rods.
    Ready to be assembled..
    Assembly..
    Things are on track to get the motor assembled this weekend
  9. #88
    nanananananananan BATMAN
    May 2012
    JHB, South Africa
    1,000
    Add MIGGZ on Facebook
    so much win dude!!!!!!!!!!!!!
    My rides thread : http://www.audi-sport.net/vb/a3-s3-f...t-journey.html
    Quote Originally Posted by Paradox1 View Post
    Healthy??? no,no,noooo
    Mine is healthy
    yours is on steriods!!!
  10. #89
    Apr 2013
    JHB, South Africa
    162
    I love it!!! Very informative build
  11. #90
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Started assembling the engine, here's the time lapse video of fitting the crank and checking the main bearing clearances.
    Pedrosousa likes this.
  12. #91
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Finishing off the engine build,
    Waiting for bits from the engine that's in the car at the moment, then the cams can go in.
  13. #92
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Nice! How does the full race manifold line up the downpipe in regards to the master cylinder? Is yours LHD?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  14. #93
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Yeah, mine is a lhd, so the MC is on the opposite side to the downpipe. also its not a full race mani but the same design type. I fabricated it myself and welded by someone else, I had to bring the t3 flane closer to the head to fit the turbo in, as well as tilt the turbo over a bit to allow a 4" TIP to be fitted. It it was straight the TIP would of hit the MC.
  15. #94
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    If anyone is looking for AN fittings to fit the Bosch 044 fuel pump, I found this place that does them for $14 complete.
    Bosch 044 Inlet/Outlet Fittings
  16. #95
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Good fair price
  17. #96
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Hot here today
  18. #97
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,305
    Ouch! That is hot
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
  19. #98
    Apr 2013
    12
    Nice buid man!!! There are some s3 with stroker kit. Look at s3 stratis on youtube.
    Will you use WMI??
  20. #99
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Geeeez, that's crazy power. I don't think I will be heading down that road. Tha'ts Andrews@A.L.D department
    WMI is definitely going to be part of the setup
  21. #100
    Apr 2013
    12
    I am playing with hybrid K04 in my S3 and you with that toys!! Hahah. You are the luckiest man in the world of the s3's 8L!!
  22. #101
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    Quote Originally Posted by Scullies View Post
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  23. #102
    May 2012
    JHB, South Africa
    1,000
    Hey hey hey..... Where's the updates bra?
    Mine is healthy
  24. #103
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Absolutely fook all, its been pretty warm and I dont have the energy at the moment to swop the engines out in 45+ degs.
    I was hoping to get it down before things got hot here but I think I have missed that cut off date.
    My mate here is going back to the US for a few weeks at the end of June and he said I can use his workshop when he is gone.
    So hopefully by the end of the month it will be in, but then I'm going to need the WMI to do the mapping as things will be cooking by then. Will have to be midnight/early morning logging but its still warm then, around 30 deg
  25. #104
    May 2012
    JHB, South Africa
    1,000
    Dude that's hectic hey! Its winter here now but the days I'm off work its 28'+ and I can't dyno to get a reading.
    What wmi kit you gona run?
    Mine is healthy
  26. #105
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Its going to be a DIY hybrid kit
  27. #106
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Taking advantage of the last of the "cool" weather with an early morning blast through the mountains.
  28. #107
    Jun 2009
    Leeds
    3,352
    Nice long open roads you must love getting your foot down
    In the uk we have more donkeys, Not the animal type but the type that can't drive
    FOR SALE
  29. #108
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    There are plenty of those creatures this side too, that's why we go early as they still sleeping.
    That road is awesome and let's just say I'm glad there are no speed cameras on the route :D
  30. #109
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    collecting parts for wmi
    Tank and level sensor for $25 - gotta love the forums.
    Missed out on a new AEM pump and boost switch for $75
  31. #110
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    I might go to Dubai soon, I should visit
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
  32. #111
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    So some more bits arrive
    WMI pump, was looking for a 300psi pump but this new one came up for a deal.
    An a small catch can with AN fittings. The plan is to run black braided hose from the IE breather kit to the catch can. I want to run 2 separate lines, one for the crankcase breather and one for the valve cover breather. Will see how the oil smell is, so at the moment it will vent to atmosphere.
    Then got some of these 6an fittings that are said to clip onto the stock fuel line fittings that come into the engine bay. Then AN lines to a surge tank and fuel bump.
  33. #112
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,305
    Your WMI pump looks just like my AEM one
    2001 S3 (AMK)
  34. #113
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Yeah, it seems these 200psi all look pretty similar. Probably same manufacturer. Even the 300psi one looked the same.
  35. #114
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    So today I braved the heat and did I little bit of trial fitting to familiarize myself with the setup again.
    So AEB runners fitted along with fuel rail and TIP. I wanted to see if the breather lines would like better going under or over the TIP to the catch can. I think it will look neater going under, bearing in mind all aluminium pipes with end up black.
    [IMG][/IMG]
    Since the spare oil filter housing I have is from a N/A car, I found a nifty brass adapter that will allow me to extend the oil pressure switch and add an oil feed line to the turbo. Aftermarket oil pressure switch will be fitted to the filter housing in the spare port on the top. Xcessive plenum is on order but the people in the US are celebrating their independence day so shipping will be delayed a few days.
    [IMG][/IMG]
    Now been looking where to fit the DV, I previously had it located near the TB but have decided to change it to the OEM position, except having the DV sit closer to the charge pipe and then dumping into the TIP with a straight hose and not the one thats fitted in the picture. Its all I have at the moment. Again waiting on piping and silicone for charge pipe.
    [IMG][/IMG]
  36. #115
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    Looks good. i dont know where to put my dv yet, but i like the idea of it close to the charge pipe, but then it'd be more of an arse to change coil packs.
    what maf sensor housing is that? Is that a 4 inch tip?
  37. #116
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    The DV would be fitted to a nipple off the charge pipe, so it would only need to loosen a hose clamp and pull DV out. But my setup requires, DV off, charge pipe off and heat shield off to access plugs or coil packs. Fsi coil packs will be bolted down so they wont be popping off.
    something like this - Universal 2 5" Type H RFL Blow Off Valve Adapter Turbo Aluminum Flange Pipe Tube | eBay
    The MAF housing is a B7 S4, which is the same as the B5 RS4
    FYI - MAF sensor housing
    TIP is a 3.5" with a 3.5" - 4" elbow on the compressor housing. Also there is a nylon spacer pressed onto the filter side of the MAF to increase the MAF diameter to 100mm so the air filter can be clamped down.
  38. #117
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Thats the perfect maf for me then. Ive got a 3-3.5 inch coupler on my turbo inlet, and want 3.5 inch all the way to filter.
  39. #118
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    I have received the last of the bits for the WMI setup. Will use a single nozzle setup on the k04 engine for now and it couldn't have arrived any sooner as its been 50deg the last 2 days, not that I drive the car as it has no AC atm and the holy month of Ramadan has started, so thats no eating/drinking in public from sunrise to sunset as per the fasting rules
    All that is needed is to get a bung welded into the IC piping and find the energy to install the system.
    Now introducing my SNOW DEVIL MIST water/methanol system
    [IMG][/IMG]
    Plan to use the 2nd nozzle, check valve and boost switch along with a solenoid as a 2 stage setup with the BT engine. Will see how that works out.
    Saw this on FB - love it
    https://www.facebook.com/photo.php?f...type=1&theater
  40. #119
    May 2012
    JHB, South Africa
    1,000
    Very curious to see how the twin nozzle setup works you gona do before turbo or before cooler?
    Mine is healthy
  41. #120
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Before turbo??
    Been advised to use the larger nozzle just after IC, as normal. Then the smaller nozzle near the TB.
    So the idea is stage 1 starts off 15-18 psi going flat out, then stage 2 kicks in at a high boost, thinking 28-30psi. This will need to be tested at different boost levels first to see if it all works out as planned
  1. Did someone say BIG TURBO build ????
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2012, 21:22
  2. S3 PE1820 big turbo build
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2011, 13:03
  3. 2002 S3 big turbo build
    By suba..who?? in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2011, 21:26
  4. Big Red Building and Little Red Audi
    By technics100 in forum Photography & The Digital Darkroom
    Last Post: 3rd July 2008, 00:23
