Chris NottEM Tuning
Results 1 to 22 of 22
    Oct 2012
    West lothian,Scotland
    227
    Question Bleeding brake problem
    Changed the disks and pads on the a3 because they were rubbish, still rubbish so done a quick google search and found this old thread Brake problem - Audi dealer can't bleed them even so want to try the Ross-Tech: VAG-COM: ABS Brake Pump Bleeding before changing the master cylinder btw my brakes are doing the same as the one in the thread, could someone explain in more detail the Ross-Tech: VAG-COM: ABS Brake Pump Bleeding technique I may be missing something but it seams like a brief discriprion also how to bleed the master cylinder
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    You don't need to bleed the ABS pump unless you have changed it or have introduced air into the system upstream of the ABS pump...
    Generally these will just need bleeding using a pressure bleeder (don't use the 'pump the pedal' method) and make sure you bleed the master cylinder last..
    What do you mean when you say your brakes are rubbish? new disks and pads take a few miles to bed in and get their bite...
    <tuffty/>
    Oct 2012
    227
    In general the brakes were soft from we got the car thought although new looking pads still spongy pedal, so thought perhaps Cheap pads and disks as had been the case with my Mondeo so got apex ones but pedal is worse gose right down before it bites and really soft and when you pump it and hold it, it slowly gose back down as mention in the before thread so perhaps it's previously had pump etc change and not bleed properly??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Bleed the master cylinder before doing anything... use a pressure bleeder...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    ...and add paragraphs to your posts... makes them difficult to read...
    <tuffty/>
    Jun 2011
    Great Melton Norfolk
    1,356
    Might be a silly question but has the Brake fluid been changed recently?
    Oct 2012
    227
    Ok and as far as I know it has not had a change in brake fluid not from we got the car anyway
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    So you haven't actually bled the brakes at all? fluid needs to be changed every 2 years... get some fluid and a pressure bleeder (Gunsuns Eezi bleed) and get it changed
    <tuffty/>
    Jun 2011
    1,356
    Brake fluid absorbs water over time,so might be good idea to change it , especially if you have no records of it being done.
    Also new fluid will reduce the spongy pedal as well.
    Oct 2012
    227
    Don't have a pressure bleeder so will try bleed it the old fashiond way to see if there's any improvement doubt it tho after that most Likly fails will get it to a garage and should i ask them to pressure bleed the brake system and master cylinder??
    Oct 2012
    227
    I think the mrs bleed them the last time she done the back brakes a few weeks ago need to ask her, but am pritty sure she did
    Oct 2012
    227
    Ah well she says she never done it so will try that tomorrow and if that dont work will get it pressure bled
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    I wouldnt do it the old fashioned way, apparently our cars have something that if you do it the old fashioned way and it flips from inside, there is no way of unflipping it and it can end up causing more issues.....
    Might be worth doing a search, as there is alot of info on bleeding the brakes and about doing it the right way too.
    Oct 2012
    227
    What amount of fluid will I need to drain the system and refill it
    Oct 2012
    227
    So what's the verdict do it the old fashiond way see if it improves any then get the system drained and filled pressure bled and master cylinder bled or just leave the old fashions way all together and just get it pressure bled
    Jun 2011
    1,356
    Just get it pressure bled to avoid problems.
    Oct 2012
    227
    Bled including getting it emptied and filled
    Oct 2012
    227
    How much fluid will I require
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by Den13 View Post
    Do NOT use the old fashioned way... you will nick or flip the master cylinder seals and it will need replacing... use a pressure bleeder...
    I used a 1ltr tin of fluid... from GSF its not much more than a tenner
    <tuffty/>
    132
    I find the gunson isn't up to the job with bleeding problematic brakes (e.g air in the system). I use the sealey VS820 power bleeder, it works well and is worth the money.
    Oct 2012
    227
    Ok cheers again guys
    Nilz's Avatar
    Apr 2006
    10,087
    As Tufty says, dont do the old fashioned way, you will cause more problems for yourself.
    Get a litre or two, it doesnt cost much and you have extra just in case.
  1. Brake problem - Audi dealer can't bleed them even
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 17:05
  2. Bleeding Brakes
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2004, 20:20
  3. S3 brake problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2004, 23:39
  4. Bleeding brakes A3
    By marcsnoz in forum Handling
    Last Post: 16th July 2003, 09:47
  5. Bleeding Brakes A3
    By marcsnoz in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 09:41
