Results 1 to 24 of 24
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Rear Diff Oil Advise required.
    Hi Guys
    As with some others on here, I have the issue with the back wheels locking up, I have done a haldex oil and filter change, but the issue still exists, I have changed the earth strap, still the same and also removed fuse 31 and the issue is still there.
    I am going to try and change the rear diff oil.
    Can anyone advise which is the best oil to go for and also how much. It only seems to be happening on the back so im presuming nothing on the front needs to be done does it??
    Any help or advise much appreciated, im going to see if I can get it done this weekend.
    Nilz
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Oil is the same as the gearbox mate... 75W90 semi or fully synth... if the haldex is engaging even with the fuse pulled I believe thats the clutch plates sticking... an oil change may not fix it straight away...
    <tuffty/>
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    I did a bit of research on this. They're both 75w90 but the rear is GL5 whereas the front is only suitable for GL4. Something to do with the additives in a GL5 oil.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Interesting... just had a cursory search about and yeah... GL4 spec seems to be the one people suggest for the gearbox due to the GL5 spec being less syncro friendly (by all accounts)... will need to have a further read to validate this but this thread (VWVortex.com - Gear Oil: GL-4 vs GL-5?) suggests the VAG spec for 02A gearboxes is GL4 which corroborates this to a degree...
    Just to be a little clearer... as Sam has said it would seem you can use a GL5 spec in the diff but a GL4 spec for the gearbox... GL5 is supposed to be more 'slippery'
    <tuffty/>
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    I found out the hard way. I ordered GL4 for front and rear, only to realise (thanks to this forum) that GL5 was advised for the rear. Oh well, good to have spare!
    May 2010
    139
    I'm going to change the diff oil as i have the lock-up issue, although i'm going to buy a new controller to see if maybe the controller is duff..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by demons uk View Post
    Don't confuse the diff and the haldex... haldex is the clutch system that connects drive from the prop to the diff... both the diff and the haldex use very different oil... oil changes need to be done every 20k miles on the haldex... the diff and gear box typically only need topping up every now and then...
    <tuffty/>
    May 2010
    139
    <tuffty/>
    Yeah sorry didn't make that reply very clear with the lock up issue i thought it would be a good idea to change the diff oil as i've already changed the haldex and filter, i'm aware there separate units as with my last S3 the diff was a breeze to drain and fill and the haldex is a *****
    Nilz's Avatar
    Apr 2006
    9,640
    So just to confirm the oil that I go for, does it need to be a particular brand or anything, is it ok to go to TPS and ask for rear diff oil if I give my reg number?
    Also, how much will I need?
    With regards to the rear locking up Paul, do you think the oil change will make a difference or not??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    If getting the stuff from TPS they 'should' be able to get you the right stuff... not sure on quantity... couple of litres should be more than enough...
    A diff oil change won' make any difference to the haldex issue but its not gonna hurt to do it...
    <tuffty/>
    Nilz's Avatar
    Apr 2006
    9,640
    Thanks mate, will give them a shout tomoz if i get a chance.....
    Now back to the original issue.....any ideas on how further to sort the locking up issue???
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    tbh no mate... not seen any personally so can't comment... looking up is typically to do with the plates sticking or the precharge pump having a spaz... after a haldex oil change it may take a little while to free them up maybe...
    Sorry I can't offer much more input on this... I believe there are some tests that can be done in VCDS to see if the pump 'works' but beyond that mate I can't really say...
    Need to take one apart one day and see whats what
    <tuffty/>
    Feb 2012
    bedfordshire
    735
    I think I read but not 100% sure it's about 1.6lts for the rear diff. Tuffty didn't you use the same oil in the rear as the you did in the front diff and gearbox ? As I was going to use gl4 for front and rear I have read a few people have, with no issues
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by dre_S3 View Post
    Yes... no idea if it was GL4 or GL5... wasn't aware at the time of the difference as I bought the stuff from GSF at the time... guess it 'should' be GL4 but I can check and its not gonna cost an arm and a leg to swap it out if required..
    <tuffty/>
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    I'm not sure the rear takes 1.6L. About a litre did it for me. Haldex fluid is just the amount in the tube. Front took 3.5L.
    Suction pump makes the job of the front a rear box/diff way easier.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,638
    If I have it correctly, GL5 supersedes GL4 but isn't suitable for the gearbox. That said, some GL5 variants are ok in the gearbox but its safer to stick to GL4. Additionally, you could use GL4 in the rear but GL5 is better. Don't take my word for it though. Get googling
    Feb 2012
    bedfordshire
    735
    Ok I think I will get some gl5 for the rear then, does anyone know what one to get there are a few different types 75w 90, 75w 140, 80w 140 ? I bought 4 litres well 4 quarts as its American of redline mt90 gl4 75w 90 for the front diff and gearbox. Sam I did get one of those suction pumps to do it hopefully makes the job easier as it looks near on impossible with out one
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    75 - 90 mate... wouldnt get to hung up about the gl 4-5 tbh... new oil in the diff is better than a kick in the ass...
    Feb 2012
    bedfordshire
    735
    Cheers Dave I need to get some more oil to do the rear anyway so gonna go for the gl5
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by Nilz View Post
    Haldex always locked
    Seems to have the same issue you describe... pull the fuse and it doesn't lock... will let you know how this turns out (providing the customer pursues it)
    <tuffty/>
    Nilz's Avatar
    Apr 2006
    9,640
    Paul mine remains even if you take the fuse out, so not sure its the same issue...
    Will keep an eye on the other thread though, as it would be good to see if you do sort it or not.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Sounds like knackered Haldex Clutch unit or ECU mate, you need a scan?
    You've got to have a laugh!
    Nilz's Avatar
    Apr 2006
    9,640
    Hmm maybe Jo, ive already scanned the car and checked the pump, all of that is fine, no faults stored either.
    Thanks for the offer tho mate
    Feb 2008
    2,810
    Hope you get it sorted nilz.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
  1. Gearbox and Rear diff oil
    By rolo tomassi in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2009, 21:52
  2. Rear diff oil? (not haldex)
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2009, 08:32
  3. Rear Diff Oil
    By Jacko4130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2009, 19:15
  4. S3 Rear Diff Oil Change
    By jonS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2007, 20:09
  5. S3 Rear Diff Oil?
    Last Post: 1st February 2007, 14:24
