Volks AutosSky Insurance
    Nov 2012
    Kent
    451
    Add Tim_Attard on Facebook
    Hello, Changing my Double Din HU? HELP Please
    Hello,
    I’m new here and have just got my Audi a3 which I love; my first area of focus was the engine cleaned, DV, Hoses, and Paint etc. I am now going for my second area which is audio and need help on fitting a new head unit.
    I have an 03 Audi A3 1.8t it has a double din symphony installed already and want to know what I need to change it to a aftermarket double din?
    I can’t find anything useful on the web that I have seen, I know they don’t make a fascia adapter so I would have to get an a4 one and trim it but what one would I need?
    Would I need any other parts?
    What would I need to do to the wires?
    Tim
    Jan 2013
    Audi Double Din Car Stereo Fitting Kit
    Although its a full stalk adapter kit, it also includes a facia adapter, unless I'm misunderstanding the question. Hope that helps.
    actually just had another look. How about Autoleads DFP-05-09 Audi A3 Symphony Double Din Fascia Adaptor
    May 2012
    RETFORD, NOTTS
    1,707
    The 8L has sharper corners the one linked looks like an 8P
    You wont find a facia off the shelf for what you are doing. I wish i had never started my aftermarket head unit project now.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jun 2003
    World of my own
    9,813
    As said no one makes a DD fascia adapter for the 8L.
    You will need an RCA ISO wiring adapter PC9-410 and an ISO amplifier antenna adpter
    CT27AA05 Aerial/Antenna VAG Active ISO Adaptor
    You will also be missing a switched live on the ISO power harness as your A3 uses the CANBUS to tell the HU when the ignition is on/off. So you will need to either wire one in from the fusebox (fuse Radio s-Kont) or power the new HU off the permanent live and switch it on/off manually i.e. splice both the yellow & red feeds on the new HU together.
    Alex Turner
  1. Changing MFSW to DSG MFSW Help Please!!
    By Dannykn9 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th November 2011, 17:55
  2. a4 single to double din help please
    By durb992000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th July 2011, 12:11
  3. Double DIN System Help!
    By r4j in forum In-Car Entertainment
    Last Post: 27th July 2010, 15:43
  4. b5 avant double din fascia help
    By wellhouse0 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2008, 21:03
  5. Anyone with Audi SatNav (or double DIN console) please help
    By imported_christhick in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2005, 08:52
