JMB RetrofitsVolks Autos
    Jul 2012
    East Grinstead/ forest row
    104
    Audi s3 PCV failure
    hi guys, i belive that my PCV Valve isnt working due to air pushing out of my oil filler cap when removed, is there an up-market/ after market one i can put on my car? any ideas, cheers
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    All in the stickys at the top of the forum mate.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    No after market valve as such dude... just replace all the split/worn bits... or do a PCV delete..
    For the pressure to be pushing the oil cap up then something is seriously blocked and/or you have some bad ring wear.... you can test the theory by undoing the PCV pipe from the top of the rocker... see if the engine is breathing heavy...
    This is the stuff under the inlet of a facelift S3...
    <tuffty/>
    Sep 2012
    Caracas, Venezuela
    45
    Follow ceS3r On Twitter Visit ceS3r's Instagram Channel
    <tuffty/>
    My oil cap also pushes up when its loose, so I will surely do the PCV delete..
  1. 2.0 tfsi oil leak, possible pcv failure?
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2011, 23:29
  2. 2004 Audi A6 1.8T Avant Multitronic Failure
    By safcsteve in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th January 2010, 13:52
  3. Xenon levelling failure + big up to Tonbridge Audi
    By benw123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2007, 09:32
  4. Audi UK Will not warranty turbo failure on S4
    By ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2006, 11:41
Tags for this Thread
