Sky InsuranceAH Fabrications
    Adam P's Avatar
    May 2012
    Southampton
    333
    Battery Drain / Help Please
    As the title states, my 2001 s3 8l seems to have a flat battery when it is left un-driven for a couple of days.
    I got a local garage to check for any drains and all they came back with was to replace my battery as the one which came with the car looked undersized and didn't fill the battery holder fully. So i have done this today and replaced a cheap and nasty battery with one of these:
    Bosch Audi S3 Battery 027 3 Year Guarantee | Euro Car Parts UK’s No.1 Car Parts Retailer
    The swap was easy enough, however i took the car out for a run after the install and when i parked back on the drive i left the car running for a couple of minutes then turned off the ignition and walked round to the front of the car where i heard an electrical wining noise. I opened the bonnet and its coming from under the inlet where the alternator is located. I researched this on the forum and have seen other people posting about this issue. I timed the noise and it lasted for 11 minutes. Surley this drains the battery?
    If anyone has any ideas of can offer some advice it would be much appreciated.
    Thanks in advance.
    Adam P
    Sep 2012
    61
    Check your central locking pump isn't staying on, as has been know that it will keep trying to pump if the vacuum isn't made to lock the door...
    what HU do you have in the car? Standard or an after market one?
    Also have you put a volt tester on the battery whilst's the car is running? Should pump out about 14V and when it isn't running about 12.5, run the car for 5 - 10 minutes and check the voltage again and it should read 12.5 ish (same as when first tested before Starting the car)
    also as far as I am aware the noise you are hearing is the after-run pump.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    999
    Quote Originally Posted by Adam P View Post
    Thanks in advance.
    Adam P
    Have a look at this thread
    Water pump running on after ignition off & draining battery - help please
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    829
    Add Vex182 on Facebook
    Sounds like the after run pump. Feel the coolent hose near the inlet manifold, should feel the coolant flowing. Normal for it to run for a few minutes then turn off. Helps cool the turbo down, normal for this!
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    that S3 battery is a little light , I had one and continued to have problems with battery drain. Went for a S5. Had to order one for a audi 80 I think as ECP list the wrong sized batteries for the S3 they are too long and won`t fit. They even tried to tell me there wasn`t a S5 for my S3 lol but there is
    red to red black to black blue to bits
    Adam P's Avatar
    May 2012
    Southampton
    333
    Thanks for the responses guys, lots of useful info for me to take on board.
    The car has been absolutely fine since the battery change. So fingers crossed the problem is cured. However if the battery does drain again i will test the alternator and look at my head-unit as it is an aftermarket alpine one.
    Adam P
  1. Batterys flat, help please
    By vince, A3 turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2012, 22:09
  2. Water pump running on after ignition off & draining battery - help please
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2011, 08:00
  3. A4 18T 2003. Battery drain. HELP!
    By qawsed in forum General Technical / How To
    Last Post: 27th January 2010, 09:26
  4. Please help (strange battery drain)
    By mrlinderley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2009, 20:12
  5. A4 Battery drain-help
    By audimike in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd December 2008, 07:24
