Chris NottVolks Autos
Results 1 to 35 of 35
    Jan 2011
    Surrey
    53
    S3 Rear Wheel FAILED - HELP PLZ
    right so my mates just called me and said he was driving home from work and he could feel the back end dragging - he then sent me these pics
    now some history - back in nov 12 we took his car to the dyno for a power run to see what it was putting out and the car was fine no issues atall...
    when they went to dyno it they went to remove the haldex (4wd system) fuse as these need to be dynod in fwd however the fuse could not be locted as the panel was slightly different. the dyno guy removed a fuse which we beleived was the right one but it wasnt and instead caused a nasty clutch burning smell.. the car was strapped down while being driven and the back wheels were unable to turn even though they were trying to when accelerating..
    now we then soon realised that the car was stuck in permamnent 4wd, so they backed the rear wheels onto the rollers to dyno it using all 4 wheels..
    when we left the location his back wheels would lock up on tight turns, much like driving with a welded diff - now he got used to this and has been driving ike it daily until tonight he explaned what ive put above...
    saying the back wheels are like there dragging so i presumed the haldex system has failed and locked up completely but then when he sent me these images it looks like an arm could have snapped or something....
    any audi experts know of a haldex to cause this or are we looking at another issue here unrelated??
    my mate is not mechanicly minded in the slightest and im stuck at work until 7am so looking for someone in the know plz
    Deposit down - B6 Audi A4 1.8T (190) Sport - Daily Drive - Pajero Lwb 2800TD(the Truck - Drift Car - Nissan 180SX (S14a Front end) - FOR SALE - Subaru Impreza RB5 Ltd Edition #096 4k!!
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    i think that looks like a snapped rear tie bar, probably just near where it joins the back of the hub.
    the rear wheels locking on tight turns is probably the rear diff.
    someone please correct me if im wrong, this has never actually happened to me
    Jan 2011
    Surrey
    53
    Quote Originally Posted by danger S3 View Post
    yeh i know it has a haldex problem hence the wheels locking but i wanted to know if this was related.. thanks
    Lewis583's Avatar
    Mar 2010
    870
    As danger said, looks like he has had a tie bar fail/break/snap/whatever.
    In regards to the haldex, I'm betting the clutch plates have welded together inside the haldex section of the rear diff causing the haldex to be permanently engaged. If they couldn't find the fuse all they needed to do was apply the handbrake and that would disable the haldex.
    It highly unlikely to be related to the tie bar failure. The cause is usually the ball joints in the hubs seize which forces the tiebar to flex in ways it wasn't designed to.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jan 2011
    Surrey
    53
    Quote Originally Posted by Lewis583 View Post
    ok where can i get a tie bar? on ebay there a few hundred pound and adjustable.. stock item would suffice
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    As already mentioned... this is related to the ties bars breaking.. the rose jointed bushes seize which cause the arms to fracture... this is not related to a haldex issue...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    <tuffty/>
    Jan 2011
    Surrey
    53
    stand by, more pics being sent now and he just said some bar is hanging down lol
    Jan 2011
    Surrey
    53
    ok here we go
    is this the tie bar?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    yep, snapped aftermarket tiebar there. Not a standard item at all.
    Hopefully the makers mark in son there somewhere to perhaps claim under warrrenty, or buy one single arm
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    Ah... an adjustable tie bar that broken....
    I have seen the nuts come loose on these before... if this happened to these then the looseness of the screwed fitting will have weakened it and obviously the result is what you see here
    I can't be sure but they look like KW tie bars... these have been reported to have snapped before by another member on here... I run these myself but I do check they are secure quite regularly...
    <tuffty/>
    Sep 2006
    Sunny Suffolk
    552
    Yep. Are they KW tie bars?
    Jan 2011
    Surrey
    53
    Quote Originally Posted by Byzan Pics View Post
    hang on a minute this is not a standard item ie this item has been fitted since leaving the factory?
    sorry but im bit confused, as if these are all an aftermarket item then surley i can remove both sides and the car should be fine to run without them?
    also how easy to remove/fit are they? looks simple enough undo the shock etc??
    Apr 2004
    12,520
    Yes these have been fitted at some point after leaving the factory, probably the same time as the lowering springs.
    You will need to buy 2 standard ones and live with the camber due to it being lowered, or find out what brand it was and try to buy one as stated.
    Jan 2011
    Surrey
    53
    yer just done some research and now know these are a must when lowering..
    so i see 2 options;
    1. fit stock springs and tie bars but is it worth it? ie how much are stock tie bars?
    2. get a new pair (unlikley ill find one tie bar same as this) but how easy are these items to fit?
    will i need new bushes, poly or stock?
    are these any good?
    AUDI S3 ADJUSTABLE TIE BARS FITS AUDI A3 S3 TT R32 QUATTRO | eBay
    Feb 2012
    1,113
    im pretty sure thats a modified standard bar so the weakpoints are still there. sure i read one of the forum experts sayin this about these bars when i was looking. sure someone will correct me if im wrong. saying that if the bushes are the main reason they snap replacing these might make them ok. daz
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    The biggest problem with the std arms (and modified versions of them) is more to do with the bushes seizing than anything else... if the bushes are ok or replaced then these 'should' be ok...
    <tuffty/>
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I have one (driver's side as it happens) KW adjustable tie bar available after my passenger side one snapped in exactly the same place. I now run the Forge ones.
    But don't know if you would want to take the risk.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    ....I can't be sure but they look like KW tie bars... these have been reported to have snapped before by another member on here... I run these myself but I do check they are secure quite regularly...
    <tuffty/>
    That'll be me...
    Jason
    Jan 2011
    Surrey
    53
    Quote Originally Posted by jcs356 View Post
    yes im interested in this part mate - pm me a price please
    well this is the pic i took today of the snapped bar - can anyone confirm what this part no refers to - stock or kw etc??
    Apr 2004
    12,520
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    KW ties bars dude
    <tuffty/>
    Jan 2011
    Surrey
    53
    great thanks guys - whos the uk distributor of these?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    Jan 2011
    Surrey
    53
    great help thanks, any advice on fitting one of these?
    Apr 2004
    12,520
  28. #27
    Jan 2011
    Surrey
    53
    cant find a good read for one thanks
    looking for maybe a how to or something on here
  29. #28
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    Quote Originally Posted by reepers13 View Post
    ..then use the search facility on here or look at the stickies as I have posted how to search the site using Google to get better results..
    Sorry mate but you are gonna have to put a little leg work in ;P
    <tuffty/>
  30. #29
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    pm sent
    Jason
  31. #30
    Oct 2012
    35
    Is there anyway of checking the bushes to make sure there ok?
  32. #31
    Jan 2011
    Surrey
    53
    ok bumping this again...
    my mates s3 was doing 70-80 when the same side bar snapped again.. needless to say no damage other than the snapped bar..
    decided he wants steel ones now.. seen a set on ebay but can anyone recomend where else these are available please?
  33. #32
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    Has he checked the bushes are ok? for it to snap again it would suggest the bushes have seized...
    <tuffty/>
  34. #33
    Jan 2011
    Surrey
    53
    <tuffty/>
    no its not been looked at yet but it will be fixed if thats the problem also... just need to find some decent tie arms in steel to help prevent this from happening again
  35. #34
    Feb 2012
    68
    Yes but i think Tufftys point is it doesnt matter what the bars are made from, the issue is the bush is seized, not that bar isnt up to the job. With the bush siezed the weight of the car will be bending the bar back and forth ALL the time - accelrating/decellerating/potholes etc., and it has to give. Change the bush and an OEM bar will last the life of the car.
  36. #35
    Jan 2011
    Surrey
    53
  1. rear wheels locking during 3 point turns.can anybody help?
    By lukens3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3 Days Ago, 20:20
  2. rear wheel bearing = mot fail?
    By quattro1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2011, 19:13
  3. Rear Footwell Lights Help Plz
    By gregormac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2009, 22:21
  4. need help on rear wheel chamber
    By S3ren in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2008, 19:19
  5. Noise from rear wheel - Tyre problem ? Help
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th February 2007, 19:22
