Volks AutosChris Nott
Page 3 of 3 FirstFirst 123
Results 81 to 87 of 87
Like Tree11Likes
Thread: New Year - new suspension!
  1. #81
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    I need to do those trailing arm bushes on mine. Does the alignment need to be redone after?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  3. #82
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Ideally yes, there is a small amount of movement in the mounting and it can have an effect on rear toe.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  4. #83
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Update with piccies!
    So it's done....all in it wasn't too bad a job. The total list of parts fitted ended up as
    - Bilstein B12 Pro Kit
    - Dave's tiebars (fitted in the top position)
    - Rear tiebars poly bushed (inner)
    - R32 Rear ARB
    - Rear trailing arm front bushes polybushed
    - Cupra R top mount rubbers with OE bearings
    - Front wishbones front bushes poly-bushed
    - Front wishbones rear bushes OE audi TT
    - OE track rod ends
    - OE ball joints
    - New bolts and nuts for the stuff above
    The only annoying hurdles were:
    1. The trailing arm bush bolt on the drivers side seizing to the inner collar on the bush, I had to grind the bolt in half in the end which took aaagggeeeesss.
    2. The front track rod ends were goosed as a previous mechanic had rounded off the hex on the top, again I had to cut these off with a grinder.
    After completing the work on Friday night, I took it in for alignment on Saturday morning:
    After much adjustment (it was way out after putting the new stuff on) the results looked like this:
    I can confirm that the car now handles properly well. All of the above gubbins has been done before by others so I've not really broken any new ground, but my god it is good. Still comfortable and smooth but it turns in properly and no longer gives me motion sickness from rolling about. The ride quality is exactly what I was after, still comfortable enough to run the wife about in and no rattles, but really effective at pace. Whilst the suspension still seems to be settling, it already looks heaps better than before, here it is after a it had a bath on Saturday:
    Handling wise the only other thing I want to change is the steering rack bush, I'll probably poly-bush it in the next few weeks.
    Thanks for looking
    s3dave, superkarl and Sam_ like this.
    > S3 225 (03) - OEM+
    View: My S3 diary
  5. #84
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,456
    excellent work. looks great
    [Dave B] likes this.
  6. #85
    Alex C's Avatar
    Lizard, Cornwall
    2,563
    Quote Originally Posted by [Dave B] View Post
    I thought Dave had stopped making these?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
  7. #86
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Quote Originally Posted by Alex C View Post
    Mine are the coated mild steel versions, he's stopped making the fully stainless items.
    > S3 225 (03) - OEM+
    View: My S3 diary
  8. #87
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    Just FYI, the later powder coated ones are thinner, so you can bolt you xenon height sensor on it as normal. The first batch of SS ones which I have are a bit more chunky, so I had to modify the xenon sensor bracket. On the basis of fitting the arms at the bottom of course.
    Alex C likes this.
    You've got to have a laugh!
  1. New year, new pics
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th January 2008, 00:54
  2. X-mas and New Year screensavers!
    By TDI-line in forum General Chat
    Last Post: 20th December 2005, 01:43
  3. More New Year Resolutions
    By jdp1962 in forum General Chat
    Last Post: 2nd January 2005, 18:04
  4. new A3 , sport suspension
    By pentidis in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th September 2004, 00:04
  5. Seeing as it's New Year what's your calendar??
    By JohnH in forum General Chat
    Last Post: 10th January 2003, 17:10
