Sky InsuranceVolks Autos
Results 1 to 22 of 22
    Jan 2013
    11
    audi a3 1.8t quattro engine code replacement
    hi guys...new to the site,hoping someone can shed sum light on my problem.i have an audi a3 1.8t quattro engine code ajq 180bhp, i was just wondering what other engine codes would be compatable for a direct replacement...due to finding it hard to get an ajq engine, it needs to be a 180bhp..any help would b appreciated
    Alex_Dubz's Avatar
    Dec 2012
    Bucharest, Romania
    23
    Taken from wikipedia: AJQ, APP, ARY, ATC, AUQ, AWP, BEK, BNU (North America only), BBU (UK)
    I guess AUQ would be easiest to find and i'm sure its a traverse engine found on MK4 Golfs also, but what happpened to yours?
    Jan 2013
    11
    Oil light came on so i looked in to it and the oil pump had gone so changed that and it still came on and it was ticking and i let it run for about 5 min and the car just cut out and it wouldnt start now so my m8 who is mecanic said it sounds like it has seized,but has'nt yet looked at it...thank you for your reply
    James TQ's Avatar
    Apr 2012
    Essex
    546
    get it looked into a little deeper instead of saying, it wont start need a new engine, the 180bhp engine is the a3Q is also in the TT 180bhp, call around salvage yards but a new engine isnt cheap...get another opinion first
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    for the most part all 20v 1.8t engines are the same... you can fit a 20v engine from almost any transverse VAG car and it will work the same as now... there are a few caveats though... main differences are rods, cam chain tensioner (VVT/Non VVT), large port/small port head and SAI...
    Cars to consider are Mk4 Golfs, Mk3 Ibizas, Mk1 Leons, Skoda Octavias, and 8L A/S3's... there is a link to a spec sheet in the FAQ's sticky that has engine codes etc in there that can help... most people opt for AGU engine as a replacement as they come with 20mm rods as std, are non VVT and are widely available from A3's and Golfs... Mk3 Ibiza Cupra's use 20mm rods and small port heads (again non VVT), later AUM engines use 19mm rods and are VVT...
    <tuffty/>
    Jan 2013
    11
    Hi lads i have just found a auq engine 180 bhp out of a seat leol cuppra with every thing and 6 spped box £475 with 102000 on and the one in my car has 165000 is that a good buy for one of these thanks for the feedback
    James TQ's Avatar
    Apr 2012
    Essex
    546
    why are you buying a new engine when your not 100% of the cause!?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Should say that you do not have to have to find an engine with the same power output rating for it to work... you could in essence drop in as BAM 225 engine from an S3 but it will still only put out 180hp as the output is mapping/turbo related...
    The AUQ engine has 19mm rods and VVT... your AJQ engine has 20mm rods (IIRC) and is non VVT.... technically the bottom end of the AUQ engine is inferior to your AJQ but in reality will work fine...
    Some other useful info...
    1.8T 20V Engine codes FAQ
    <tuffty/>
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,090
    If i ever had to replace the whole engine in my TQS i would be looking at upgrading at the same time and putting a 225 bhp S3/TT unit in it.... at least you get something to put a smile on your face and not just your old car back the way it was when you've had to shell out a load of cash
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by 666markyboy View Post
    Putting the engine in by itself won't give you the power dude... tbh its cheaper to source an engine like an AGU or something from any other car than an S3 or TT as for some reason they seem to think this warrants a premium on the price when in actual fact there is not a lot different mechanically...
    There is a little bit of work involved going from a K03 turbo'd engine to a K04 turbo'd engine too so make sure you get as many ancillaries as possible..
    <tuffty/>
    Jan 2013
    11
    Just striped the engine down and the teeth on the crank that drive the chain on the oil pump have snaped off so i have got to heat it up 2moz and get it off does anyone no where i can get one of those sprockets from thanks
    Jan 2013
    11
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Audi dealer should be able to get one I think... never seen that before... has the tensioner arm broken? its plastic and most likely damaged or even the cause of the failure in the first place...
    <tuffty/>
    Jan 2013
    11
    Yes m8 it was in the bottem of the sump and the sprocket off the oil pump was in the sump as well it had sheered the bolt off thanks m8
    Jan 2013
    11
    Just phoned audi up and the cog is part of the crankshaft audi want £518 +vat?????
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by andy321 View Post
    Sounds about right... give Bill at Badger 5 a call (http://www.facebook.com/Badger5Ltd) as I know he has a damaged crank that you might be able to use for the gear...
    <tuffty/>
    Jan 2013
    11
    Sound m8
    Jan 2013
    11
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Found one then
    <tuffty/>
    Jan 2013
    11
    Ye m8 go one from tps in wolvo £15
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Dealers are absolute rubbish at finding parts LOL... (except for Jason.s of course ;P)
    <tuffty/>
    Jan 2013
    11
    Lol all dun now with new cambelt waterpump and oil pump and a full service thanks for your help everyone
  1. Audi 2.0T TTS Quattro Engine Cover
    By Spin140 in forum Parts Requests
    Last Post: 29th February 2012, 11:46
  2. Audi 2.0T TTS Quattro Engine Cover
    Last Post: 22nd February 2012, 19:31
  3. Help! Engine for Audi A4 1.8t Quattro 2002
    By SLICKSTER in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th October 2009, 08:50
  4. Audi TT 2.0 16v TDI engine code?
    By EMT in forum TT/TT-S/TT-RS Forum
    Last Post: 6th May 2009, 13:52
  5. audi s3 engine code
    By mart72 in forum General Technical / How To
    Last Post: 7th February 2007, 22:14
