JMB RetrofitsBadger5
Results 1 to 19 of 19
    Jun 2012
    45
    Fault code 17608 Boost Pressure Control Valve
    Hi all,
    Does this fault code mean I need to replace the n249 valve or is it my forge008 needing a service? Anyone got any other ideas?
    Cheers Coless3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Have you got an N249 bypass?
    <tuffty/>
    Jun 2012
    45
    No I haven't. Am I right in thinking that the n249 valve dumps the boost or not?
    Is it best to do a bypass? Won't it mean that the fault code is there continually if the n249 is bypassed or am I wrong
    coless3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    That fault code is the result of the ECU trying to use the N249 to operate the dump valve under boost as there is an issue somewhere (typically an over boost deviation)... if the ECU doesn't see the boost pressure drop quickly enough (or at all) then this code is thrown as it implies there is an issue with the dump valve...
    If you have not done an N249 bypass then it suggests the DV is the problem.. I would look at that in the first instance...
    <tuffty/>
    Jun 2012
    45
    What's the reason for a n249 bypass? I have a forge 008 fitted, should I service it? Could this solve the problem?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    N249 bypass is more suited to highly tuned setups... big turbo power etc... it also serves to clean up the engine bay if thats what you wish to do.. for stage 1/2 levels of tune it is not really thats required to be done but it does improve DV response a little...
    Its a protection system that is used by the ECU to prevent engine damage from an overboost situation...
    I couldn't say for sure if servicing the 008 will 'fix' your problem as the very fact that this has come up in the first place is because of another potential issue requiring the ECU to try and dump boost... service the DV anyway as they do require this from time to time, make sure that its actually working too... if you are getting a fluttering sound (choo, choo, choo noise) when you lift off the throttle (even revving the engine whilst stood still will highlight this) then the DV is not working properly so check it and the way its plumbed in
    <tuffty/>
    Jun 2012
    45
    Cheers for that, I know this is properly a silly question and there properly is an endless amount of things it could be but what would make the ECU try to dump boost?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    ...as I explained above... too high a boost deviation... if actual boost is higher than requested boost by 200mbar or more for a set amount of time then it will try and dump boost and throttle cut to protect the engine...
    <tuffty/>
    Gizmo20VT's Avatar
    Jun 2012
    289
    Error codes and logs would point you in the right direction , could be anything from a small boost/vac leak, to a faulty electronic component.
    Jun 2012
    45
    Gizmo20vt
    what would I be looking for in the logs? Would this highlight where the problem is coming from?
    is there set values for what certain things should be running at whilst looking at a log?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    You need to log block 115 as a minimum... this will give you requested boost vs actual boost
    <tuffty/>
    Jun 2012
    45
    So if my actual boost is higher then then the requested boost what would I be looking at then?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Quote Originally Posted by Coless3 View Post
    So if my actual boost is higher then then the requested boost what sort of log block would I need to do then?
    If this is the case then you have a mechanical problem....
    One issue at a time though... fix the DV issue then start logging...
    <tuffty/>
    Jun 2012
    45
    Have taken out the DV and serviced it and checked it is working as far as i can. Did a log block 115 and as far as i can tell the actual boost pressure and desired boost pressure are all within 200mbar.
    Results were at 5760rpm ;- Actual boost pressure was 2190mbar and desired boost pressure was 2180mbar.
    Could the problem just be a faulty N249 valve? Is there any way of testing it?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Not particularly...
    I assume the code hasn't come back and the car is running ok? if so I would not worry too much about it at this time... if you are sure the boost is ok (what gear did you do the logging in?) then I would wait and see if you get the code again
    <tuffty/>
    Jun 2012
    45
    3rd gear ? does that boost pressure sound about right?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Would need to see the logs tbh...
    <tuffty/>
    Jun 2012
    45
    i haven't got them with me atm, would you mind looking at them tomo night.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Sure...
    <tuffty/>
  1. 17963/P1555 - Boost Pressure Control: Upper Limit Exceeded :(
    By Dubstep in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2011, 21:39
  2. engine fault code p1200 (boost control valve)
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2011, 17:48
  3. boost pressure control valve mechanical malfunction
    By stoneys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2010, 20:01
  4. code 18223 pressure control valve
    By toolnut in forum General Technical / How To
    Last Post: 22nd January 2009, 01:32
  5. Boost pressure control valve
    By imported_SYNAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2004, 09:33
