Tsportaudia3
Hi all, was looking at Creations Motorsport website and came across this item, anyone have any previous experience of this part, recommend it or not, or would you say get a used 007 dv and a service kit? Thanks
I've just fitted a 007 after having the fluttery OEM since I bought the car a few weeks ago. It pulls much harder now, sounds a lot more spooly and just feels better. Granted they might leak but a bust diaphragm in my old one was obviously leaking like a madman.
Billet aluminium is always better than plastic too
Any valve would be an improvement in that case... simply fitting a new OEM one would have done the job just as well...
This point of failure was downfall of the OEM ones but the latest versions are pretty good... in fairness the OEM one could break again but I still maintain its a decent valve... being billet doesn't really make it any better... they leak at the seat.. you don't need a stiff spring (to keep it closed) as all this does is make the valve slow to respond and make the actual opening gap smaller when it does...
You can 'lap' the piston in though (like you would lap the valves in a cylinder head) and this improves the seal...
I believe the Forge 008 has a rubber seal on its piston so should seal well...
<tuffty/>
Heehee I know Anything was better than the last. I just like gnarly bits of metal rather than plastic. I bought some Hi Spec Billet 4 pots for my Escort and didn't fit them for months because I liked having them on my desk. Once I did, though, it could do stoppies
I read all of your posts and others' about the 007 vs OEM but decided to go for the Forge item just because I had the cash burning a hole in my pocket and I live close to a tuning shop which had them on the shelf. I might just give lapping a whirl then on your say so as that makes total sense :thumbsup:
today I saw an AGU Golf that had a Forge cold side relocation kit fitted... the 'vacuum' pipe for the DV was actually 'T'd into the 'boost' pipe of the N75 valve... this would mean in would almost never see a decent form of vacuum and in actual fact would never work even remotely like it should do...
<tuffty/>
isnt 'T'ing the pipe from the DV valve part of the N249 removal? sorry is this sounds like a stupid question but im new to this tuning of audis and read far to much mixing it up as i go along lol
