Volks AutosMonster Motorsport
Results 1 to 21 of 21
Thread: Speedo issues
    Oct 2012
    West lothian,Scotland
    227
    Question Speedo issues
    Hi all having problems with my mrs speedo, it seams to be off quite a bit when doing 0-40 it's out Mibi 0-10 mph on speed increase then after that 10-20 mph from 40-100 anybody know what is causing this,is there a sensor somewhere I could change thanks
    Sep 2012
    61
    Mine says 35 when doing 30 and 46 when doing 40 and 78-80 when doing 70... Think it's just generally out... Just stick with what the GPS says.
    Oct 2012
    227
    Yeah but we don't have the sat nav stuck to the window all the time very rarely, it's a right pain
    Oct 2012
    227
    And mine says 90when it's doing 70
    Sep 2012
    61
    What tire's do you have on..?? (Size) as you can slightly adjust the speedo depending on your tire sizes etc... As depending on the tire size depends on how many times the wheel spins which then effects the speedo etc...
    Oct 2012
    227
    It's just 15 or 16 with big tyres as far as I know they are original to the car
    Sep 2012
    61
    Um... Weird... I would say live with it but if its reading 90 when you doing 70 that's way off I would say it should be 3 - 5 mph out. Check your tire pressures are up to what they should be.
    Oct 2012
    227
    Yup everything is tip top the way it's ment to be so surly there is a sensor somewhere I can change or clean or shout abuse at and see if it changes anything
    May 2011
    stocton-on-tees
    64
    They is a speed sensor in the back of the gearbox. Try changing that
    Oct 2012
    227
    Ok will do hopefully solves the problem
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    140
    I can't see how the speed sensor could cause it to be out a bit, it's just a pulsed signal, a dodgy sensor couldn't change the timing of the pulses it sends. It might miss pulses or stop them all together, but that'd cause the speedo to stop or under-read, not over-read. Still worth checking out though, it's quite simple and all just unclips with no tools if I remember right. It's on top of the diff and on a 1.8t (and maybe others) it's covered with a little heat shield pocket.
    It does sound quite likely that the tyre size is out. What actual size are they? Seems odd though, being that far out they'd be quite noticeably visually smaller. Still there's a lot of room for error with a small wheel and big tyre.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    Oct 2012
    227
    Will have to look at tyre size it's the mrs car but it could well be, because I think the car came from an old dear she maybe took it to a garage and they put the wrong tyres on as they do seam quite new so might very well be that
    Oct 2012
    227
    ok so washed the a3 today a looked at tyre sizes thay are 195/65/15 all round sound off to anybody?
    Sep 2012
    61
    They seem a bit small to me, let me just check mine..
    Sep 2012
    61
    Nope.. Exactly the same as mine. Have you checked the psi in them all?
    *edit
    its also an eu law that the speedo has to read 3mph more than what you are doing.
    Oct 2012
    227
    Yep all the psi is the same and sitting at the right pressure, and mine is well above the law then lol bloody pain in the arse just want to know what's causing it
    Sep 2012
    61
    Where does the speedo sit when your are sitting still?
    Oct 2012
    227
    Erm 0mph then as you increase the speed it gets more and more out, I thought perhaps the clocks had been changed because is a 1.6 and the clocks got to 160mph I thought they might only go to 130 or 140 but checked 1.6 on eBay and saw pics of 1.6 with clocks that went to 160mph so kind of ruled that out,but at looking at mot certificate in 14 month the car done 1200 miles????? But the mrs says it was an old dear that did not work that had it but I still find it a bit odd(btw she picked the car herself I had no say in it......she knows best as always )
    Sep 2012
    61
    The dash cluster is the same as the 1.9, 1200 in 14 months for someone who just used it to go to the shops and back is reasonably at a push.. Reset your mileage counter and drive a mile according to the satnav and see what comes up on the cars counter, as could be an underlying issue somewhere.
    Oct 2012
    227
    Set sat nav up the other day when we went to Glasgow and it ok to maybe 10 mph then after that it get increasingly worse till you reach 90mph on speedo and your actually doing 70mph
    Sep 2012
    69
    i woundnt worry to much if i was you. police allow 10% difference in speed for this reason no two speedos read the same. my work van has a gps traker an reads 70 when my van speedo reads 80ish just one of them things
  1. Audi A3 1.6 1999 Speedo Issue
    By FMAudia31.6 in forum General Technical / How To
    Last Post: 19th September 2012, 14:50
  2. Audi A3 1.6 1999 Speedo Issue
    By FMAudia31.6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2012, 17:35
  3. A3 Speedo problems issues 1996-2003
    By caddypete in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2011, 12:52
  4. A3 Speedo/Fuel gauge issues
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2010, 19:21
  5. Bumper Issue
    By tonyrmay in forum The Welcome Section
    Last Post: 23rd July 2003, 13:32
