Hi Guys. I downloaded vagcom lite and done a scan on my new s3 and I have egt temp sensor 1 open or shot to plus code present p1453-35-00. The code clears and comes back. I have removed the sensor and seems quite pitted on the end, the pins all seem ok and traced the wiring visually all the way back to the scuttle panel all ok and cleaned my earth points under the battery. I've been doing a bit of research and everyone recommends checking the wiring. Has anyone had any problems with this code coming up? I realise my sensor might be pooped due to pitting (look over heated) but wiring could also be at fault. Is there a fellow member with the full version of vag com that might be able to lend a hand in Leicester city center? Many Thanks Mark.
