Volks AutosAH Fabrications
Results 1 to 14 of 14
    S3-Steve's Avatar
    Oct 2012
    Scotland
    10
    S3 Pre facelift to facelift headlights advice.
    Hey folks, I'm looking to upgrade to the facelift headlights on my S3. I'm aware of what's involved with regards to cutting the wing etc. The thing is, my mate has given me a set of facelift headlights from his a3 8l, however as these are not xenon i'm not sure if they're of any use.
    Should I not bother with these and try and source the xenons, or is there any way I could use the xenon components from my current lights; or would anyone recommend buying an HID conversion kit?
    Cheers,
    Steve
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Mines a pre s3, i ditched the **** xenons, bought some new facelift a3 lights, fitted a 6k Hid kit and mever look back mate.
    S3-Steve's Avatar
    Oct 2012
    Scotland
    10
    Cheers mate. I might have a look into that then. Is the conversion kit easy enough to fit?
    Sep 2012
    69
    im looking to put facelift lights on mycar too. what is the process of cutting the wings? is it a big job to do as iv not seen a thread with work being carried out?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,632
    mate, I'm down sheff tomorrow, Monday and Tuesday. If your free, I gotta see how your lights are. If its any good then I think I'm just gonna do that! Was it hard to wire?
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Gops, HID kits are a piece of cake to fit, used to do em in 20min...
    Currently rolling in a SKODA!!!
    Arrkon's Avatar
    Oct 2010
    1,641
    Quote Originally Posted by Birdy View Post
    If you remove the indicator housing, there is a "lip" of metal behind that needs to be cut out (IIRC). Without removing it, the facelift lamps won't sit back enough to allow you to bolt them in.
    S3-Steve's Avatar
    Oct 2012
    Scotland
    10
    Think I'll go for the Hid conversion on the a3 lights then. Could any of you recommend the best kit to buy? Thought it would be a hassle at first but if it's easy enough to fit i may as well. It'll save a few quid too.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,632
    Cheers rob! I was wondering if it will defo be brighter than the ****ty xenons I got. And also if I'd need to do something with the wiring as facelift lamps are different connections. We need to link up dude!
    Dec 2011
    Bedfordshire
    137
    Took a few pics when I did mine
    you need to cut off this bit
    pie used a makitia 10v reciprocating saw and some tin snips I also had to cut some of the plastic behind where the light goes you will see when you fit them which bit to cut mine are just face lift a3 not Xenons
    As for the Xenons I bought some off eBay and they fit the standard lamp holes as the s3 xenon lamps don't fit
    hope this helps
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    As above, really easy todo, hardest part is cutting the wing.
    I wont be free today or tomorrow gops but think i am tuesday, drop me a text and well try to sort something.
    AVLO's Avatar
    Mar 2012
    Doncaster
    268
    this i like , i have the a3 facelift with 6k hids and the pre-facelift s3 and i have to say the a3 lights are much brighter, i have been looking for a pair of s3 facelift lights but they are going for silly money so i may look into doing this myself? does the auto leveling still work on the a3 headlights?
    BRING ON THE WET WEATHER ​QUATTRO FTW
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,632
    cheers mate! Ill text you I was just confused about the connectors on the a3 facelifts were round and the ones on my car are squarish.. Lol
    AVLO's Avatar
    Mar 2012
    Doncaster
    268
    any information on the auto leveling of the non-xenon a3 lights people? do we really need auto leveling if the are set right in the first place?
  1. xenon headlight wash pre to post facelift
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2010, 21:33
  2. Pre to post facelift headlight upgrade
    By calvin in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2010, 12:43
  3. Will facelift 1 piece headlights fit a pre facelift A3??
    By lexyy_a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2009, 21:23
  4. Different Between Pre-Facelift and Facelift?
    By emzino in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2006, 06:40
  5. Fitting facelift A3/S3 headlights to a pre facelift 1998 A3
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2005, 20:10
